6470b/8470p (Calvin UMA 6050A2466401) touchpad and keyboard flick
  • r ez a
    • Sep 2014
    • 39
    • iran
    hello my friends
    this board problem is that touchpad working but every 2 sec it stop for 1 sec!
    its same for keyboard
    they working but there is stops
    its same even in bios page!
    i test them separately
    i tried different cpu,ram, touchpad and keyboard
    replacing kbc and flashing bios doesn't help
    any idea?
  • swammyw
    • Apr 2021
    • 66
    • finland
    Re: 6470b/8470p (Calvin UMA 6050A2466401) touchpad and keyboard flick
    i had this same fault on asus laptop once and bad battery was causing it
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Can be coz of bad screen as well. If screen is flickering,touchpad will freeze and then again act like normal.
      • r ez a
        • Sep 2014
        • 39
        • iran
        i test this motherboard on 3 different laptop and problem remains!
        something is wrong with board itself
          • 21841
          are you using a genuine 65 or 90 watt charger
          • r ez a
            • Sep 2014
            • 39
            • iran
            its same with any charger
            another motherboard work fine in this setup
            • master3112
              NM-C741 Lenovo L15 Gen 1 Touchpad and Trackpoint don´t work
              by master3112
              I have a Lenovo L15 Gen 1. The touchpad and trackpoint on the device are not working. Not even in BIOS, so it's not a driver issue. The touchpad is enabled in BIOS. When I run Lenovo Diagnostics for Windows, the touchpad is not even recognized. I have already updated BIOS, without success. VCC is present on the touchpad connector.
              Does anyone have any ideas?
              10-07-2025, 07:01 PM
            • B2L_Repairs
              Macbook A1706 touchpad and keyboard not working. Please help
              by B2L_Repairs
              Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
              10-09-2023, 04:56 AM
            • claws77
              lenovo flex5-14itl05, touchpad water damage
              by claws77
              last night i dropped some liquid over my laptop touchpad, immediately stopped using and tried to dry it up.
              the touchpad misclicks, sometimes stops working altogether
              i have removed the touchpad assembly cleaned it with alcohol and brush and cotton buds.
              can i fully disassemble the touchpad assembly as i suspect some liquid is still lurking inside the trackpad.​...
              07-15-2024, 07:34 PM
            • MichelinMan
              CF-20 Toughbook (mk1) Trackpad/Touchpad and USB ports not working
              by MichelinMan
              Hey guys,
              Just purchased a CF-20 (mk1) supposedly was all working. However, the seller had done a fresh install of windows 10 but did not install any driver. Seller was adamant the trackpad/touchpad was working.
              The touchpad/trackpad does not work. No led lights near the trackpad. The keyboard works, the USB 2 port on the base does not work, The USB 3 ports will recognise a USB 3 flashdrive but did not recognise a USB mouse. The ethernet port on the keyboard section works.
              The USB 3 port on the actual tablet section works with no issues.
              07-18-2023, 08:12 AM
            • uintptr
              Acer E1-571G Q5WVH LA-7912P Rev 1.0 Bypass Touchpad Requirement
              by uintptr
              Hello, i have Q5WVH LA-7912P Rev 1.0 motherboard on my old PC. I accidently broke the touchpad things when replacing the back and up case. After doing that my motherboard going to blinking orange light on LED2. When I properly seat that touchpad thing, it occasionally boots. I think the problem is because of this. I don't have a soldering iron, so I can't solder it there. Since I'm going to use the computer as a server, I don't need a touchpad. I'm also leaving a photo for better understanding. I need to short-circuit it and make it work all the time. Which pins is for short-circuit? Thank you....
              01-02-2025, 09:36 AM
