Huawei Magicbook m/b DAH98AMBAD0, dead
  • DrFalken
    • May 2008
    • 122
    Just arrived a Magicbook with m/b DAH98AMBAD0 completely dead, power LED stay OFF.
    Checking with thermal camera I see a chip labeled 4GA "pulsating".
    4GA code point me to "FT521GAb"="LDO, Dual out, Vout1/Vout2=2.8V/1.2V±2%, 250mA, +CE"
    Maybe something is shorting it ?
    What can I check ?
    Can't find it on the attached schematics - https://www.badcaps.net/forum/troubl...c-or-boardview
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: Huawei Magicbook m/b DAH98AMBAD0, dead
    What can I check ?
    Can't find it on the attached schematics.
    what is the voltages of the pins, after check the resistance of eveery pin
    • DrFalken
      • May 2008
      • 122
      Voltages of nearby components fluctuate when fed from the original power supply.
      I've also tried another power supply...same behavior.
      This morning I've injected up to 4.5V (starting at 1V@1A) on the main power rail (this laptop is powered by a USB Type-C) and starting from 4V this chip immediately overheats on the thermal imager.
      So I've removed this "4GA" part and I'm looking for the datasheet to find a replacement
      Note: The voltages do not fluctuate with the bench power supply.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        better try to change it already
        • DrFalken
          • May 2008
          • 122
          Found !
          4G(A) = RT1711H Programmable USB Type-C PD Controller
          • mon2
            • Dec 2019
            • 14320
            Excellent find.
            • matheus30
              • Apr 2016
              • 27
              • spain
              Found !
              I have the same problem, Did it work for you when you changed it?
              https://www.badcaps.net/forum/troubl...BA-celsius-hot
              My board is HUAWEI Matebook D15 Laptop - Mod: BOB-WAH9 - Motherboard: DAH98MMB8D0 REV D , but I think that is the same IC
              The last letter 4GA -> 4G"D" is date packaging
              • DrFalken
                • May 2008
                • 122
                Sorry can't help 😥
                If I remember correctly, the customer took the laptop back without repairing it
                • Cecilius
                  Huawei Matebook D15 - DAH98AMBAD0 Rev.:D dead
                  by Cecilius
                  Hi, I just come to this laptop with symptoms from owner - it stop charging. Thought it would be easy USB-C replacement (matebooks known issue) I took it. But port is good. After charging battery from power supply laptop is still dead. No power to EC chip. I'm out of ideas what to check next.
                  Next to 3.3V LDO which is only active rail after main rail is a circuit which sends voltage to EC chip. I don't understand at all function of this circuit. It consist of 2 PNP transistors few resistors and P-channel mosfet. Below is a circuit diagram of that part with explanation. Does anybody...
                  02-19-2025, 07:52 AM
                • DrFalken
                  Honor MagicBook X 16 mod. BRN-F56 dead
                  by DrFalken
                  Good morning!
                  A customer just brought in an Honor MagicBook X 16 mod. BRN-F56, motherboard P/N Fermi_MB NB6269A_MB_V4, not working (no power LED, no charging LED, nothing)
                  He said he had been using an aftermarket power supply for a while, but noticed that it suddenly stopped charging and when the battery was completely dead the laptop would not turn on, even with the original (working) power supply.
                  On the power connector, on the motherboard side, I measure 20V.
                  With the thermal imaging camera I found a component labeled 2920J (TSOP5) that, when I supply power, increases...
                  01-29-2025, 03:41 AM
                • Raygen
                  No VCC to bios chip - Huawei Matebook d15 DAH98AMBAD0 REV:D HF Model H98A H898A
                  by Raygen
                  Hello, I received to repair this Huawei laptop (model in the title).
                  The laptop will charge the battery fine throught the USB C port, but it wont turn on. The charging led will blink fast and repeatedly when trying to turn it on.
                  I've attached photos of the board. (the wires are for briging the power button, I did not inject voltage)
                  Upon visual inspection, a couple of ICs were blown. Along the 5V line leading to one of the USB A ports. They wasnt fully shorted but just a couple of ohms to ground.
                  I replaced the blown IC on the board (the one circled in red,...
                  09-23-2024, 04:21 PM
                • fanaticgames
                  DAH98AMBAD0 Rev D Huawei Matebook No charge need schematic or boardview
                  by fanaticgames
                  can someone help me? i need schematics or boardview for DAH98AMBAD0 Rev D motherboard Huawei Matebook
                  03-27-2023, 07:00 AM
                • Yolofolkss
                  Huawei D14 dah98ambad0 rev d please help identify Missing components
                  by Yolofolkss
                  Hello I just bought this laptop to be used personally (that I'm currently trying to repair.), I am aware that liquid (gravy) has been spilled in this area before. but there are missing components it it possible to have a board view or a schematic of this? or just an idea on what components its missing?
                  as far as I know this parts are connected as sense or enable.... that's how far I know...
                  Images attached:
                  the picture of the area. and some of the pinouts that I noticed on the chip...
                  03-26-2023, 12:37 AM
