very slow response macbook air
  • kulokutoys
    • Jun 2010
    • 132
    • Phillippines
    model A1466 emc3178. laptop working fine when charging after unplug it will slow down tremendously. perform smc and ram resets multiple times it doesn't help. can someone guide me on this, I'm not an apple guy.
  • mon2
    • 14663
    Re: very slow response macbook air
    It is slow when running from battery only?
    • kulokutoys
      • Jun 2010
      • 132
      • Phillippines
      yes
      • mon2
        • 14663
        Is the battery the original?
        How many charge cycles are reported ?
        Review the part number on the battery.
        Reference:
        https://www.ifixit.com/Answers/View/...anging+battery
        • kulokutoys
          • Jun 2010
          • 132
          • Phillippines
          ok will check
          • gjlpereira
            MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
            by gjlpereira
            Hi forum.
            I'm working on a macbook pro, model a1708, that is running extremely slow.
            Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
            One other symptom of the problem with the machine is that the fan is always running at full speed.
            This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
            09-06-2022, 07:45 PM
          • envym
            by envym
            Hi everyone!
            06-27-2025, 08:54 AM
          • platinumsteel
            Macbook Air 2015 Booting Very Slow and Stuck on apple Logo 99%
            by platinumsteel
            Hi guys i have my personal MacBook Pro 2015 820-00165 board that was working fine for more than a year and one day stopped working on my original Magsafe charger. It was turning on with my bench power supply. Opened it up and while diagnosing that somehow i ended up with a shorted smc.The line which was shorted was SMC_PM_G2_EN. I removed the SMC and short was gone. So all I had was another working donor board 820-3435 which i used to program it's SMC to 820-00165 using the SMCTOOL By MuertoGB.Took that SMC and use it on my 820-00165 board .And my board started working again. PPBUS_G3H 8.56V....
            03-18-2024, 05:16 PM
          • resistor83
            Macbook pro 15" 2011 A1286 stuttering and slow
            by resistor83
            hi all, I have a problem with my macbook pro 15 inch, late 2011 with SSD, AMD Radeon HD 6770M dedicated video card and Intel HD 3000 integrated card.
            I use the computer occasionally at home and a few weeks ago I noticed that the battery was charging very slowly, I changed the power supply with a new original one and the problem remains. I also changed the battery to a compatible one and the problem persists. Now for a few days I have also noticed that the computer after a few minutes from starting it jerks and becomes very slow. However, this problem arises in several ways:
            02-09-2023, 03:19 AM
          • Stevie_belfast
            820 00850 Macbook Pro Slow performance
            by Stevie_belfast
            Hi guys
            820 00850 board here, clean, no previous repair.
            Had a short on PPBUS, I found the problem, was shorted cap C8150, replaced and macbook boots.
            Problem is its very slow.
            It would boot to login screen eventually, but mouse and keyboard very erratic and slow to respond.
            When I tried Internet Recovery, it takes a few hours then fails on 2005F error.
            When I try to boot from USB stick, it lets me select the stick, then just a blank screen and goes no further.
            I restored using DFU...
            10-20-2022, 04:55 AM
