Logic Board 820-01958-A no display
  • mferna14
    • Jun 2018
    • 1046
    Today I am working on Macbook Air A2179 2020 logic board # 820-01958-A. It turns on fine but no display. I see the amp meter taking amps from 0.14v to 0.18v (without the battery terminal attached). 20V is perfectly entering the motherboard. The CPU gets hot but no image at all. I am assuming it might be the backlight problem. Even I get ticks feels on the Trackpad. Lid volts 1.8 is all good too. Upon checking the backlight, I checked the 1st MOSFET Q8400, Pin 4 has 12v, this seems to be right but no output pins 1-2-5-6. Pin 3 which is LCDBKLT_EN_L also has 12v which is not right. On this pin it should be around 5.23v approx . I tried with another good LCD screen (just the glass), I use a torch behind, cannot seem to see anything. Any tips will be greatly appreciated. Thanks in advance
  • mon2
    • 14663
    Re: Logic Board 820-01958-A no display
    Caps key led toggles?
    • mferna14
      • Jun 2018
      • 1046
      mon2, thanks for the reply... First thing I observed this, NO caps LED. But I checked the voltages on all inductor coils, they are present. What you think., from where should I start?? I was thinking it's backlight problem, but this maybe not it., ENABLE even is missing on the backlight chip, all other voltages are present. PRAM senses as when I do it the display on the amp meter resets too. So I know this is working.
      • mferna14
        • Jun 2018
        • 1046
        Upon more trouble shooting I found that this rail PP3V3_G3SSW_SNS is missing, this is a TRUE 3.3V rail. It is generating from U8225. When checked U8225 (SLG5AP1445V). Pin # 2 is enable (SENSOR_PWR_EN coming from U7800 pin #152) & this pin should be getting some voltage like 1.8V ~ 3V but this pin is 0V & same with pin 7 (P3V3SEN_SS) out here too it's ZERO. Pin # 1 & 3 are correct 3.3.v (PP3V3_G3H). Can omeone could share their thoughts on this repair & check whether I am troubleshooting correctly. Thanks in advance.
        • anhbanxoi
          • Sep 2021
          • 180
          • VN
          CPU getting hot but does the fan spin? If yes, then you could check around U8500. I also got this board with the same problem but U8500 is shorted. After replaced U8500 I got display but no backlight. R8444/U8400 need to be replaced also to get the backlight.
          • mferna14
            • Jun 2018
            • 1046
            Hey "anhbanxoi", thanks for your reply. There is NO fan spin at all. Even after a PRAM reset, no Fan Spin. I checked U8500 (MOSFET) & R8444, seems to be ok. & I think backlight circuit might be working, U8400 is not even getting the ENABLE signal at Pn 17 of this chip. The Caps Lock LED even does not light up & no Fan spin but I can feel that the trackpad is creating that ticking feel. Any more tips will be much appreciated. Thanks
            • anhbanxoi
              • Sep 2021
              • 180
              • VN
              Try restore with Apple Configurator in DFU mode then check if you get ALL_SYS_PWRGD signal.
              • mferna14
                • Jun 2018
                • 1046
                Thanks buddy... I am getting ALL_SYS_PWRGD signal 1.4V.. Think this voltage is ok or it should be 1.8V???
                • mon2
                  • 14663
                  That is low. It should be 1v8.
                  Check the voltage to ground of PP1V8_PRIM_PCH.
                  • mferna14
                    • Jun 2018
                    • 1046
                    Excatly 1.8V on L7701 coil. Voltage out here is perfect.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • ledbylight
                      M1 A2337 Macbook - No Display, likely due to logic board
                      by ledbylight
                      Hi all!
                      This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                      I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                      11-04-2024, 06:36 PM
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                    • ohren
                      Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                      by ohren
                      I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                      I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                      The models launched in 2018 and 2019 respectively....
                      09-08-2023, 05:24 PM
                    • Yanleb
                      LG 60PK550 Logic Control Board EBR63450301
                      by Yanleb
                      Hi all, I just want to share the repair of my 60PK550-UA TV set.
                      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                      C57: 3.30V
                      C61:...
                      07-20-2023, 12:38 AM
