Charging current for HP ENVY 15m-dr0011dx laptop
  • survivalbloke
    • Aug 2021
    • 307
    I've got a 15" ENVY laptop here, model 15m-dr0011dx. The customer complained that the power adapter was getting really hot and that it seemed like the battery would deplete quickly - like it would go from 35% to nothing, very fast. I tested this battery (SA04XL) on my NLBA Battery Analyzer and it passed all the test except charging cycles which were at 172 - and that doesn't seem high to me. I was thinking maybe this battery had high internal resistance, but all cells were reported at 108ohm, balanced across the board.
    I connected my power supply to it(lid closed) with 19.5v 4a setting, and initially it was drawing 400ma. after a few seconds, it jumped up to 2 amps. That seems awfully high to me. I thought charging current was generally under 1 amp.
    Any guidance from the laptop gods here?
    **ADDITIONAL INFO UPDATE** It goes from 456ma to 2.1a exactly 10 seconds after power is connected. I also replaced the battery and found the same numbers.
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    Re: Charging current for HP ENVY 15m-dr0011dx laptop
    It is normal the current goes over 2a when it is charging.
    maybe you must calibrate the battery.
    Greeting
    • survivalbloke
      • Aug 2021
      • 307
      Greeting
      Thanks!
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        It differs from model to model as battery specs/charging IC specs varies between models. However, i've seen abnormal current draw(though it charges fine) due to bad charging IC. Very recently, i had a HP15-BS model with LA-E801P motherboard where current draw in off condition was 2.92A and it was charging fine but was heating alot around charging area. After replacing BQ25A controller, current draw in off condition is 1.2A. So there is no definite answer to your query .
        • survivalbloke
          • Aug 2021
          • 307
          Thank you for sharing that experience!
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
            Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
            The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
            The bq24745 features dynamic power management...
            10-23-2024, 02:50 AM
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • ahmarzo
            Hp laptop charging problem
            by ahmarzo
            Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
            Charging ic is bq737 with voltages on pin no
            1&2 -19v
            34&5 -0v
            6 -2.56 v
            7- 0v
            8&9 -3.15v
            10 -0v
            11 -0.18v
            12 & 13 -13v
            14&15 -0v
            16 -6v
            17;18&19 -13v
            20 - 19v
            Voltages on battery connector are
            1&2. -13v
            3&4 -3.14 v
            5&6 -0v
            8&9 are ground...
            03-20-2025, 05:13 AM
          • julianmustofa
            Bat54cw make laptop not charging?
            by julianmustofa
            Hi all..
            long story short when i disassemble a laptop (asus gl504gs) for cleaning. I found some component deliberatelly removed from the board by unknown technician.
            turns out this component is a diode BAT54CW
            For a power protection circuit
            i installed this component and now laptop not charging anymore
            its detect the ac adapter but not charging the battery
            i removed the component again and know it start charging normaly
            i just curious why this happen, i mean it should be there from factory but why when i installed it and it make the laptop not charging?...
            10-12-2024, 07:24 PM
