A1706 (820-00923-A) Stuck on 5V/30ma
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey, working on an A1706 that doesn't power on anymore.
    The usb-c amp meter reads 5V/30A. On the right side (XA & XB) the meter loops (on/off), on the left side it stays on. This might indicate something U2890 related?
    PP3V3_G3H is present and stable, PPBUS_G3H sits at 50mv.
    Any advice? Thanx in advance!
  • mon2
    • 14659
    Re: A1706 (820-00923-A) Stuck on 5V/30ma
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of PPBUS_G3H.
    Post your measurement.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      Hey mon!
      0.450 on pad 2 of the fuse, F7000
      • Jenzo
        • Jul 2019
        • 135
        • Belgium
        My bad, just noticed you said resistance mode.
        Black probe on ground, 40.6k
        • mon2
          • 14659
          The PPBUS_G3H resistance is not showing a short circuit. Both resistance and diode readings are fine.
          Clue is here:
          The CD3215 needs to be investigated. Each LDO rail on the ACE (CD3215) controllers needs to be checked.
          This video details the same case as yours:
          https://www.youtube.com/watch?v=vXAK2l1oMZM
          Summary - the local ROM chip that is used by the non-working pair of CD3215 may be defective. Confirm no parts on this ROM chip are missing. If you are comfortable, swap the ROM from the working side to the non-working side to see if this fixes the fault. Lots of flux + low air pressure to carefully remove the ROM chip.
          Yes.
          • Jenzo
            • Jul 2019
            • 135
            • Belgium
            As far as I can tell no shorts indeed, nothing gets hot either.
            The LDO lines seem to be fine.
            Nothing is missing around the U2890 either.
            The video you linked is actually exactly the same case, amazing. I'm fine with swapping the ROM chip (U2890), is this the UB090 on the other side? Just making sure
            Also, I'm having trouble locating a replacement chip, any advice on this? Thanx for everything so far!
            • mon2
              • 14659
              The exact chip is in stock at Digikey. The trick will be finding an adapter to program this part.
              This package is the USON 2*3 mm size. Not very common.
              There are bare pcbs you can buy on AliExpress for around $22 usd that note T2 adapter boards and are black in color.
              With this board, you can solder in a blank flash chip and convert it to pdip for use with your programmer.
              This flash is 3v3 version so no low voltage conversion is required.
              The trick is in the very small package for programming.
              The dump of this tbt rom I believe can be found in the bios section of this forum.
              Suggest to buy a few of the blank chips. They are cheap on Digikey.
              Reference:
              W25Q80DVUXIE
              • Jenzo
                • Jul 2019
                • 135
                • Belgium
                Additional question, now the customer tells me the problem started with the screen showing horizontal lines. I'm looking at the schematic, but I can't figure out if it could be related in any way. Should I assume it's the flexgate issue, and then followed by the ROM chip going bad? Seems like very bad luck to me then. :')
                • mon2
                  • 14659
                  https://www.fixxo.in/blog/macbook-pr...016-2017-model
                  • Jenzo
                    • Jul 2019
                    • 135
                    • Belgium
                    Unlucky it happened so shortly after each other. It is what it is I guess.
                    • mon2
                      • 14659
                      Customer is blaming you for this design flaw??
                      Show them the above link. Offer them perhaps a discounted labor rate to swap out the display but is certainly not related to your work. That is just abuse by your customer wanting a free lunch.
                      • Jenzo
                        • Jul 2019
                        • 135
                        • Belgium
                        Hey, sorry didn't see your last reply. The customer doesn't want to pin any display issues on me at all thank god, he was just kindly giving more info about what happened because he brought it in for "no power", but forgot to mention at first that a bit before it happened he had issues with the display.
                        By now I've replaced the UB090. It solved the looping/charging problem, but then a new problem came up. U8205 heated up, removed it and measured, PP3V3_S0 is shorted to ground. I tried injecting 1V/2.5A, but nothing gets hot really.
                        Any ideas?
                        • mon2
                          • 14659
                          If not done already, remove the display and remove the trackpad.
                          Remove all power -> meter in lowest resistance mode.
                          Measure the resistance to ground of PP3V3_S0 again.
                          Post the measurement.
                          • Jenzo
                            • Jul 2019
                            • 135
                            • Belgium
                            Sorry for wasting your time with the last part, right after posting I found a piece of solder in the trackpad connector shorting it out, once removed all is working fine. Only costed me 2h of my life! Sadly the display is damaged after all, but not related to this repair, client is now deciding if the wants a new display or not. Thank you for the help, this was a really cool repair!
                            • mon2
                              • 14659
                              Very nice. We were on the right track(pad)
                              • ferrc95
                                A2338 820-02020 Stuck at 5V, meter resets
                                by ferrc95
                                The board arrived very clean, with no traces of moisture or corrosion.
                                Initially, a part of one of the CD3217B12s was heating up, so I purchased a new CD3217B12, which wasn't specified in the purchase announcement as being compatible with the A2338. The short circuit disappeared, but it was still stuck at 5V. So I decided to buy another CD3217B12 specific to my model, but after replacing it, it remained the same.
                                PPBUS_AON is 12.3V. Before the reset, it drops to 12V, remains there for a few seconds, and then drops until it restarts.
                                The USB power meter shows...
                                10-17-2025, 07:31 AM
                              • Junior†
                                Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
                                by Junior†
                                I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
                                here are my measurements/observations
                                with battery/fan connected (connected to 65W charger):
                                top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
                                bottom USBC port: 20V (80ma for a split second then goes to zero)
                                without battery, fan is still connected:
                                top USBC port: 4.950V (starts at ~75ma, then settles at 30ma)...
                                01-18-2024, 03:43 PM
                              • Steven Pieter
                                Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                by Steven Pieter
                                hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                11-24-2024, 10:02 AM
                              • Stunt
                                Hp Laptop Stuck on Hp protected by hp sure start screen
                                by Stunt
                                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                screen that's it and stuck there. I left it until the following day and i still...
                                09-02-2025, 01:51 PM
                              • chth96
                                by chth96
                                03-09-2024, 10:03 PM
