iPad Pro 11 A2230 won't boot up - stuck at logo
  • martyjelen
    • Mar 2023
    • 127
    • Czech republic
    I have iPad which stuck at logo. Is there something I can do with it without data loss?
    Thanks for your help
    Martin
  • mon2
    • Dec 2019
    • 14758
    Re: iPad Pro 11 A2230 won't boot up - stuck at logo
    https://support.apple.com/en-us/HT212017
    • elecsoluces
      • May 2020
      • 66
      • France
      Try DFU mode and update the device with 3utools
      • martyjelen
        • Mar 2023
        • 127
        • Czech republic
        But there is a risk of data loss during update isn't it? Already tried to enter DFU mode with itunes but it doesn't work.
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          So, it looks there is no way to get data back due to encryption, so chip-off is not possible.
          • elecsoluces
            • May 2020
            • 66
            • France
            In DFU mode you can't update the device with itunes, you have to use 3utools.
            No risk of loosing data with an update.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              I tried to use 3utools but I can't get into DFU mode. I tried this :
              https://osxdaily.com/2021/10/10/ente...e-ipad-pro-m1/
              Is it correct way to get into DFU mode?
              • martyjelen
                • Mar 2023
                • 127
                • Czech republic
                Nobody knows?
                • mon2
                  • Dec 2019
                  • 14758
                  Is the USB cable a known good cable? Test with another.
                  Is the charge port on the ipad still ok? Do you hear any dock chime when the charge cable is mated to a charger / power adapter?
                  • martyjelen
                    • Mar 2023
                    • 127
                    • Czech republic
                    Yes. Cable is new. Never used before. Tried another, but still the same.
                    Charge port is OK. If I plug it to power supply, it takes 15V /1.5A.
                    Power off is imposiible with power button, I must disconnect battery to kill it. I don't really know what dock chime is, but I don't hear anything.
                    • mon2
                      • Dec 2019
                      • 14758
                      Often, when the ipad / iphones are plugged into a USB port on a host PC or power adapter, the screen will power on and you will hear a 'ding' sound to inform the user that the battery is now being charged.
                      The current consumption is a good start which means that the unit is consuming current.
                      What is the history of this unit? Any liquid damage / was dropped?
                      • mon2
                        • Dec 2019
                        • 14758
                        You are not alone...
                        https://discussions.apple.com/thread/250584769
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          Ah, I see. There is no sound, when I connect it to power supply.
                          Known history : suddenly stuck for unknown reason. No signs of liqiud damage, nor dropped.
                          • mon2
                            • Dec 2019
                            • 14758
                            The unknowns are if this is a hardware / software or crapware root cause.
                            If crapware, only Apple will know how to fix their custom OS. Even if you wanted to erase the contents of this ipad to reset to factory - is that possible with your unit?
                            That is, you are able to boot up but always gets stuck at the Apple logo -> the unit is not responding to any of the combinations of button presses?
                            Other hardware videos cite that coils (mostly) or caps get damaged during an ipad drop and this can then cause a stuck at logo or bootloop fault.
                            See here:
                            https://www.youtube.com/watch?v=ODYUxi83l2s
                            This model is with a USB Type C connector? The power delivery contract appears to be working if it is selecting a higher than the default 5 volts out of the external power adapter.
                            This validates that the CCx lines are working on the one side of the USB connector blade.
                            Remove and rotate the type C connector head by 180 degrees and test again if iTunes can find this unit. That is, by rotating the type C head, you are now using the other half of the dual sided connector head. Perhaps one side is damaged (ESD?) but the other side may be ok.
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              This is exact what I'm trying to understand. If It's a HW or SW error.
                              Unit is stuck in bootloop and doesn't respond to any button combination.
                              It has a USB-C connector. I will try to rotate connector and check it again.
                              I will let you know tomorrow.
                              • mon2
                                • Dec 2019
                                • 14758
                                The timing to perform the reboot of this model is critical. Perhaps try again the button press combinations posted on the Apple and other websites.
                                Other ideas are to carefully disconnect the display and digitizer connector - see the many youtube videos before proceeding. Keep track of your screws and disconnect the battery first.
                                The mate the battery and attempt to connect to the host PC with itunes. Do you hear a ding upon applying power to the unit (without the display)?
                                • Stevedb
                                  Stevedb
                                  • Feb 2018
                                  • 624
                                  • Belgium
                                  Also those ipad are known for broken coils inspect the board for lose coils. Or broken coils.
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    I already tried ever possible combination of buttons press, but still the same. Even without LCD and digitizer. Also tried disconnect everything that is not need for power on unit. Still no sound.
                                    • martyjelen
                                      • Mar 2023
                                      • 127
                                      • Czech republic
                                      Checked all coils on board. Everything looks OK.
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        I leaved it some time on power supply and noticed that C8073 is very hot and look burned. Also D8710 burned. That's weird.
                                        And only Aliexpress have these diodes. So I have to look for some donor.
                                        • GeirAndersen
                                          iPad .pcb file collection
                                          by GeirAndersen
                                          I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
                                          Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
                                          IPAD COLLECTION 1
                                          +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
                                          +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
                                          +---iPad mini3 820-00008(A1599) 820-00002(A1600)
                                          +---iPad mini4 820-00180(A1538) 820-00177(A1550)
                                          +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
                                          +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
                                          12-09-2024, 09:28 AM
                                        • Teban1306
                                          [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                          by Teban1306
                                          Hello everyone!
                                          I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                          System Information:
                                          • Model: Lenovo ThinkPad T14 Gen 1
                                          • Machine Type: 20S1S4E600 (Intel i7 variant)
                                          • Current BIOS: N2XET42W (1.33) - Latest version
                                          • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                          What I'm trying to achieve:
                                          Replace the default "LENOVO" boot logo with a custom image during POST.
                                          🔧 What I've tried:
                                          09-14-2025, 11:49 AM
                                        • q2v5
                                          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
                                          by q2v5
                                          Lenovo T480s
                                          Model 20L8-S3TE00
                                          Board ET481-U10
                                          Chip MX25L12873F
                                          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
                                          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
                                          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
                                          08-15-2024, 10:40 PM
                                        • DynaxSC
                                          MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                                          by DynaxSC
                                          Hi Folks
                                          I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                                          Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                                          09-29-2024, 04:27 PM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
