A2338 820-02020 Stuck at 5V, meter resets
  • ferrc95
    • Mar 2023
    • España
    The board arrived very clean, with no traces of moisture or corrosion.
    Initially, a part of one of the CD3217B12s was heating up, so I purchased a new CD3217B12, which wasn't specified in the purchase announcement as being compatible with the A2338. The short circuit disappeared, but it was still stuck at 5V. So I decided to buy another CD3217B12 specific to my model, but after replacing it, it remained the same.
    PPBUS_AON is 12.3V. Before the reset, it drops to 12V, remains there for a few seconds, and then drops until it restarts.
    The USB power meter shows a consumption of about 177 mAh, which gradually decreases to zero and then restarts, then restarts again.
  • ferrc95
    • Mar 2023
    • España
    Up
    • mon2
      • 14659
      Do not have access to my schematics and am out of the office till next week- check if there is a fuse on PPBUS_AON. Flux and remove this fuse. Then power up again. Test if this power rail is still power cycling at the producer side (before the fuse).
      • ferrc95
        • Mar 2023
        • España
        Hi, thanks for responding. Yes, I did the fuse removal test a few days ago and the voltage remains constant at 12.3V without resetting.
        • mon2
          • 14659
          Measure the resistance to ground of each inductor on the board. You are on the hunt for any power rail that may have a lower than normal resistance that will denote a shorted part on that rail. List all suspects. Downstream power rails are built by using this ppbus_aon rail as the high side of the next lower voltage rail. Each is a suspect.
          • ferrc95
            • Mar 2023
            • España
            Hi again, I attach the resistance measurements of all the inductors.
            • lab10.haifa
              Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
              by lab10.haifa
              Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
              It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
              There is no damage on the motherboard. No short circuits.
              Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
              Thanks....
              10-08-2025, 02:55 AM
            • iMuhtaseb
              820-02020 (A2338) stuck @ 5v 0.11amps
              by iMuhtaseb
              board came with liquid damage and prior work on SoC PMU (U8100) with short on PP3v8_AON..
              it had corroded caps around U8100, all removed and U8100 replaced successfully.. short removed..
              Board is still stuck 5v 0.11 amps.. I have returned all the missing caps around U8100 thinking maybe they're necessary but sadly no fix.
              PPBUS 12.33v
              PP3v8_AON 3.8v
              PPV5_S2 not present, no short
              PP3v3_S2 not present, no short
              PP1v8_S2 not present, no short..
              I've taken diode and short measurements around all coils for U8100 they were...
              10-16-2024, 06:39 AM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • Instafixx
              Macbook A2338 Amp Meter Reboots
              by Instafixx
              Namaste.
              I have a Macbook A2338 that came in for turning on issue. It turned on once when i had it but then again went off. The amp meter but bootloop. The board was clean - no dust - no green .
              I performed a DFU Revive. Got the error 4042. Assumed BAD SSD. But it turned on , worked well for 1 day and again went off.
              Anything can be done ?The customer needs data
              09-27-2023, 02:25 AM
            • chth96
              by chth96
              03-09-2024, 10:03 PM
