TUF505DT : No charge
  • kurtspirit
    • Feb 2019
    • 112
    • France
    #41
    Re: TUF505DT : No charge
    I just check again and it about 168kohm ~
    • mon2
      • Dec 2019
      • 14666
      This is an Asus? So no schematics are available?
      This part is not the correct value.
      Can you post a clear pic of this part?
      Then we can seek out a replacement.
      • mon2
        • Dec 2019
        • 14666
        Asus will have followed the recommendations by TI for the charger IC.
        Respectively, see attached. Very likely that the original current sense resistor was of the same value @ 10mOhms = 10 milli-ohms.
        This resistor is now defective based on the measurements posted earlier.
        If possible, take measurements of body size of this part and then we can try to hunt down a replacement.
        • kurtspirit
          • Feb 2019
          • 112
          • France
          #44
          Here is a picture from the zone. The two red marks are points where i find the measurement. If i follow the datasheet, ACN and ACP are 1 and 2 on the BQ.
          https://ibb.co/8BfmRFy
          And here is a picture from the zone. To be honest, i don't find the resistor. I don't find a boardview file for this board... Thank you really much for your help
          https://ibb.co/Rc9DHhv
          And i just find something on the other side of the board : I found a completely cut track on the other side of the map. I can fix it but I'm not sure if it's relevant. If a component caused this break, I wouldn't want to pry with a wire and cause a big, widespread short.
          What do you think ?
          Edit : after test, the two tracks are in permanent contact. Is this normal? I don't know but could this be one of the reasons for the problem?
          https://ibb.co/GvZ66vF
          • mon2
            • Dec 2019
            • 14666
            The trace under the label you show does appear to be cut. Use a meter in the lowest scale and measure from the very top of the trace with the exposed copper to the start of the trace near the label.
            Then measure the resistance again between acn and ACP pins. It should be a very low resistance.
            The reading should be ~0 ohms. Confirm it.
            If it is not, use a piece of wire to bridge the broken trace.
            Then power up again and post the voltage to ground of ACN and then ACP.
            • kurtspirit
              • Feb 2019
              • 112
              • France
              #46
              The problem is that the two traces side by side are in contact... I'm not sure that's normal
              https://ibb.co/4YPkwmF
              • mon2
                • Dec 2019
                • 14666
                Hello.
                1) post the pics only on this forum. Otherwise the links expire and this thread will be of no value.
                2) yes the traces will appear shorted because of the low resistance current sense resistor.
                3) focus only on the right side trace. Meter at start and meter at end of the right track. What is the resistance? You have exposed copper test points. The pic shows the trace to be broken. It must be fixed. Also the hole in the middle of this same right trace..is that hole broken? If yes then someone else is not connected due to the broken hole. This hole is called a PCB via. This via is used to take the connection from this side to the opposite side of the PCB.
                • kurtspirit
                  • Feb 2019
                  • 112
                  • France
                  #48
                  The trace is clearly cut. I'll put a wire instead.
                  For the pics, i'm sorry but when i use the link from forum , pictures doesn't appear in the message...
                  • kurtspirit
                    • Feb 2019
                    • 112
                    • France
                    #49
                    Ok mon2, now the resistance is about 0.01ohm. Maybe i have to test with battery ?
                    • mon2
                      • Dec 2019
                      • 14666
                      Good. Now test again.
                      • kurtspirit
                        • Feb 2019
                        • 112
                        • France
                        #51
                        How to thank you?!
                        The PC is finally charging! I'm so grateful, I never thought I'd get there. It's awesome ! I'm really happy and thank you ten thousand times
                        • mon2
                          • Dec 2019
                          • 14666
                          Well done. Kudos to @Piernov for spotting the large voltage drop. I saw it as well but did not think at the time, the drop was that large of a delta. It is great that you located the cut trace. That is true teamwork!!
                          • mon2
                            • Dec 2019
                            • 14666
                            How to thank you?!
                            Donate to the forum. Trying to convince the webmaster to host on Amazon servers to prevent downtime.
                            • Sephir0th
                              • Oct 2020
                              • 1289
                              Very interesting. Just to have a idea what happened here lately. For me it turned out, it was "just" a cutted ACN or ACP rail, no? So luckily, the voltage drop was measured at the charging controller itself instead of at the CSR. Otherwise we were still clueless...?
                              FairRepair on YouTube
                              • kurtspirit
                                • Feb 2019
                                • 112
                                • France
                                #55
                                To be honest, I don't know.
                                I think a Mosfet (I changed them all) caused this broken line but that's really a guess...
                                The previous battery had suddenly stopped charging for no reason, that's when something happened but it will remain a mystery.
                                I changed in the end: battery, the 3 Mosfets, the charging IC, a diode.
                                Thank you very much to everyone anyway, it's a pure pleasure to see the PC working again!
                                • Astonished
                                  Fixing the Charge Circuit of the Batteries of the DC Motor
                                  by Astonished
                                  Hi friends of electronics
                                  What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                  The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                  Please help me fix this circuit.
                                  (the datasheet of the IC: https://pdf.datasheet.live/28...
                                  01-28-2025, 06:24 AM
                                • ipatch
                                  troubleshooting microsoft surface pro 4 no power no led charge light
                                  by ipatch
                                  hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                  10-05-2023, 11:59 AM
                                • dicky96
                                  HP Laptop TPN-C125 replacement batteries will not charge after 12 months
                                  by dicky96
                                  I got four replacement batteries for these HP laptops about a year ago. The originals would not charge, and these replacements have now gone the same way.
                                  I'm not sure what the expected life of a laptop battery is but I woud have thought they would last longer than that
                                  I now need to order four more batteries. Possibly these replacement ones were now good? The owner does not mind paying a bit more for originals or good compatible batteries that last longer
                                  The top one is the original
                                  Any ideas?
                                  Cheers...
                                  05-19-2021, 07:53 AM
                                • razenxd
                                  How can I charge that battery pack?
                                  by razenxd
                                  it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                  At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                  Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                  Now, I have noticed a few things.
                                  The "dead" battery, while connected to charger and NOT Charging will...
                                  12-05-2024, 06:11 AM
                                • howardc64
                                  Where do repair shops buy MB replacement batteries?
                                  by howardc64
                                  Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                  Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                  BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                  07-25-2024, 10:42 AM
