Asus Rog Laptop new battery still 0% Biard issue?
  • irepair559
    • Dec 2022
    • 134
    Re: Asus Rog Laptop new battery still 0% Biard issue?
    Originally posted by Sephir0th
    Although it is a typical way how a DC-IN Mosfet shorts out, your resistance measurements does not makes sense at all regarding the previous observation.
    The two Mosfets on the first picture. What resistance do you measure between Source and Gate?
    The Dual-Mosfet near the burned via might be a secondary(!) issue which you might want to rule out later.
    i assumed that larger mosfet near the charger port was shorted but i learned thats not the correct way to measure by continuity mode. So i measured in diode mode to source and gate and its 0.9v . And on Drain its 0.4v on the left one and 0.9v on the right mosfet. So for the right mosfet its 0.9v all around basically is that normal?
    • Sephir0th
      • Oct 2020
      • 1282
      Ohms mode is better to compare. How much Ohms are this 0.4v and 0.9v in diode mode?
      FairRepair on YouTube
      • irepair559
        • Dec 2022
        • 134
        ok in ohms i found many mosfets with low readings under 100 ohms. i heard they are supposed to be in the thousands or millions right? i did red probe on ground and blavck on spurce ( pin 1 ) where the dot is. But under 100 ohms is bad right?
        • Sephir0th
          • Oct 2020
          • 1282
          Well, we're still at the two DC-IN Mosfets close to the charging port. I want to exclude one of them is (still) internal shorted and causing this behaviour. Forget all the other Mosfets present on the board for the moment.
          • irepair559
            • Dec 2022
            • 134
            source to drain is 1 ohm on the closet mosfet to the dc jack.. Bad ? Also had a small mosfet was measuring very low to and removed it and now that area measures in the kohms and the others near it are now measuring high to.. possibl lot of mosfets blew same time, what to do next ?
            • Sephir0th
              • Oct 2020
              • 1282
              We are probably dealing with a language barrier or similar right now, since you managed to remove the wrong mosfet (picture 1) which is not part of our troubleshooting.
              Please place it back immediately before doing anything else and ignore low values as long as they're not related to the DC-IN circuit. Just ignore each mosfet which hasn't anything to do with the DC-IN circuit please, like I told before.
              And in future do not touch any component without advise please
              Now to the second picture: Yes, 1 Ohms is a internal short and has to be solved. This one could be the culprit of your actual issue.
              • irepair559
                • Dec 2022
                • 134
                sorry just got impatient.. i put back the little mosfet but the 3 pin source always bridge even after cleaning the pads.. is that ok ? Also i removed that main mosfet near the dj jack and tested it out of the board and its shorted between source and drain.
                • Sephir0th
                  • Oct 2020
                  • 1282
                  All three pins of source are together anyway, so yes, no issue.
                  Wonderful, replace the mosfetwith a suitable replacement please and the issue should be gone.
                  • irepair559
                    • Dec 2022
                    • 134
                    so source and drain of the larger mosfet was 1 ohm outside the board thats bad correct? Also can i use similar looking mosfet off another asus laptop board i have? Or where can i buy one of these mosfets? i looked on ebay couldnt find any . The original is a NIKOS PKCH288 GUD201701
                    The one i want to use is a SM4309 RW6BY look similar and from same location near dc jack.
                    Thanks.
                    • irepair559
                      • Dec 2022
                      • 134
                      I found the mosfet thats on the same line of the battery positive line.. The drain of that bottom mosfet and the 3 pos batt terminal pins beeps that has to be the main batt mosfet right? I measured that mosfet source ohms and its 1 ohm( red probe ground and black to source ) . So im assuming the batt mosfet is bad? there are 2 other mosfets right above and the source on those are in the Mega ohms.. Also those two mosfets sourc's e has contuity with the batt terminal as well. But i think those 2 are good and the fist one is bad ?
                      • Sephir0th
                        • Oct 2020
                        • 1282
                        SM4309 is a P-Channel mosfet and the old one is N-Channel so ofc not a suitable replacement.
                        Easiest and best advice is to replace with the exact male/model. Otherwise you have to pay attention to a few key specs, like Ids same or higher, Rds same or lower, Ugs breakdown same or higher, Ugs threshold same or lower, and so on.
                        This is no easy stuff and if we even have issues to differentiate P-Channel from N-Channel then i have doubts now
                        • irepair559
                          • Dec 2022
                          • 134
                          so i took out the sm4309 from the donor board and measured its around 5 megaohms drain to source.. just like the other original nikos one still on the board.. measures the same around 5 mega ohms. but the Suspected bad one measures nothing zero trued even flipping probes.. So that mosfet is bad for sure right?
                          • irepair559
                            • Dec 2022
                            • 134
                            I appreciate you helping me and having patients with me. As i dont have any patients ����
                            Where can i find NIKOS PKCH288 GUD201701 in the US? seems like all from china ?
                            • Sephir0th
                              • Oct 2020
                              • 1282
                              A Mosfet which reads out of circuit below KiloOhms in any internal direction has pretty sure failed. This is why we measure it this way.
                              Can't help for sourcing though. Check local eBay and verified suppliers. Maybe it helps when you type the right model:
                              PKCH2BB instead of PKCH288
                              • irepair559
                                • Dec 2022
                                • 134
                                so can i test mosfet while on board? and whats the proper way to test ? oops ywah your right its BB not 88 lol.. You think that main mosfet is tge cause of the battery charging issue? i thought it would be something in the battery circuit. Also i noticed a lor of coils and diodes and mosfets source) have contuity with ground?? Is that normal ? like 1-5 ohms , wouldnt that indicate a short? but how can a laptop still work with that many shorts?
                                • Sephir0th
                                  • Oct 2020
                                  • 1282
                                  How many proofs do you need till you do what someone with experience advised?
                                  It is widely known that a internal shorted DC-IN Mosfet can cause no charging. Oversimplified the adapter voltage will be just jumpered into the main power rail, although the charging circuit is not ready.
                                  And regarding the "shorts", you have to differentiate between a Mosfet, which acts like a simple switch and mosfets which are part of a buck converter. If they're part of a part of a buck converter there is always at least one mosfet connected to GND. Otherwise the step down wouldn't be possible at all. you should read about some basics in this direction. They're absolutely necessary to not make the issue worse by random attempts.
                                  • irepair559
                                    • Dec 2022
                                    • 134
                                    Thank you very much, i will order a couple PKCH2BB and hopefully that works!!
                                    • irepair559
                                      • Dec 2022
                                      • 134
                                      ok got the new mosfets but after install not getting any voltage at all?? not even at the dc jack ?? Maybe they sent me wrong ones and i blew something else?
                                      • mon2
                                        • Dec 2019
                                        • 14144
                                        Remove the power adapter. Meter in dc volts mode. Use a 20v or higher scale.
                                        Red meter probe to inside of the adapter barrel / coax connector. Black meter probe to the outside of the same connector. Plug in the adapter to the wall.
                                        Do you have ~19v dc volts reading?
                                        If yes, remove all power. Meter in resistance mode. One meter probe to the center pin connector on the logic board. Other meter probe to ground.
                                        What is the resistance?
                                        • irepair559
                                          • Dec 2022
                                          • 134
                                          im getting 20v out of the charger..
                                          OL For center dc jack and ground
                                          1 ohm for center dc jack and coil right next to it..
                                          But at the dc jack just 0.5v and dropping till zero
                                          seems like charger goes into safe mode and kills the voltage on the charger due to some short or issue on board...
                                          i put back original mosfet and same issue.. bummer
                                          at least before it would power on now board is dead ����
                                          I think those new mosfets are wrong type and damaged something?
                                          • mkdj
                                            ASUS X571 no power : battery issue?
                                            by mkdj
                                            Mark and model: ASUS X571
                                            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                            Tests already made:
                                            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                            - I have removed...
                                            07-14-2025, 09:16 AM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • code share
                                            Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                            by code share
                                            I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                            Here's what I've tried so far:
                                            • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                            • Booted successfully on AC power only with the battery disconnected
                                            • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                            • Battery
                                            04-21-2025, 12:50 PM
                                          • huzo
                                            HP ELITE X2 1013 G3 weird battery issue
                                            by huzo
                                            Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                            01-31-2025, 12:09 AM
                                          • danielsak
                                            Dell Inspiron 3542 (Cedar_Intel-MB 13269-1) - RTC battery self-discharging and Realtek LAN issue
                                            by danielsak
                                            Hello, I have issue with Dell Inspiron 3542.
                                            Motherboard marking:
                                            Code:
                                            PWB FX3MC REV: A00
                                            The laptop works just fine (on battery and power supply) and doesn't cause any problems, except those described below:
                                            1. The first problem is that the RTC/CMOS battery self-discharges after about 2-3 weeks after installing a new battery. I have been installing different batteries (GP, Duracell, Energizer) and the problem still exist.
                                            1. The second problem is the LAN network card (Realtek RTL8106E), which is not detected at all in Windows. The BIOS is
                                            10-11-2024, 04:36 PM
