Hp la-e841p battery plugin but not increase
  • SR IT SOLUTION
    • Jan 2023
    • 61
    • INDIA
    hi, i have hp CTL51/53 LA-E841P REV 2.0
    the problem is battery plugin but charging % not increased i already replaced battery but the problem still same. any one help !!!
  • mon2
    • Dec 2019
    • 13829
    Re: Hp la-e841p battery plugin but not increase
    Measure the voltage to ground of each pin on the battery connector. Post the measurements.
    If the smbus lines are shorted (SCL or SDA) due to an ESD transient, then this fault can occur.
    • SR IT SOLUTION
      • Jan 2023
      • 61
      • INDIA
      connector voltage with out insert battery /insert battery
      pin1-0 /0v
      pin-2--0/0v
      pin-3---3.2v/0v
      pin-4 --0v/
      pin-5---3.2v/3.2v
      pin-6----3.2v/3.2v
      pin-7----0.4/2.2v
      pin-8---0v/0v
      • kalilinux25
        • Mar 2018
        • 2069
        • ZAMBOANGA SIBUGAY
        pin1-0 /0v
        pin-2--0/0v
        pin-3---3.2v/0v
        pin-4 --0v/
        pin-5---3.2v/3.2v
        pin-6----3.2v/3.2v
        pin-7----0.4/2.2v
        pin-8---0v/0v
        schematic
        https://www.badcaps.net/forum/showth...t=88185&page=2
        Last edited by Vesko356; 04-14-2023, 03:05 AM. Reason: Attached schematic removed and replaced with the link
        • mon2
          • Dec 2019
          • 13829
          Thanks for the schematic.
          Does Windows report the battery is connected or disconnected if removed?
          Attach the battery and power adapter.
          Carefully measure the voltage to ground of each pin on the charger IC (PUB1).
          Post the readings with the pin numbers.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            pin1-0 /0v
            pin-2--0/0v
            pin-3---3.2v/0v
            pin-4 --0v/
            pin-5---3.2v/3.2v
            pin-6----3.2v/3.2v
            pin-7----0.4/2.2v
            pin-8---0v/0v
            Dead battery. No voltage on battery output pins.
            • Stevedb
              Stevedb
              • Feb 2018
              • 622
              • Belgium
              Which charging ic do you have what are the voltages on the charging ic.
              • SR IT SOLUTION
                • Jan 2023
                • 61
                • INDIA
                i replace the charging ic bq25a
                now problem solved
                thanku so much everyone!!!
