HP Probook 430 G3 wont turn on
  • roxboy1984
    • Jan 2022
    • 177
    • South Africa
    Please could someone assist me. So i have a strange issue where my HP laptop wont turn on. The charger light comes on when AC is connected but nothing when i press power.
    Long story short i managed to get it to boot by removing the Bios battery but when i put the battery back and reconnect the main battery the problem returns so i suspected a bios issue. ive now removed the bios chip and am trying to reprogram it but i get the issue you can see on the pic. Does this mean the chip is failed? Thanks in advnce
  • mon2
    • Dec 2019
    • 14681
    Re: HP Probook 430 G3 wont turn on
    If you have a backup -> erase the part and review if this same location is still stuck or does it revert to 0xFF.
    • roxboy1984
      • Jan 2022
      • 177
      • South Africa
      Thanks as always for your help @Mon2. I don’t have a backup unfortunately. Do you think the fact that the chip is giving me that error could be the reason for the issue with it not powering on initially?
      • reformatt
        • Feb 2020
        • 1522
        If it boots after a CMOS reset, then your BIOS is (was) likely ok. Behaviour like this is usually a bad power button. It boots automatically due to the reset, but once that is done it relies on the button to start. Quite a common failure on HP's. Pull the power button board out and you'll probably find the top part of the switch is missing.
        The programming error is more likely an issue with your programmer. Did you get a dump of the chip beforehand?
        • roxboy1984
          • Jan 2022
          • 177
          • South Africa
          Thanks guys.
          So here is the original Bios that i saved before i started. i shall reflash this and see if it is successful. After i reset the bios battery the power button did work to power on the machine it would only stop working once i re inserted the main battery back into the machine. so im not sure that the power button is faulty.
          • roxboy1984
            • Jan 2022
            • 177
            • South Africa
            So when i try and reflash the original bios back i get the following.
            "Verification error on address: 0x00001100, Device: 0xFF, Buffer: 0x26"
            • roxboy1984
              • Jan 2022
              • 177
              • South Africa
              Tried a new version of NeoProgrammer and get this verification error.
              Verification error on address: 0x00000EFC, Device: 0xFF, Buffer: 0xDF
              • mon2
                • Dec 2019
                • 14681
                Continue to verify only the contents with this flash device.
                Do you have the same location fault everytime?
                Are your programmer tools stable? Can you slow down the read/wrote speed in your software? Being spi flash, it should be possible. Use a slower clock in the setup. This may be the true issue.
                Otherwise, to me, the flash device is defective and should be replaced.
                • roxboy1984
                  • Jan 2022
                  • 177
                  • South Africa
                  I shall try what you suggested with the verify option. however im not familiar with how to slow down the read/write speed in NeoProgrammer. any chance you can tell me how to do this? Im using a Ch341 Black USB programmer if that helps at all.
                  • reformatt
                    • Feb 2020
                    • 1522
                    CH341 there are many clones and knock offs. Check the data line voltage levels, apparently on some these run at 5V rather than 3.3V and result in these errors.
                    I'd still be checking your power switch with a meter.
                    • roxboy1984
                      • Jan 2022
                      • 177
                      • South Africa
                      Hi Guys,
                      Thanks again for all the replies and help. i have just tried to reflash another bios chip and am getting verification errors. Im wondering if perhaps my programmer is the issue. please advise what i need to do or check on this programmer to see if its faulty.
                      The programmer im using is Ch341 Black and NeoProgrammer v2.2.0.10. I am still learning so any help is greatly appreciated.
                      • abel2b
                        • Mar 2009
                        • 34
                        Check Flash chip model and voltage, I get that error when trying to program 1.8V chip, in that case, you need 1.8V adapter for ch341 ...
                        • roxboy1984
                          • Jan 2022
                          • 177
                          • South Africa
                          Thanks so much for the reply. i have the 1.8V adapter but the chip is definitely a 3.3V. im not sure what else to do or how to test if its the programmer or the chip itself.
                          • roxboy1984
                            • Jan 2022
                            • 177
                            • South Africa
                            Turns out the Programmer was the issue. ive bought a new one and was able to flash the bios again successfully however the fault still remains. all u get is an orange light when charger is attached and no sign of life when i pish the power button.
                            • mon2
                              • Dec 2019
                              • 14681
                              1) be sure your bios is correct to use for this logic board.
                              2) post or link the schematic for this logic board.
                              3) review the DCin mosfets and power adapter detect circuit. The charger IC details are of interest.
                              Which one is onboard? BQ series?
                              • roxboy1984
                                • Jan 2022
                                • 177
                                • South Africa
                                Thanks i shall do the above and post back. Not sure if this is relevant but the amber light is there regardless of whether the battery is installed or not.
                                I tried multiple bios's.
                                here is a link to the Schematics. https://www.badcaps.net/forum/attach...8&d=1538122191
                                • mon2
                                  • Dec 2019
                                  • 14681
                                  Check the voltage to ground of BQBATPRES pin # 15 of the BQ charger IC. This pin senses if the battery is present or not.
                                  The netname for this signal to the battery is MAIN_BAT_DET#. Interested in the voltage to ground here.
                                  Also - see attached.
                                  Other points to measure are the voltage readings of the SMBUS pins on the battery pack = SMD / SMC (names from their schematic).
                                  Each must be ~3 volts else the TVS ESD diodes may be shorted and causing a communication fault of the SMBUS lines.
                                  Update: REMOVE the battery and check the pin #15 voltage to ground. Without the battery, this pin must be ~3 volts.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    Does the mb boots after cmos removal with new bios flash?? If yes, it has nothing to do with bios. You should have acted on @reformmat's advice of checking the power button. Another reason can be some issue in RTC circuit. If battery is charging, there should be nothing wrong in charging circuit. So do check the basics before taking un-necessary steps.
                                    • roxboy1984
                                      • Jan 2022
                                      • 177
                                      • South Africa
                                      òk so just an update. I checked the Power button as suggested and its fine.
                                      The machine however is now turning on and fans are spinning but i get nothing on display and no external display either.
                                      • Sephir0th
                                        • Oct 2020
                                        • 1289
                                        Then you're back at BIOS. however, check whether you get a reaction from CapsLock or Numlock with external keyboard before.
                                        FairRepair on YouTube
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • Syph1979
                                          PS5 EDM-031 1216A BIOS Issue
                                          by Syph1979
                                          Hi all. First post here, so I hope I'm getting this right and operating in the spirit of things here.
                                          I've been working on consoles for a while now. Always learning and trying new repairs, but I have one that has been stumped and I wondered if anyone with more experience could help?
                                          I picked up a PS5 from eBay recently. It was described as not having the disc drive, but it was also a no power unit. On testing it was clearly an issue with the supply (no 12v), so I replaced that and then when I inserted the power lead, I got 3 beeps. So far, seems all related. As I was...
                                          09-25-2025, 05:48 AM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          Yesterday, 05:14 AM
                                        • wizard13
                                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                          by wizard13
                                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                          • Part Number (P/N): PYU13E-00C00PFR
                                          • Serial Number (S/N): 22028896H
                                          • System Configuration (SC): A1PYU13E1127
                                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                          • Power Input: DC 19V –
                                          02-28-2025, 02:43 AM
