Macbook A2442 820-02098 no battery charging.
  • Lukosiukas
    • Jul 2018
    • 106
    • Lithuania
    Hello, i need assistance -
    Got 820-02098 with liquid damage 2 cd3217b12 was damaged. Replaced both (On schematic uf400 for typeC and u5500 for magsafe), after replacing, computer turns on, works, but no battery charging(battery charge goes down). Checking with usbc power meter after reassembling getting 5v 1a power draw on magsafe, after reconnecting cable getting 20v 0a power draw. When power meter shows 5v, I'm getting the same 5volts on on PPDCIN_AON, but after reconnecting magsafe (20v on power meter) getting 0volts at PPDCIN_AON. Need help to understand why im not getting 20v on PPDCIN_AON line.
  • mon2
    • Dec 2019
    • 14118
    Re: Macbook A2442 820-02098 no battery charging.
    Check the voltage and parts of the attached.
    • Lukosiukas
      • Jul 2018
      • 106
      • Lithuania
      R5271 195K OHMS
      D5270 NO SHORT TO GND
      With battery disconnected :
      Magsafe voltage 5v
      SAVE_BAT_G 4.2V
      PPDCIN_AON 5V
      With battery connected :
      Magsafe voltage 5v
      SAVE_BAT_G 4.4V
      PPDCIN_AON 5V
      With battery connected:
      Magsafe voltage 20v:
      SAVE_BAT_G 0V
      PPDCIN_AON 0V
      • mon2
        • Dec 2019
        • 14118
        When the power delivery contract of 20v is selected, are you able to confirm that 20v is present on the USB Type C Vbus connector pin? Perhaps the PD controller is able to select this PD contract but the power supply being used is unable to provide this contract of 20V @ xx current.
        • Lukosiukas
          • Jul 2018
          • 106
          • Lithuania
          Yes, voltage (20v) comes up to CD3217B12, but does not go thru. But when 5v is on the line, then it goes pass CD3217B12. Thats is mindfu*king me.
          • mon2
            • Dec 2019
            • 14118
            When you have 5v power delivery contract from the outside power supply, what is the voltage to ground of PPBUS_AON ?
            What is the voltage to ground of PPBUS_AON when the PD contract is 20v ?
            From my understanding, the ISL9240 is a buck/boost regulator which when powered from 5v, should boost PPBUS_AON to ~13v.
            When the PD source voltage is 20v, the ISL9240 will enter buck mode to supply the same ~13v.
            Respectively, suspecting that the ISL9240 may be defective or the SMBUS master is unable to configure the modes of the ISL9240.
            Do check the voltage to ground of the SMBUS SCL / SDA lines on the ISL9240.
            • Lukosiukas
              • Jul 2018
              • 106
              • Lithuania
              When you have 5v power delivery contract from the outside power supply, what is the voltage to ground of PPBUS_AON?
              12volts with battery disconnected and 11.4 with battery connected.
              11.4volts
              SDA/SCL 1.78v
              Now im thinking that isl9240 could be bad. Could cd3217 break ISL after liquid damage?
              • mon2
                • Dec 2019
                • 14118
                Flux and remove D5270 and test again with the 20V PD contract. Make a note of the polarity of this diode.
                What is the voltage to ground of SAVE_BAT_G ?
                • Lukosiukas
                  • Jul 2018
                  • 106
                  • Lithuania
                  Removed D5270, no changes,
                  Save_bat_g is 0volts.
                  • mon2
                    • Dec 2019
                    • 14118
                    Do you see the 20v on the other side of the 200k resistor?
                    • Lukosiukas
                      • Jul 2018
                      • 106
                      • Lithuania
                      No, as i said, 20v from charging port goes to cd3217, but not pass it .
                      Now random thing : UR500 becomes hot, it was not earlier.
                      Edit: battery connection broke off. resoldered it, waiting for UV to cure paste.
                      • mon2
                        • Dec 2019
                        • 14118
                        UR500 = audio codec? Remove all power and check the resistance to ground of each power rail on this component.
                        • Lukosiukas
                          • Jul 2018
                          • 106
                          • Lithuania
                          Yes, after removing, turns on, same problem no batterty charge
                          • dbuergi
                            Macbook A2442 no display board 820-02098
                            by dbuergi
                            i got a Macbook A2442 which statrts normal but is not showing any picture. Using an external monitor works fine. After opening the Macbook i found a dried up line of liquid damage around CN979, RD503, and UP730. I cleaned up everything and also unsoldered the chips to clean the pads. There were no shorts before but i still don't have any picture. Sometimes you can see a glimpse of light in the middle of the display.
                            So before i change the whole display i want to make sure that it's not any issue with the logicboard. So any ideas what i can check next?...
                            05-25-2025, 10:58 AM
                          • TechSplendid
                            MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                            by TechSplendid
                            Hi All,
                            I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                            Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                            04-09-2025, 02:13 AM
                          • Constantinos
                            Macbook Pro A2442 820-02098 No image but has backlight
                            by Constantinos
                            Hi all
                            I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                            He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                            Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                            Obviously, he decided against this and gave it to me so that I could have a crack at it.
                            From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                            08-24-2024, 09:48 AM
                          • Enzo150i
                            MacBook A2442 exclamation mark after oxydation
                            by Enzo150i
                            I have a MacBook Pro A2442 with board 820-02098-A very highly oxydated (water) by an accident.
                            The customer just need to recover the data (no backups, heh), so we cleaned fully to make it power on.
                            Fortunately the Mac is still alive but it shows an exclamation mark in a circle (!) (Apple T2 fw issue?) with the text "support.apple.com/mac/restore" and doesn't go further.
                            We tried to interface with another Mac, but can't get in DFU. Very likely the keyboard is gone too because the water, so we're planning to buy a cheap compatible one just to....
                            06-29-2025, 01:26 PM
                          • veedo
                            Macbook A2442 820-02098 boot and display issue
                            by veedo
                            Hi All
                            I have MacBook A2442 which had keyboard replaced and now it doesn't turn on correctly, it have sound chime from time to time and Apple logo shows on the display and there is no backlight on, apple logo appear and stuck on kind of boot loop. But if one of the display flexes is disconnected from the motherboard then MacBook turns of fine with the external monitor and it keeps working fine.
                            Without keyboard its still have same issue, I don't have second display to replace it and compare but does display can make issues with boot?
                            I found component UD290 ( SF0101-I2C) little...
                            04-01-2024, 06:06 AM
