Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
  • mon2
    • 14664
    Re: Macbook A1989 - 820-00850-A Won't turn on - stuck at 5V/5mA
    Leave at 5A. We want the shorted part to heat up.
    For safety, keep the voltage at 1v or even 0v8.
    • martyjelen
      • Mar 2023
      • 127
      • Czech republic
      I didn't noticed anything heat up. There is still short.
      • mon2
        • 14664
        When the power supply at 1v is applied, what is the current draw?
        • martyjelen
          • Mar 2023
          • 127
          • Czech republic
          2 ampers
          • mon2
            • 14664
            Confirm if the power supply is being current limited. If yes, increase this value to 5A and test again.
            • martyjelen
              • Mar 2023
              • 127
              • Czech republic
              #26
              It's not. I set it to 5A. Still get only 2A.
              • mon2
                • 14664
                Increase the voltage to 2 volts and test again. Monitor who is heating up.
                • martyjelen
                  • Mar 2023
                  • 127
                  • Czech republic
                  #28
                  I found it. It's C6555 and C6556. They are very hot.
                  • mon2
                    • 14664
                    Excellent!! Flux and remove both of these parts.
                    Be sure the pads are not shorting and then check the resistance to ground again if F7000, pin #2.
                    • martyjelen
                      • Mar 2023
                      • 127
                      • Czech republic
                      #30
                      I already removed C6555 and there is no short anymore. I can measure F7000, but I will do it on Monday. I must go out. I will reply on Monday.
                      Thanks again. You are very kind.
                      • mon2
                        • 14664
                        Excellent! Place back the removed fuse and test it all again.
                        Thanks to @Piernov for the clarity on how to test the short condition - initially to me, thought your CPU was shorted.
                        This is a good read as well:
                        https://logi.wiki/index.php/PPBus_G3H
                        Review the article on PPBus Shorts (@Piernov).
                        Will cross my fingers waiting for some good news on Monday.
                        • martyjelen
                          • Mar 2023
                          • 127
                          • Czech republic
                          #32
                          Just to be sure, you mean place the fuse back, connect it to power supply trough USB-C and see If I get 20V?
                          Sorry for dumb questions, but I'm really a newbie. And I don't want to kill the board completely.
                          • mon2
                            • 14664
                            Yes. Remove all power to the board. Start with posting the resistance to ground of the F7000, pin #2 so we can be sure the short is gone. Then solder back the removed fuse and confirm the voltage of PPBUS_G3H.
                            Ideally, this was the only root cause and the unit should be repaired.
                            • martyjelen
                              • Mar 2023
                              • 127
                              • Czech republic
                              #34
                              It's about 5MΩ.
                              • mon2
                                • 14664
                                Good resistance. Solder back the fuse and test again.
                                • martyjelen
                                  • Mar 2023
                                  • 127
                                  • Czech republic
                                  #36
                                  Now I get 20V on all ports. You are the best! Thank you very much!!!
                                  • martyjelen
                                    • Mar 2023
                                    • 127
                                    • Czech republic
                                    #37
                                    Sadly, when I put PCB back it still won't turn on. Maybe there is another problem.
                                    • mon2
                                      • 14664
                                      What is the voltage and current draw? Is the current draw stable or cycling?
                                      What is the voltage to ground reading of PPBUS_G3H @ F7000 ?
                                      • martyjelen
                                        • Mar 2023
                                        • 127
                                        • Czech republic
                                        #39
                                        20V / 0.436A - stable
                                        Voltage at F7000 PPBUS_G3H is 12.5V. I noticed that U7800 is hot.
                                        • mon2
                                          • 14664
                                          What is the voltage to ground of ALL_SYS_PWRGD_R ?
                                          Perhaps try DFU.
                                          • MyronViegas
                                            MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                                            by MyronViegas
                                            Hey guys,
                                            I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                                            Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                                            10-06-2025, 08:45 AM
                                          • PITERPENY
                                            MacBook A1989. Stuck in DFU and won't turn on!
                                            by PITERPENY
                                            MacBook A1989. does not work with dfu. Stuck in DFU and won't turn on!
                                            20 volts and 0.00 amperes
                                            Does anyone have any suggestions?
                                            It's possible that the problem is in the EFI (BIOS),
                                            who has the EFI ROM file please share
                                            01-11-2024, 07:43 PM
                                          • nosinformatica
                                            Macbook Pro 13'' - A1989 stuck at 5v
                                            by nosinformatica
                                            Preface : My primary job it's not repairing logic board, so please excuse me.
                                            The Macbook A1989 is stuck at 5v at 0.3A on three usb-c port, and in one port no absorption, so the incriminated chip may be the CD3125.
                                            I'have read that these mac have two CD3125 in daisy chain.
                                            How can i confirm my diagnose before reballing it? Someone have experience with this issue?...
                                            09-29-2023, 06:29 AM
                                          • Bmet
                                            MacBook Pro 13 inch A2238 M2 stuck on 5V
                                            by Bmet
                                            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                            04-02-2025, 05:02 PM
                                          • modtool
                                            Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                                            by modtool
                                            Dear friends,
                                            a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                                            I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                                            I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                                            Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                                            10-25-2025, 05:09 AM
