Lenovo T470 not charging
  • mohamed mm
    • Nov 2022
    • 41
    • India
    The client brought me a laptop Lenovo T470 and it's not charging, the client said the battery is good and this suddenly happened to him, and reading from Ic charging it's like this:
    (BQ25700RSNR_QFN32_4X4) ic name.
    1: VCN= 20V
    2: VCP= 20V
    3: VBUS= 20V
    7: VDDA= 6V
    4: CHGR_OK= 3.3V
    21: BATDRV#= 3.3V
    22: VSYS= 9.2V
    3 pins in the battery connector have 3.3v, and when I connect the battery one goes 2.3v and the other two pins stay in 3.3v.
    what else do I have to check? ask me anything and I will replay as soon as possible.
    there is a pic of battery charger.
    Thank you.
  • mon2
    • Dec 2019
    • 14544
    Re: Lenovo T470 not charging
    Connect the battery.
    Measure the voltage to ground of:
    SRN
    SRP
    • mohamed mm
      • Nov 2022
      • 41
      • India
      with battery:
      SRN= 9.2V
      SRP= 9.2V
      without battery:
      SRN = 9.2V
      SRP= 9.2v
      Thank you for respond
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        How much voltage do you have on ac drive.
        • mohamed mm
          • Nov 2022
          • 41
          • India
          do you mean ACN?
          ACN= 20v
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            Sorry i was mistaken i thought it was bq24780s. The charging ic. i was mistaken with another treath.
            • mon2
              • Dec 2019
              • 14544
              Link the full schematic when you can. Braincells are being wasted today on retooling our dreaded smt line for a new part.
              • mohamed mm
                • Nov 2022
                • 41
                • India
                this is the schematic,
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Please link to topic in the Schematic subsection rather than uploading schematics in your post here!
                  I'm tired of editing posts in the section. Finally, I will start deleting all replies with attached schematics.
                  Please edit your post!
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • mohamed mm
                    • Nov 2022
                    • 41
                    • India
                    I was not aware of the existence of such a violation and I will not do it again, but I cannot delete or modify the response because the modification option has disappeared.
                    Lenovo T740 schematic link.
                    https://www.badcaps.net/forum/showthread.php?t=78951
                    • mon2
                      • Dec 2019
                      • 14544
                      Confirm the voltage to ground of each pin on connector PJ2. Connect your battery while checking.
                      Confirm the voltage to ground on each side of fuse PF3.
                      • mohamed mm
                        • Nov 2022
                        • 41
                        • India
                        Pj2 & pj3
                        without battery,
                        1pin= 0.21v
                        2pin= 0.21v
                        3pin= 3.3v
                        4pin = 3.3v
                        5pin= 3.3v
                        6pin= 0.0
                        7pin= 0.0
                        fuse= 0.21v
                        with battery:
                        1pin= 0.0v
                        2pin=0.0v
                        3pin= 3.3v
                        4pin= 3.3v
                        5pin= 2.06v
                        6pin= 0.0
                        7pin= 0.0
                        fuse= 0.0
                        • mon2
                          • Dec 2019
                          • 14544
                          Remove all power. Remove the battery.
                          Meter in resistance mode.
                          Check the resistance of the same fuse using the meter probes across the fuse.
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            The name of the subsection speak for itself, all the schematics must be placed there, not all over the forum. It's interesting how you would easily find a schematic in a forum without knowing exactly which section to look in for it?
                            Not to mention it is very easy to assume that if the same schematic is uploaded several times in a hundreds of created threads, it will overflow the server free space. We still have critical difficulties with this problem - there is a sticky thread regarding this issue:
                            "IMPORTANT ANNOUNCEMENT. Possible closure of Bios Requests"
                            https://www.badcaps.net/forum/showthread.php?t=116453
                            • mohamed mm
                              • Nov 2022
                              • 41
                              • India
                              FUSES with probes on both sides:
                              fp3= 000
                              fp4= 000
                              FUSES with black probe on ground and red on one side of the fuse:
                              fp3= 1.9 mega ohm
                              fp4= 1.9 mega ohm
                              • eliemgh
                                • May 2024
                                • 13
                                • lebanon
                                hello . i have a problem on t470 batteries, the voltage on battery cellule is ok (total 12 volts) but on board no voltage . any one can help me
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                • jared101
                                  Lenovo Ideapad 320-15IKA NM-B452 not charging battery
                                  by jared101
                                  NM-B452
                                  Hi guys. I've used the forum a lot but never asked questions before. I had a Lenovo come in that was shorted on the 20V rail. I fixed that and thought my job was done until I realized it wasn't charging the battery. Here is what I've checked so far
                                  On the BQ24780SRUYR charging ic
                                  VCC 20V
                                  SMBUS lines
                                  SDA 3.3V
                                  SCL 3.3V
                                  Current Sensing lines
                                  ACP/ACN 2.3 ohms
                                  SRP/SRN 21.2 ohms
                                  REGEN line 6V
                                  PHASE .84V with no battery installed(this may be normal)
                                  08-03-2022, 09:19 PM
                                • Julian Bailey
                                  HP ProBook 445 G8 Battery not charging
                                  by Julian Bailey
                                  Hi all
                                  We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                  The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                  I have gone around the board with a MM and cant find anything
                                  Windows shows the battery fine,...
                                  10-11-2024, 10:34 AM
                                • mferna14
                                  Lenovo Carbon X1 Battery not charging
                                  by mferna14
                                  Hi, Working on a Lenovo X1 Carbon 1st Gen (Type 3444) Laptop. Came in for battery problems. Upon testing the battery, I noticed that one of the cells is bursted & has to be replaced. Ordered a Brand New battery. Now it works on battery but does not charge at all. I see in Windows 10 it shows the charging sign & AC power connected but stuck on 79%. I did a press-in switch reset at the botton of the laptop, but did not help. Checked the Voltage on the chip BQ24760RSBR, all seem to be fine. Battery voltages are ok 14.4v but on the battery coil L24, when AC is plugged in I only get 1.8V. Then...
                                  02-24-2023, 05:25 PM
                                • piernov
                                  Laptop battery charging circuit
                                  by piernov
                                  1. Some theory
                                  1.1. Introduction
                                  Almost every laptop has a charging circuit of some sort, that does a few things:
                                  • Manages switching between AC adapter and battery power
                                  • Manages battery charging and generates power rail to charge battery
                                  There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                  • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                  • Narrow VDC (NVDC)
                                  Texas instrument has a nice overview of these technologies with some more details at https:...
                                  11-15-2020, 01:31 PM
