TUF505DT : No charge
  • Sephir0th
    • Oct 2020
    • 1282
    Re: TUF505DT : No charge
    Okay, so communication between board and batery is ok.
    Although 25V at ACDRV looks fine, I guess it doesn't harm to check the DC-IN Mosfets in addition for internal short.
    FairRepair on YouTube
    • kurtspirit
      • Feb 2019
      • 112
      • France
      I try to find what happened but to be honest, i follow what mon2 and you telI am what mon2 and you tell me. I'm not too electronically savvy.
      Anyway, the mosfets seem ok, which bothers me even more... Could the IC I changed, the BQ24780S, be out of order?
      • Sephir0th
        • Oct 2020
        • 1282
        "The mosfets seems okay" -->> You mean the DC-IN mosfets or the other three mosfets mentioned by mon2? Any measurements?
        I don't think the charging controller is the culprit here since the board basically works, except you're not concinced about your soldering skills.
        • mon2
          • Dec 2019
          • 14097
          The source & drain resistance values = 0.90k = 900 ohms ? That is very low.
          Reverse the meter leads and confirm this value again.
          • kurtspirit
            • Feb 2019
            • 112
            • France
            Ok, to be more accurate :
            source (1-2-3) & drain (5-6-7-8)
            Left (not on board): black probe on Drain and Red on Source : 1.43K - Reverse : decrease from 13mohm
            Top : black probe on Drain and Red on Source : 6K (sometimes 2K oO) - Reverse : decrease from 300K
            Right : black probe on Drain and Red on Source : 6K (sometimes 2K oO) - Reverse : decrease from 300K
            source (1-2-3) & gate (4)
            Left :black probe on SOURCE and Red on GATE : OL - Reverse : OL
            Top : black probe on SOURCE and Red on GATE : OL - Reverse : OL
            Right : black probe on SOURCE and Red on GATE : OL - Reverse : 82K
            gate (4) & drain (5-6-7-8)[/B]
            Left : black probe on GATE and Red on DRAIN : OL- Reverse : OL
            Top : black probe on GATE and Red on DRAIN : OL - Reverse : OL
            Right : black probe on GATE and Red on DRAIN : 1mohm decrease- Reverse : OL
            • kurtspirit
              • Feb 2019
              • 112
              • France
              #26
              I hope someone is still here to give me ideas
              Took a little time as I ordered multiple items. So I changed the 3 mosfets as well as the BQ purchased from Mouser and the result is no better...
              I really do not understand what is happening but I can now rule out 99.99% a problem on these 4 components.
              Having no diagram or boardview, I don't know where to look or what to measure :/
              Thank you very much in advance. Your help is really much appreciated.
              • mon2
                • Dec 2019
                • 14097
                Apply the adapter and the battery.
                Power on.
                Carefully measure the voltage to ground of each pin of the charger IC.
                Post your measurements with the pin numbers.
                • kurtspirit
                  • Feb 2019
                  • 112
                  • France
                  #28
                  Thank you for your reply.
                  Here are the measurements :
                  1 - ACN : 19.41V
                  2 - ACP : 20.23V
                  3 - CMSRC : 20,02V
                  4 - ACDRV : 25.33V
                  5 - ACOK : 3.123V
                  6 - ACDET : 2.741V
                  7 - IADP : 3,204V
                  8 - IDCHG : 0.015V
                  9 - PMON : 0.336V
                  10 : PROCHOT :0.00V
                  11 - SDA : 3.280V ~
                  12 - SCL : 3.280V ~
                  13 : CMPIN : 2.00V
                  14 : CMPOUT : 4.921V
                  15 : BATPRES : 0.00V
                  16 : TB_STAT : 0.273V
                  17 : BATSRC : 11.13V
                  18 : BATDRV : 10.61V
                  19 : SRN : 10.61V
                  20 : SRP : 10.61V
                  21 : ILIM : 3.138V
                  22 : GND :0.00V
                  23 : L0DRV : 0.00V
                  24 : REGN : 5.998V
                  25 : BTST : 10.34V
                  26 : HIDRV : 10.62V
                  27 : PHASE : 10.62V
                  28 : VCC : 19.90V
                  • mon2
                    • Dec 2019
                    • 14097
                    To me, pin # 10 stick out.
                    This is an active LOW signal. If LOW, there is something wrong.
                    See attached from one of the datasheets by TI.
                    Remove all power. Meter in resistance mode. Measure the resistance to ground of pin #10.
                    Next, meter in DIODE mode.
                    Red meter probe, yes RED to ground.
                    Black meter probe to pin #10 of the charger IC.
                    Post each measurement.
                    • kurtspirit
                      • Feb 2019
                      • 112
                      • France
                      #30
                      In resistance mode, i find 112,6kohm
                      In Diode mode : red probe on ground : 0.554 and black probe on ground: OL
                      • Sephir0th
                        • Oct 2020
                        • 1282
                        In my opinion ILIM stands out too. Would more expect something around 1V than even 3V. You could check PR8913 and PR8914 for beeing inside the specs
                        • kurtspirit
                          • Feb 2019
                          • 112
                          • France
                          #32
                          Thank you but what is PR8913 / PR8914 please ? I don't have any diagram or boardview :/
                          • piernov
                            • Jan 2016
                            • 4435
                            • France
                            #33
                            1 - ACN : 19.41V
                            2 - ACP : 20.23V
                            Voltage drop too high
                            7 - IADP : 3,204V
                            Saturated as a result
                            • kurtspirit
                              • Feb 2019
                              • 112
                              • France
                              #34
                              Ok and what do you think about ? Have you an idea ? Thanks very much
                              • kurtspirit
                                • Feb 2019
                                • 112
                                • France
                                #35
                                I still stuck with this charging issue :/ Is someone have a boardview for this laptop please?
                                I don't understand what happen with this case. Thank you very much.
                                • mon2
                                  • Dec 2019
                                  • 14097
                                  Check the resistance to ground of ACN pin.
                                  Post the measurement.
                                  • kurtspirit
                                    • Feb 2019
                                    • 112
                                    • France
                                    #37
                                    I find 85kohm between ground and ACN
                                    • mon2
                                      • Dec 2019
                                      • 14097
                                      So no short on the main power rail.
                                      Measure the resistance between ACN & ACP pins. What is the resistance of the current sense resistor?
                                      There should not be such a large voltage drop from ACP to ACN pins.
                                      Perhaps you can measure the voltage to ground again of each of these pins and post your updates.
                                      • kurtspirit
                                        • Feb 2019
                                        • 112
                                        • France
                                        #39
                                        Ok, so resistance between ACN and ACP is : 168.5kohm
                                        Here are the latest measurements from ground to each pin :
                                        1 - ACN : 19.41V
                                        2 - ACP : 20.23V
                                        3 - CMSRC : 20,02V
                                        4 - ACDRV : 25.38V
                                        5 - ACOK : 3.123V
                                        6 - ACDET : 2.741V
                                        7 - IADP : 3,204V
                                        8 - IDCHG : 0.100V
                                        9 - PMON : 0.030V
                                        10 : PROCHOT :0.00V
                                        11 - SDA : 3.280V ~
                                        12 - SCL : 3.280V ~
                                        13 : CMPIN : 2.00V
                                        14 : CMPOUT : 4.924V
                                        16 : TB_STAT : 0.100V
                                        17 : BATSRC : 11.12V
                                        18 : BATDRV : 11.12V
                                        19 : SRN : 11.12V
                                        20 : SRP : 11.12V
                                        21 : ILIM : 3.141V
                                        22 : GND :0.00V
                                        23 : L0DRV : 0.00V
                                        24 : REGN : 5.999V
                                        25 : BTST : 10.84V
                                        26 : HIDRV : 11.12V
                                        27 : PHASE : 11.12V
                                        28 : VCC : 19.90V
                                        • mon2
                                          • Dec 2019
                                          • 14097
                                          OMG...can you check the acn to acp resistance again?
                                          Waaaay too high. Check the schematics (not at my desk now) but it should be ~1ohm or less.
                                          This is a serious fault if the reading is accurate.
                                          • Astonished
                                            Fixing the Charge Circuit of the Batteries of the DC Motor
                                            by Astonished
                                            Hi friends of electronics
                                            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                            Please help me fix this circuit.
                                            (the datasheet of the IC: https://pdf.datasheet.live/28...
                                            01-28-2025, 06:24 AM
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • dicky96
                                            HP Laptop TPN-C125 replacement batteries will not charge after 12 months
                                            by dicky96
                                            I got four replacement batteries for these HP laptops about a year ago. The originals would not charge, and these replacements have now gone the same way.
                                            I'm not sure what the expected life of a laptop battery is but I woud have thought they would last longer than that
                                            I now need to order four more batteries. Possibly these replacement ones were now good? The owner does not mind paying a bit more for originals or good compatible batteries that last longer
                                            The top one is the original
                                            Any ideas?
                                            Cheers...
                                            05-19-2021, 07:53 AM
                                          • razenxd
                                            How can I charge that battery pack?
                                            by razenxd
                                            it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                                            At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                                            Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                                            Now, I have noticed a few things.
                                            The "dead" battery, while connected to charger and NOT Charging will...
                                            12-05-2024, 06:11 AM
                                          • howardc64
                                            Where do repair shops buy MB replacement batteries?
                                            by howardc64
                                            Order my parts from mobilesentrix.com and iPhone batteries have been excellent. Recently got 3x bad A1534 (2015) batteries. All would work until ~30-40+% and drop to < 10% instantly. Typical sign of cheap batteries.
                                            Perhaps the less popular A1534 model's aftermarket batteries are more source limited. Just find it surprising quality from mobilesentrix (usually fairly high quality aftermarket parts) have been so poor.
                                            BTW, this isn't the only defective parts I've had from mobilesentrix. Amongst others including iPad Air touch screen and A1989 touch bar (display was...
                                            07-25-2024, 10:42 AM
