A1706 (820-00923-A) Stuck on 5V/30ma
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey, working on an A1706 that doesn't power on anymore.
    The usb-c amp meter reads 5V/30A. On the right side (XA & XB) the meter loops (on/off), on the left side it stays on. This might indicate something U2890 related?
    PP3V3_G3H is present and stable, PPBUS_G3H sits at 50mv.
    Any advice? Thanx in advance!
  • mon2
    • Dec 2019
    • 14187
    Re: A1706 (820-00923-A) Stuck on 5V/30ma
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of PPBUS_G3H.
    Post your measurement.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      Hey mon!
      0.450 on pad 2 of the fuse, F7000
      • Jenzo
        • Jul 2019
        • 135
        • Belgium
        My bad, just noticed you said resistance mode.
        Black probe on ground, 40.6k
        • mon2
          • Dec 2019
          • 14187
          The PPBUS_G3H resistance is not showing a short circuit. Both resistance and diode readings are fine.
          Clue is here:
          The CD3215 needs to be investigated. Each LDO rail on the ACE (CD3215) controllers needs to be checked.
          This video details the same case as yours:
          https://www.youtube.com/watch?v=vXAK2l1oMZM
          Summary - the local ROM chip that is used by the non-working pair of CD3215 may be defective. Confirm no parts on this ROM chip are missing. If you are comfortable, swap the ROM from the working side to the non-working side to see if this fixes the fault. Lots of flux + low air pressure to carefully remove the ROM chip.
          Yes.
          • Jenzo
            • Jul 2019
            • 135
            • Belgium
            As far as I can tell no shorts indeed, nothing gets hot either.
            The LDO lines seem to be fine.
            Nothing is missing around the U2890 either.
            The video you linked is actually exactly the same case, amazing. I'm fine with swapping the ROM chip (U2890), is this the UB090 on the other side? Just making sure
            Also, I'm having trouble locating a replacement chip, any advice on this? Thanx for everything so far!
            • mon2
              • Dec 2019
              • 14187
              The exact chip is in stock at Digikey. The trick will be finding an adapter to program this part.
              This package is the USON 2*3 mm size. Not very common.
              There are bare pcbs you can buy on AliExpress for around $22 usd that note T2 adapter boards and are black in color.
              With this board, you can solder in a blank flash chip and convert it to pdip for use with your programmer.
              This flash is 3v3 version so no low voltage conversion is required.
              The trick is in the very small package for programming.
              The dump of this tbt rom I believe can be found in the bios section of this forum.
              Suggest to buy a few of the blank chips. They are cheap on Digikey.
              Reference:
              W25Q80DVUXIE
              • Jenzo
                • Jul 2019
                • 135
                • Belgium
                Additional question, now the customer tells me the problem started with the screen showing horizontal lines. I'm looking at the schematic, but I can't figure out if it could be related in any way. Should I assume it's the flexgate issue, and then followed by the ROM chip going bad? Seems like very bad luck to me then. :')
                • mon2
                  • Dec 2019
                  • 14187
                  https://www.fixxo.in/blog/macbook-pr...016-2017-model
                  • Jenzo
                    • Jul 2019
                    • 135
                    • Belgium
                    Unlucky it happened so shortly after each other. It is what it is I guess.
                    • mon2
                      • Dec 2019
                      • 14187
                      Customer is blaming you for this design flaw??
                      Show them the above link. Offer them perhaps a discounted labor rate to swap out the display but is certainly not related to your work. That is just abuse by your customer wanting a free lunch.
                      • Jenzo
                        • Jul 2019
                        • 135
                        • Belgium
                        Hey, sorry didn't see your last reply. The customer doesn't want to pin any display issues on me at all thank god, he was just kindly giving more info about what happened because he brought it in for "no power", but forgot to mention at first that a bit before it happened he had issues with the display.
                        By now I've replaced the UB090. It solved the looping/charging problem, but then a new problem came up. U8205 heated up, removed it and measured, PP3V3_S0 is shorted to ground. I tried injecting 1V/2.5A, but nothing gets hot really.
                        Any ideas?
                        • mon2
                          • Dec 2019
                          • 14187
                          If not done already, remove the display and remove the trackpad.
                          Remove all power -> meter in lowest resistance mode.
                          Measure the resistance to ground of PP3V3_S0 again.
                          Post the measurement.
                          • Jenzo
                            • Jul 2019
                            • 135
                            • Belgium
                            Sorry for wasting your time with the last part, right after posting I found a piece of solder in the trackpad connector shorting it out, once removed all is working fine. Only costed me 2h of my life! Sadly the display is damaged after all, but not related to this repair, client is now deciding if the wants a new display or not. Thank you for the help, this was a really cool repair!
                            • mon2
                              • Dec 2019
                              • 14187
                              Very nice. We were on the right track(pad)
                              • Junior†
                                Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
                                by Junior†
                                I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
                                here are my measurements/observations
                                with battery/fan connected (connected to 65W charger):
                                top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
                                bottom USBC port: 20V (80ma for a split second then goes to zero)
                                without battery, fan is still connected:
                                top USBC port: 4.950V (starts at ~75ma, then settles at 30ma)...
                                01-18-2024, 03:43 PM
                              • Steven Pieter
                                Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                by Steven Pieter
                                hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                11-24-2024, 10:02 AM
                              • chth96
                                Is it possible to test small ceramic disc capacitor with analogue meter?
                                by chth96
                                I read EBOOK of Testing Electronic Component and found that
                                "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                Is it really possible to test small ceramic disc capacitor with analogue...
                                03-09-2024, 10:03 PM
                              • BMCappelletti
                                MacBook Pro A1706 - Stuck at 5V and 0.09A
                                by BMCappelletti
                                Hi everyone.
                                MacBook Pro, model A1706, EMC 3071. Charger shows only 5V and only 0.09A drawn. Board is 820-0239-A. Mint condition. Pretty sure no one ever opened it and was not used much.
                                I tested all steps from the table here https://logi.wiki/index.php/CD3215_Bootup_Sequence changing the CD3215 lines as I moved from one USB-C to the other.
                                What I found was:
                                - on step 3, I have the voltages as 10V and 7.8V, indicated as "Air" on this table, which I suppose would be for a MacBook Air. But this one is a Pro. Same on all DC3215s.
                                - on step 11, on diode mode,...
                                02-10-2024, 02:07 PM
                              • stormanimal83
                                Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                by stormanimal83
                                Hey....
                                Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                01-18-2024, 02:15 PM
