dell e6440 no battery detected
  • SR IT SOLUTION
    • Jan 2023
    • 61
    • INDIA
    dell e6440 la-9931p rev:1.0 battery not detected already i replace battery
    still problem same. pls help thanks in advanced
  • mon2
    • Dec 2019
    • 14191
    Re: dell e6440 no battery detected
    Battery not detected will be:
    1) connector fault
    2) connector contacts not soldered
    3) ESD diodes clamping the SMBUS circuits - remove PD2 & PD4 and test again. My bet (of a fresh box of Haldiram's motichoor ladoos) are on this fault. Killed 3 days on a macbook (other shops gave up on it) and it was down a tiny tiny SMD ESD dual didoe - needed tweezers to solder it.
    See attached. Post your updates.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Sometimes its a shorted cap or mosfet on discharge circuit.
      • SR IT SOLUTION
        • Jan 2023
        • 61
        • INDIA
        yes!!!
        done pd2 is faulty i remove pd2 now battery detected
        thanku so much
        • mon2
          • Dec 2019
          • 14191
          SMD ESD dual didoe
          DIODE. LOL, salivating while typing ☺️
          Good job. The ESD diode did it's job to suppress a transient event at the battery connector. Do replace it if available.
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • HTR-Informatique
            by HTR-Informatique
            02-09-2025, 06:51 AM
          • ipatch
            dell inspiron 5567 laptop battery lipo WDX0R
            by ipatch
            recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
            1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
            2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
            got the computer...
            04-02-2023, 04:45 PM
          • tomodachi
            Dell Precision 5510 " Not a Dell Battery"
            by tomodachi
            Hi
            Dell Precision 5510
            Mobo code : LA-C361P
            This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
            The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
            So we ordered a geniune battery for customer, plugged it in
            RTC battery was also dead and it was also replaced. First boot up brought up warning message;
            Funny thing is Service Tag is already set.
            And...
            11-07-2024, 06:08 AM
          • DProf.
            Dell XPS 13, 9365 battery not detected
            by DProf.
            Hi great minds. I have this Dell XPS 13 9365 with service tag FK960x2 showing No battery detected and blinking white light continuously, meanwhile there is a working battery in it that is still backing up fine. Please can anyone help with the solution?
            09-02-2024, 06:31 PM
