DELL n5010 runpwrok issue
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Hello friends and happy new year to all the lovely badcaps family.
    Laptop N 5010 came with no display. Upon investigation found the PGOOD ( RUNPWROK) is missing . Now if I remove the +1.05V_VTT output COIL , the RUNPWROK is back at 3.3 volt.
    Also +1.05V_VTT is not generated on TPS51218 (PU4901)
    The readings on PU4901 is as follows with coil removed :
    1 - 0V
    2 - 0.8V
    3 - 3.3V
    4 - 0V
    5 - 0V
    6 - 0V
    7 - 5V
    8 - 0V
    9 - 0V
    10 - 5V
    The impedance on the VTT coil is Good as well.
    The mosfets on this DC DC converter is OK. What could be wrong ?
    Thank you
  • Sephir0th
    • Oct 2020
    • 1280
    Re: DELL n5010 runpwrok issue
    And resistance to GND measurements of the Pins with missing voltage (except GND)?
    It seems the requirements are met. So, If +1.05_VTT looks healthy, it might be the time to inspect the buck converter more detailed. Start with the mosfets (are they internal shorted?) and replaced the Controller along with the mosfets if nothing turns out
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Replace PU5001 and very likely RUNPWROK will be back to 3.3V.Put PL4901 back.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Seconded (and thirded, it seems) the firm suggestion to replace PU5001 ALONG WITH BOTH MOSFETS AT THE SAME TIME. Put PL4901 back. Should run fine then.
        Done this same mistake so many times for years and years and years myself, especially on VGA and battery charger circuits. Find mosfet short, replace mosfet, burns again on all terminals. Replace controller chip and burned mosfet, controller chip burns again. Replace controller chip a 3rd time. Mosfet burns.
        Rinse and repeat and measure and check untill I FINALLY get fed up and "pull out the shotgun" - replace controller chip, ALL associated mosfets and low value gate resistors (if any) and all the fuses too. Then, the magic happens. The smoke stays in, the power supply delivers healthy voltage, the battery charges and the dedicated graphics card works unless it needs reballing.
        There is an actual physical, electrical and very real and measurable explanation to this, it's not just "old technicians' talk", service bulletin or something you learn from experience. It's called MOSFET gate leakage. Look it up. You will find everything about it in less than 1 minute. Fully understanding what it means, why and how it happens and how you can prevent it from happening if you are the designer doing that power circuit could take many years, though.
        A working TV? How boring!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Agree with @Th3_uN1Qu3 to replace PWM along with high/low side fets. Thats the standard practice and we all do that. Since the OP is here for long time, i expect him to replace fets along with PWM though perhaps i should have mentioned it.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            🛠 Original Issue
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
          • Spider1211
            Dell N5010 display issue after UMA conversion
            by Spider1211
            Hey guys, need help figuring out what's causing the following issue.
            I have a dell N5010 which had a bad GPU chip and a UMA conversion was performed.
            Initial conversion was done per this video: https://www.youtube.com/watch?v=cq8r920tW64
            After conversion, laptop boots and display comes on but once windows starts loading, it becomes all fuzzy/dotted. I initially though it could be a driver issue, so I removed the HDD and booted into BIOS settings. Image was not fuzzy but some letter jitters (like dancing dots at the edge of the letters) was visible....
            05-15-2021, 04:50 PM
          • Simone Vergani
            Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
            by Simone Vergani
            I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
            To assist with troubleshooting, I'm attaching two power circuit schematics:
            • Power
            03-05-2025, 02:25 PM
