Macbook A2442 820-02098 no battery charging.
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Hello, i need assistance -
    Got 820-02098 with liquid damage 2 cd3217b12 was damaged. Replaced both (On schematic uf400 for typeC and u5500 for magsafe), after replacing, computer turns on, works, but no battery charging(battery charge goes down). Checking with usbc power meter after reassembling getting 5v 1a power draw on magsafe, after reconnecting cable getting 20v 0a power draw. When power meter shows 5v, I'm getting the same 5volts on on PPDCIN_AON, but after reconnecting magsafe (20v on power meter) getting 0volts at PPDCIN_AON. Need help to understand why im not getting 20v on PPDCIN_AON line.
  • mon2
    • Dec 2019
    • 14667
    Re: Macbook A2442 820-02098 no battery charging.
    Check the voltage and parts of the attached.
    • Lukosiukas
      • Jul 2018
      • 106
      • Lithuania
      R5271 195K OHMS
      D5270 NO SHORT TO GND
      With battery disconnected :
      Magsafe voltage 5v
      SAVE_BAT_G 4.2V
      PPDCIN_AON 5V
      With battery connected :
      Magsafe voltage 5v
      SAVE_BAT_G 4.4V
      PPDCIN_AON 5V
      With battery connected:
      Magsafe voltage 20v:
      SAVE_BAT_G 0V
      PPDCIN_AON 0V
      • mon2
        • Dec 2019
        • 14667
        When the power delivery contract of 20v is selected, are you able to confirm that 20v is present on the USB Type C Vbus connector pin? Perhaps the PD controller is able to select this PD contract but the power supply being used is unable to provide this contract of 20V @ xx current.
        • Lukosiukas
          • Jul 2018
          • 106
          • Lithuania
          Yes, voltage (20v) comes up to CD3217B12, but does not go thru. But when 5v is on the line, then it goes pass CD3217B12. Thats is mindfu*king me.
          • mon2
            • Dec 2019
            • 14667
            When you have 5v power delivery contract from the outside power supply, what is the voltage to ground of PPBUS_AON ?
            What is the voltage to ground of PPBUS_AON when the PD contract is 20v ?
            From my understanding, the ISL9240 is a buck/boost regulator which when powered from 5v, should boost PPBUS_AON to ~13v.
            When the PD source voltage is 20v, the ISL9240 will enter buck mode to supply the same ~13v.
            Respectively, suspecting that the ISL9240 may be defective or the SMBUS master is unable to configure the modes of the ISL9240.
            Do check the voltage to ground of the SMBUS SCL / SDA lines on the ISL9240.
            • Lukosiukas
              • Jul 2018
              • 106
              • Lithuania
              When you have 5v power delivery contract from the outside power supply, what is the voltage to ground of PPBUS_AON?
              12volts with battery disconnected and 11.4 with battery connected.
              11.4volts
              SDA/SCL 1.78v
              Now im thinking that isl9240 could be bad. Could cd3217 break ISL after liquid damage?
              • mon2
                • Dec 2019
                • 14667
                Flux and remove D5270 and test again with the 20V PD contract. Make a note of the polarity of this diode.
                What is the voltage to ground of SAVE_BAT_G ?
                • Lukosiukas
                  • Jul 2018
                  • 106
                  • Lithuania
                  Removed D5270, no changes,
                  Save_bat_g is 0volts.
                  • mon2
                    • Dec 2019
                    • 14667
                    Do you see the 20v on the other side of the 200k resistor?
                    • Lukosiukas
                      • Jul 2018
                      • 106
                      • Lithuania
                      No, as i said, 20v from charging port goes to cd3217, but not pass it .
                      Now random thing : UR500 becomes hot, it was not earlier.
                      Edit: battery connection broke off. resoldered it, waiting for UV to cure paste.
                      • mon2
                        • Dec 2019
                        • 14667
                        UR500 = audio codec? Remove all power and check the resistance to ground of each power rail on this component.
                        • Lukosiukas
                          • Jul 2018
                          • 106
                          • Lithuania
                          Yes, after removing, turns on, same problem no batterty charge
                          • dbuergi
                            Macbook A2442 no display board 820-02098
                            by dbuergi
                            i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                            So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                            05-25-2025, 10:58 AM
                          • TechSplendid
                            MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                            by TechSplendid
                            Hi All,
                            I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                            Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                            04-09-2025, 02:13 AM
                          • tyler_jones8209
                            2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
                            by tyler_jones8209
                            So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
                            I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
                            I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
                            I don’t have much experience with laptops, only consoles and controllers...
                            10-28-2025, 04:54 PM
                          • gurpawan
                            A2442 14inch Macbook Pro ,JR940 Connector- where to buy?
                            by gurpawan
                            Hi, can anyone please advise on where to buy the JR940 microphone flex connector? I accidentally broke it while repairing A2442 14inch Macbook Pro 2021. it came off....
                            10-22-2025, 02:40 PM
                          • rounin
                            MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                            by rounin
                            Device Information
                            • Model: MacBook Pro 14” M1 Pro (A2442)
                            • Logic board number: 820-02443-05
                            Original Issue
                            The device suffered liquid damage, causing a short circuit on the logic board.
                            Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                            Work Performed
                            Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                            Current Status
                            • When powered on, the screen shows support.apple.com/mac/restore....
                            10-20-2025, 11:15 PM
