Asus GL503VD Not charging or powering on
  • Jasonexe
    • Apr 2023
    • 69
    • Belgium
    Hi, anyone that could help me? My asus GL503VD Suddenly turned off one day. My laptop doesn't turn on, when i try to turn it on with the charger plugged in nothing happens. Also the led indicators don't light up. I tried disconnecting the battery and plug the charger in and same issue persists. I noticed that the motherboard makes a small clicking sound when the charger is plugged in but that's it.. i got the tools to measure resistance etc.. so if anyone could help it would be really appreciated.
  • mon2
    • Dec 2019
    • 13995
    Hi. Start with the dcin connector.
    Meter in DC 30v or higher setting.
    Measure the voltage to ground of DCin connector. You should have ~19v. Confirm it.
    Red meter probe at the dcin connector; black to ground - shield is ok.
    Them locate the 8 pin mosfets that will follow. Mosfets are electronic switches that must enable to power the logic board.
    Post the topside markings of these mosfets. Great if you can post pics of the area.
    Often, the 2nd dcin mosfet gets damaged. To be determined.
    • Jasonexe
      • Apr 2023
      • 69
      • Belgium
      Re: Asus GL503V does not power on battery
      I measured the voltage when i plug the charger in and I’m getting 0.44V.
      the Mosfets that are used are the TPCA 8059-H.
      • mon2
        • Dec 2019
        • 13995
        Re: Asus GL503VD Not charging or powering on
        These are N-channel mosfets so the GATE pin has to be higher than the voltage being passed between source / drain pins.
        Measure the voltage to ground of each pin of each mosfet.
        source (1-2-3)
        gate (4)
        drain (5-6-7-8)
        https://www.arrow.com/en/products/tp...hl1q-m/toshiba
        Continue to review the logic board for the battery charger IC on this board. The gate pins of these mosfets is being driven by the charger IC. It is possible that the charger IC is the 'BQ' series from TI.
        • Jasonexe
          • Apr 2023
          • 69
          • Belgium
          source (1-2-3)
          gate (4)
          drain (5-6-7-8)
          Okay, this are the voltages i got.
          Left Mosfet:
          Source: 0.37v
          Gate: 0.37v
          Drain: 0.00v
          Right Mosfet:
          Source: 0.37v
          Gate: 0.37v
          Drain: 0.37v
          I forgot to mention that the battery charger IC the BQ24780S
          • Stevedb
            Stevedb
            • Feb 2018
            • 624
            • Belgium
            I do not think that are the in rush mosfet the first and second mosfet the red corner. I think they are on the otherside of the board
            • mon2
              • Dec 2019
              • 13995
              Ditto. Locate the DCin power adapter connector and then locate the mosfets close to the charger IC.
              If there is a fuse, check if the fuse is receiving power from the adapter.
              These mosfets are not being powered.
              • Jasonexe
                • Apr 2023
                • 69
                • Belgium
                I checked the fuse close to the dc jack connector and im getting 0.40v. I also checked the fuse close to the battery charger ic and i get no voltage reading. I also noticed that the laptop charger outputs 0.40v once i plug it in the motherboard. When i plug it out the voltage stays the same. The only way to make it output 19.7 volts again is by replugging it in the wall socket. I got 2 adapters so im sure that my adapter is not the problem.
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Obviously you have a shorted main power line then, check the resistance to ground at that line.
                  Become a Badcaps supporter
                  Thanks to all supporters.​
                  • Jasonexe
                    • Apr 2023
                    • 69
                    • Belgium
                    I checked the resistance and i’m getting 41.5K Ohms when i measure the positive and negative pin from the motherboard dc jack.
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      I checked the resistance and i'm getting 41.5K Ohms when i measure the positive and negative pin from the motherboard dc jack.
                      DC in jack is before the first two mosfets, measure the resistance after the mosfets. The short is after the mosfets!
                      • Jasonexe
                        • Apr 2023
                        • 69
                        • Belgium
                        Okay, I measured both mosfets. I set my multimeter to 200K for measuring resistance. This are the measurements i got.
                        Left Mosfet:
                        Pin 1-2-3 (Source): 52.8K Ohms
                        Pin 4 (Gate): 52.8K Ohms
                        Pin 5-6-7-8 (Drain): 0.6 Ohms
                        Right Mosfet:
                        Pin 5-6-7-8 (Drain): 52.8K Ohms
                        • Vesko356
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          Left Mosfet:
                          Right Mosfet:
                          Exactly as I told you, 0.6 Ohms is a dead short. Now you must find what is shorting your main power line.
                          • Jasonexe
                            • Apr 2023
                            • 69
                            • Belgium
                            I checked the schematic of this laptop with boardview and i see that the drain from the left mosfet is connected to a other mosfet close to the battery charger IC. I removed the left mosfet but still had the short. After that i also decided to remove the one close to the battey charger IC but still the same problem, (i marked it with a red cross). You can see in the attachment that there are other components that are connected to it. I'm not sure which one i should check next.
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              There is no point in removing components this way, this is your main power rail and the short could be anywhere. Look carefully around the entire board for a component that is darkened or visually different from normal, it is most likely a ceramic capacitor. If you find nothing, the only way out is to inject 1 volt/2 amps and see for a heating component with a thermal camera or if you don't have one just feel with your fingers what is heating up.
                              • Jasonexe
                                • Apr 2023
                                • 69
                                • Belgium
                                I will take a look, if i want to inject voltage. From where can i do it ? I don't want to kill the motherboard.
                                • mon2
                                  • Dec 2019
                                  • 13995
                                  If you truly have a 0.6 ohms resistance to ground, injecting with 1v (NOT higher!), then the defective part will heat up and pop or crack like a pimple. (Ok, I am grossed out by that as well).
                                  Often caps that will split and you can smell it once they. Have seen tantalum caps do this as well as ceramic.
                                  You will inject the voltage at the mosfet pin that reads this low resistance to ground.
                                  Red DC power supply pin there, black to ground. Do not go higher than 1 volt - just in case this rail is directly reaching the CPU but if it is, then the CPU is likely already dead.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    At any point of the power rail, but in order not to do something stupid, it's best to be let's say after the second mosfet, exactly where you measured 0.6 ohms.
                                    • Jasonexe
                                      • Apr 2023
                                      • 69
                                      • Belgium
                                      i tried injecting 1v but i didn't feel any components getting hot. When i try measure the voltage where the short is while injecting it drops to 0.080v
                                      • mon2
                                        • Dec 2019
                                        • 13995
                                        How much current was consumed?
                                        Is the CPU with a heat sink?
                                        • flat-earther
                                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                                          by flat-earther
                                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                          Windows also shows ''Plugged in'' when charger is not connected.
                                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                          If I let battery run out and say it has 3% Windows will...
                                          06-24-2025, 09:32 AM
                                          ASUS ROG GL503VD-FY260T Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL503VD-FY260T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-FY260T boardview and GL503VD-FY260T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 02:34 PM
                                          ASUS ROG GL503VD-E4136T Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL503VD-E4136T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-E4136T boardview and GL503VD-E4136T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 02:30 PM
                                          ASUS ROG GL503VD-DB71 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL503VD-DB71 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB71 boardview and GL503VD-DB71 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 06:00 AM
                                          ASUS ROG GL503VD-DB74 Notebook Strix Specification for Upgrade or Repair
                                          This specification for the ASUS ROG GL503VD-DB74 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL503VD-DB74 boardview and GL503VD-DB74 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
