15SBGV2D-6050A2548101-MB-A02 short battery
  • ivangserrano
    • Apr 2018
    • 28
    • portugal
    hello
    my laptop hp 15SBGV2D-6050A2548101-MB-A02 does not turn on right now.
    If you make a direct connection from the first mosfet source to drain, it turns on, but if you put the battery in, a short circuit appears in the source.
    Turns on and works perfectly just connected to the battery and connected to the charger but both (battery and charger appears short circuit in the source and the first mosfet heats up and starts to smoke. (this without the first mosfet)
    If you put the first mosfet, the gate oscillates between 5v and 15v, sometimes 17v appears and I can turn on the computer.
    I have already changed the input mosfets, the secondary and the load ic and even then it does not work and always presents the same problem described above.
    The mosfets that I changed for the load and input and secondary mosfets and the switch are not original, they are the a5 vng n channel I think it will not be for that reason right?
    I await tips.
    swapped mosfets
    Q6010
    Q6011
    Q6012
    Q6000
    Q6001
  • mon2
    • Dec 2019
    • 14216
    Re: 15SBGV2D-6050A2548101-MB-A02 short battery
    1) remove the ~4k resistor @ R6018. Do not lose this part.
    2) Power up and measure the voltage to ground @ ACDRV pin # 4. What is the measurement?
    3) Measure the voltage to ground of REGN pin # 16. What is the measurement?
    • ivangserrano
      • Apr 2018
      • 28
      • portugal
      Hello
      without resistor 6018.
      ACDRV pin 4 - 22.30v 23v oscillating
      REGN pin 16 - 6v
      I tested it after a few minutes and now I have pin4 with 7.5v and pin16 with 6v
      • mon2
        • Dec 2019
        • 14216
        Appears that the charger IC is able to boost the voltage ok to enable the mosfets.
        Remove all power and meter in resistance mode.
        Measure the resistance to ground of the drain pins on Q6011 = main power rail (PVBAT). What is the resistance ? If it is low, then the main rail is shorting somewhere.
        Check the resistance across the mosfet pins @ Q6011. Need to check if it is leaking.
        Measure the usual:
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Post each measurement.
        • ivangserrano
          • Apr 2018
          • 28
          • portugal
          Measure the usual:
          source (1-2-3) & drain (5-6-7-8) - 4.3k - red source black drain
          source (1-2-3) & gate (4) 120k going up and a oscillate - red source black gate
          gate (4) & drain (5-6-7-8) 148k going up and a oscillate - red gate black drain
          • mon2
            • Dec 2019
            • 14216
            Measure the resistance to ground of the drain pins (5-6-7-8).
            What is the measurement ?
            The readings are low and this mosfet may be leaky. You can remove it and measure the resistance of this part while it is on your work table to confirm.
            After this part is removed, are the readings of the other mosfets higher than reported earlier ?
            • ivangserrano
              • Apr 2018
              • 28
              • portugal
              Measure the resistance to ground of the drain pins (5-6-7-8) - 3.1k
              I changed the mosfets for new ones and still the same problem remains.
              curious that the notebook turns on with the battery inserted, but if it has a battery and a charger, it shows a short circuit in the source.
              • mon2
                • Dec 2019
                • 14216
                You still have a leaky mosfet in the circuit.
                Remove all power and review the resistance across the mosfet pins for:
                Q6000
                and also
                Q6012
                Post your measurements.
                • ivangserrano
                  • Apr 2018
                  • 28
                  • portugal
                  Q6000
                  and also
                  Q6012
                  6012
                  source (1-2-3) & drain (5-6-7-8) - 45k - red source black drain
                  source (1-2-3) & gate (4) - 47k red source black gate
                  gate (4) & drain (5-6-7-8) - 51k - red gate black drain
                  6000
                  source (1-2-3) & drain (5-6-7-8) - 42,7k - red source black drain
                  source (1-2-3) & gate (4) - 28.9k- red source black gate
                  gate (4) & drain (5-6-7-8) - 161k - red gate black drain
                  the ACDRV pin 4 now -1.2v 2.7v oscillating is normal??
                  • mon2
                    • Dec 2019
                    • 14216
                    Each is a suspect with the low resistance values.
                    Carefully remove q6000 (aka high side charging mosfet) off the board. Then measure the resistance of the battery mosfet again.
                    • mon2
                      • Dec 2019
                      • 14216
                      ACDRV should be ~25v under normal operation. Fault may be from a leaky q6000 or the battery mosfet. Start with q6000 removal.
                      • ivangserrano
                        • Apr 2018
                        • 28
                        • portugal
                        Forget it, I didn't read the message above
                        • ivangserrano
                          • Apr 2018
                          • 28
                          • portugal
                          removing the q6000 I get the same resistance in the battery mosfet.
                          It's strange, I measured the mosfets and it shows about 65k from source to drain any of them (q6012, q6011, q6000 and q6001), is it really low resistance in the charging circuit?
                          I'm thinking of changing the 4 mosfets for new ones and waiting for that to resolve, what do you think? and the q6010 changed too?
                          • ivangserrano
                            • Apr 2018
                            • 28
                            • portugal
                            what I did now:
                            I changed the 4 mosfets plus the input mosfet too, that is, all, when I connected the charger I got 25v in the ACDRV and it turned on. when I turned it off and tried to turn it back on the ACDRV oscillates between 2v 5v 11v etc etc.... I'm confused as to what it could be...
                            • mon2
                              • Dec 2019
                              • 14216
                              How long did the laptop work ?
                              Which mosfets have been replaced in the last effort?
                              Does the laptop boot with a pre-charged battery (only) ? This case will not care about the ACDRV voltage.
                              • ivangserrano
                                • Apr 2018
                                • 28
                                • portugal
                                it worked until i turned it on the first time with the replaced mosfets q6012, q6011, q6000 and q6001) on power only. then I went back to being without acdrv. with the battery connected and no current, the laptop turns on and works fine
                                • mon2
                                  • Dec 2019
                                  • 14216
                                  So with power adapter only, the logic board fails to turn on?
                                  Remove the battery, using the power adapter only, measure the voltage to ground of:
                                  ACDET ; this voltage value is used to define if the adapter is present or not
                                  ACPRES
                                  • ivangserrano
                                    • Apr 2018
                                    • 28
                                    • portugal
                                    Acdet 2.7v
                                    Acpress 7v
                                    • mon2
                                      • Dec 2019
                                      • 14216
                                      These are good values.
                                      After the ACDRV voltage is low, measure the voltage to ground of each pin on the charger IC. Proceed with caution so that you do not short any of the charger IC pins.
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • jkyoho
                                        ASUS TUF FA506IV-AS76 vram mosfet short, then battery cant charge
                                        by jkyoho
                                        I recently fixed a FA506IV cam with Vram mosfet short on Vin(19v)to ground. Got both mosfet replaced and now laptop could turns on and GPU everything works but battery not charging. Battery status shows 100% on both BIOS page and Windows system.
                                        Measured voltage got 0.3v on battery red lead not going up. charging mosfet gate low and 19v not passing through inductor.
                                        I also tried dc bench supply 14v charge directly onto battery but seems not drawing anthing.
                                        Any idea?
                                        07-11-2022, 03:39 PM
                                      • techfreak9356
                                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                        by techfreak9356
                                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                        09-14-2023, 11:10 PM
                                      • Grafnus
                                        Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
                                        by Grafnus
                                        Hey there,
                                        first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
                                        So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
                                        Specs:
                                        • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
                                        • CPU, GPU, RAM work fine (not involved in the Problem)
                                        So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
                                        Now I noticed...
                                        08-06-2025, 11:54 AM
                                      • ferah831208
                                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                        by ferah831208
                                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                        03-18-2025, 01:18 AM
