MSI MS-16J9 - No power
  • tommy97
    • Mar 2023
    • 160
    Hello everyone, i have problem with MSI MS-16J9, board model: MS-16J91 Ver:1.0, in attachment you can find brd and schematics.
    19.5V 0AMP Draw, checked few main points (I'm not expert in laptop board repairs, your help would be appreciated).
    Power/charger light are missing, there is no reaction on power button. Tried BIOS reflash, no difference.
    What should i check next or before?
    PWR_SRC PC213 - 19.5
    PQ41 19.5 Only on pin 5 (Not shorted to the ground)
    TPS51225CRUKR_QFN20
    VBST2 (4.7V)
    LL2 +3VSUS (0V Missing)
    EN1 - MISSING
    EN2 - MISSING
    VERG5 5V (+5AVALW)
    VERG3 3.3V (+3VALW)
    VBST1 (0v) - CLOSE TO HIGH SIDE MOSFET PWR_SRC MISSING
    PQ6 - 19.5 / Leg 4 8.5v
    PQ8 - 19.5 / LEG 4 8.1V
    PC39 -19.5
    SDC_IN+ PRESENT
    Schematic - https://www.badcaps.net/forum/showthread.php?t=84710
  • Sephir0th
    • Oct 2020
    • 1283
    Re: MSI MS-16J9 - No power
    Check whether you have 3.3V at the PWR_SW# to start with.
    FairRepair on YouTube
    • tommy97
      • Mar 2023
      • 160
      Sorted, that was problem with KBC.
      • mon2
        • 14390
        problem with KBC.
        Can you post more details? It will be appreciated by future readers.
        • madjid911
          • 399
          • France
          I have the same laptop, no power, I found u29 in shorts, after removing the u29 chip, I have no more shorts and I find the 3V 5V. can you tell me what this chip is for? on the motherboard it says E2500, but on the diagram it says E2400, which one should I order please?
          https://fr.aliexpress.com/item/40008...d=JgeSaJpXfLs7
          https://fr.aliexpress.com/item/10050...970014161410_2
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • reessi
            HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
            by reessi
            I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
            It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
            What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
            I have checked these lines in diode mode and they seam normal -> 600.
            I have checked to see if they come on for even a fraction of a second...
            07-15-2025, 09:14 AM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
            03-31-2024, 02:12 PM
