Asus Rog Laptop new battery still 0% Biard issue?
  • mon2
    • Dec 2019
    • 14814
    Re: Asus Rog Laptop new battery still 0% Biard issue?
    Remove all power. Check the resistance across the mosfet pins - see the earlier posts for details. checking for a low resistance values on the mosfet pins.
    • irepair559
      • Dec 2022
      • 134
      ok will check tom
      • irepair559
        • Dec 2022
        • 134
        Well didnt go to work today but will be there tom God willing.. But are these 2 mosfets the same or compatible? i tried searching the new one in google nothing is comimg up.
        • mon2
          • Dec 2019
          • 14814
          Yes, the same.
          Datasheet is attached.
          • Sephir0th
            • Oct 2020
            • 1289
            Something must have happened or the board finally shows its "real face". Most likely you're dealing with a short to GND of the main power rail.
            So my advice will be to check Source and Drain of bith DC-IN mosfets to GND, in Ohms mode.
            FairRepair on YouTube
            • irepair559
              • Dec 2022
              • 134
              Originally posted by mon2
              Yes, the same.
              ok thanks
              • irepair559
                • Dec 2022
                • 134
                a bunch of components are measuring 1-2 ohms to ground.. The 2nd dc jack mosfets drain also the fuse next to it and many more components ( both ends ) are measuring 1 ohm to ground..
                • mon2
                  • Dec 2019
                  • 14814
                  The picture is a bit blurry but the 'fuse' is very likely a current sense resistor. It is, by design, a very low resistance component and is used to measure the current draw of the main power rail.
                  The charger IC will monitor the voltage going INto the current sense resistor and monitor the OUTput from the current sense resistor. There will be a small voltage drop across this resistor as there is a load on the line. The charger IC will read this small voltage drop and multiply it by a factor to determine the actual current being consumed by the load.
                  Have you replaced this 2nd DCin mosfet?
                  Either way, flux and remove this mosfet and then measure the resistance to ground again to see if the fault is gone or not.
                  • irepair559
                    • Dec 2022
                    • 134
                    i removed the 2nd mosfet but still drain is shorted to ground ? should i install a new mosfet?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #70
                      Since CLR(Current sense resistor) located just after 2nd dc-in mosfet is showing 1 ohms to GND, its a clear cut short on +19V rail. Remove the CLR and check which side is shorted to GND and then proceed to inject 1V on the shorted side and wait for 5 mins. Try to feel if anything is warm. Voltage injection should'nt exceed 1V.
                      • irepair559
                        • Dec 2022
                        • 134
                        Found the culprit , was the little moafet right above the old exploded cap burnt area.. was shorted in all directions.. removed it now short seems gone.. from the areas i mentioned..
                        Are these 2 mosfets the same
                        old one was G4 GUD 6UOI05
                        Replacement
                        KO3M5 DNS 0391
                        if not can you help me find the correct one from the US or if not from Ali express is ok
                        • irepair559
                          • Dec 2022
                          • 134
                          What do you think ?
                          • mon2
                            • Dec 2019
                            • 14814
                            Can we be sure that the measurement is truly 1 ohms or is the meter scale too low and reporting the resistance to be over limit?
                            Post a picture of the meter face with the setting showing the measurement. Is the resistance auto scaling or has a dial to select the range? If it is a manual range selector, switch to a higher scale till you have a valid reading.
                            • irepair559
                              • Dec 2022
                              • 134
                              Once i removed that little mosfet near the birnt cap area the short is gone now. but can i power it on without that mosfet, can i bypass it for testing purposes untill i get a new mosfet?
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                No, you must not power the board with missing components, especially when parts of a buck converter are missing. And there is no way to bypass it. It would be more important to know which rail is supplied here. Probably something related with the VRM circuit.
                                Although you still persist in hiding measurements, you were asked for (i don't understand this behaviour tbh), from observatios it strongly looks like a shorted high-side. That's bad news in case of it happened in VRM section.
                                • irepair559
                                  • Dec 2022
                                  • 134
                                  So you need the ohm readings for the little mosfet ? its off the board is that fine? what other measuremnts do you need?
                                  • Sephir0th
                                    • Oct 2020
                                    • 1289
                                    I'm not sure what I can respond to this type of question. It might be already to late for the device, but in my opinion it would be the best to take it to a proper repair shop.
                                    • irepair559
                                      • Dec 2022
                                      • 134
                                      really are you guys giving up on me? ive cleared the short now just waiting in those mosfets to come in. The G4 GUD . Ill install that and test for shorts again
                                      • mon2
                                        • Dec 2019
                                        • 14814
                                        Post #73
                                        • irepair559
                                          • Dec 2022
                                          • 134
                                          Post #73
                                          its not 1 ohm anymore since i removed that little mosfet it was bad, waiting on them to arrive. The G4 GUD , unless can i find a compatible one off a macbook board ? or dell or hp boards? is there a site that checks cross compatibe mosfets ?
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
                                          • huzo
                                            HP ELITE X2 1013 G3 weird battery issue
                                            by huzo
                                            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                            01-31-2025, 12:09 AM
                                          • danielsak
                                            Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                            by danielsak
                                            Hello, I have issue with Dell Inspiron 3542.
                                            Motherboard marking:
                                            Code:
                                            PWB FX3MC REV: A00
                                            The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                            1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                            1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                            10-11-2024, 04:36 PM
