820 00850 Macbook Pro Slow performance
  • Stevie_belfast
    • Jan 2015
    • 23
    • United Kingdom
    Hi guys
    820 00850 board here, clean, no previous repair.
    Had a short on PPBUS, I found the problem, was shorted cap C8150, replaced and macbook boots.
    Problem is its very slow.
    It would boot to login screen eventually, but mouse and keyboard very erratic and slow to respond.
    When I tried Internet Recovery, it takes a few hours then fails on 2005F error.
    When I try to boot from USB stick, it lets me select the stick, then just a blank screen and goes no further.
    I restored using DFU mode but still the same.
    Seems like maybe another problem on the board that's causing it to be slow?
    Like CPU is throttled.
    Any help greatly appreciated.
  • Aliencomputres
    • Aug 2019
    • 220
    • România
    Re: 820 00850 Macbook Pro Slow performance
    heloo
    • Stevie_belfast
      • Jan 2015
      • 23
      • United Kingdom
      Originally posted by Aliencomputres
      heloo
      Cheers but i've reset NVRAM a load of times.
      • reformatt
        • Feb 2020
        • 1553
        Probably missing sensor data. You can prove it by going into diagnostics on boot up (IIRC you get a PFM error code). I would be eyeballing the Thunderbolt Air sensors IC's U5850/U5860 (around and underneath them) primarily as they are at the edges of the board. U5870 would also be a good candidate too, as it's just above the cap you replaced.
        • Stevie_belfast
          • Jan 2015
          • 23
          • United Kingdom
          Thanks for the info and reply,
          Forgot to mention, I did replace U5870 from info gained from searching for something similar to this problem.
          Cant get into diagnostics mode either, gets as far as entering wifi password then just hangs on blank screen.
          I'll have a look at U5850 & U5860, cheers reformatt.
          • Stevie_belfast
            • Jan 2015
            • 23
            • United Kingdom
            Changed U5850 & U5860 but still the same awfully slow performance.
            • reformatt
              • Feb 2020
              • 1553
              No signs of corrosion then? These are just the thermal sensors, there are others for power as well. I'd be looking at these sections for any tell tale signs of corrosion, maybe even use a thermal camera to identify any hot spots out side of the power supplies and CPU.
              PROCHOT can be asserted by the system management or by the CPU itself for throttling. Throttlestop is a Windows utility that I've used to debug this stuff on Windows machines, not sure what's out there for MAC's. In theory you could install Windows on this MAC but I'm sure it would be painful.
              • Stevie_belfast
                • Jan 2015
                • 23
                • United Kingdom
                No signs of corrosion, very clean board.
                I don't have a thermal camera but i'll look for hotspots the old fashioned way.
                Yes a windows install would be very painful.
                Ok, i'll keep on at it.
                Thanks for the reply.
                • Stevie_belfast
                  • Jan 2015
                  • 23
                  • United Kingdom
                  Ok, strange one this.
                  Getting hot around QB300, and the caps above it, C7006, C7008, C7009.
                  Checked for shorts but none that I can find.
                  All 4 USBC ports work fine and switch to 20V
                  Other side of the board around Q3100 doesn't get as hot.
                  • Stevie_belfast
                    • Jan 2015
                    • 23
                    • United Kingdom
                    Update, just incase anyone else has a performance problem.
                    Found a dislodged cap, C7908, on PP3v3_G3H_PMU_VINTRC_R.
                    sluggish poor performance is now fixed and it seems to be running fine now.
                    Now just have to get past the 2005F error in recovery which seem to be due to WiFi issues.
                    • MyronViegas
                      MacBook Pro 2018 A1989 820-00850-A Stuck at 5.00V and 0.150A
                      by MyronViegas
                      Hey guys,
                      I got a MacBook Pro a1989 820-00850-A dead for repair. The MacBook itself was off for a month or so and it didn't power on. I tested using ammeter and it was stuck on 5v. Opened the machine and found a short on ppbus_g3h, corrosion near the right spkr_amp. removed the spkr_amp and saw short on ppbus_g3h. plugged in to power, boosted to 20v .600A and then back down to .300A. Trackpad was clicking when on .600A but no image etc.
                      Later, I tried again but it dropped down to 5v and never boosted back to 20V. checked board again and found ppbus_g3h shorted again....
                      10-06-2025, 08:45 AM
                    • ErinV
                      MacBook Pro A1989 820-00850-A not powering on
                      by ErinV
                      Hey everyone!
                      I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                      I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                      The diode voltages around all 4 CD3215's seem fine.
                      For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                      09-30-2024, 10:21 PM
                    • kuba2102
                      Macbook pro i5 2020 GPU stuck at 300 Mhz and very slow
                      by kuba2102
                      My MacBook Pro i5 2020 820-01987-06 laptop is extremely slow. The GPU is constantly stuck at 300 MHz — it doesn’t increase or decrease. On the motherboard only one of the two voltage regulators is producing voltage, and it had been tampered with. I replaced the voltage regulators, but the situation remains the same.
                      Whenever I try to read temperatures with HWMonitor, the laptop freezes for a solid 30 seconds, the cursors still works tho. TG Pro causes a proper hang, and it kicks me back to the login screen, even though I’m still technically logged...
                      Yesterday, 07:17 PM
                      Apple MacBook Pro 13" A1989 820-00850-A Schematic
                      Apple MacBook Pro 13" A1989 820-00850 820-00850-A Schematic...
                      10-08-2024, 02:17 AM
                    • PITERPENY
                      Macbook A1989, 820-00850, won't boot. 20V, 0A.
                      by PITERPENY
                      Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                      Here are some measurements, maybe someone can tell what the problem is.
                      The initial problem was a burnt out induction coil L8504 (replaced).
                      When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                      here are some measurementsmotherboard...
                      01-16-2024, 02:19 PM
