DELL n5010 runpwrok issue
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Hello friends and happy new year to all the lovely badcaps family.
    Laptop N 5010 came with no display. Upon investigation found the PGOOD ( RUNPWROK) is missing . Now if I remove the +1.05V_VTT output COIL , the RUNPWROK is back at 3.3 volt.
    Also +1.05V_VTT is not generated on TPS51218 (PU4901)
    The readings on PU4901 is as follows with coil removed :
    1 - 0V
    2 - 0.8V
    3 - 3.3V
    4 - 0V
    5 - 0V
    6 - 0V
    7 - 5V
    8 - 0V
    9 - 0V
    10 - 5V
    The impedance on the VTT coil is Good as well.
    The mosfets on this DC DC converter is OK. What could be wrong ?
    Thank you
  • Sephir0th
    • Oct 2020
    • 1289
    Re: DELL n5010 runpwrok issue
    And resistance to GND measurements of the Pins with missing voltage (except GND)?
    It seems the requirements are met. So, If +1.05_VTT looks healthy, it might be the time to inspect the buck converter more detailed. Start with the mosfets (are they internal shorted?) and replaced the Controller along with the mosfets if nothing turns out
    FairRepair on YouTube
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Replace PU5001 and very likely RUNPWROK will be back to 3.3V.Put PL4901 back.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Seconded (and thirded, it seems) the firm suggestion to replace PU5001 ALONG WITH BOTH MOSFETS AT THE SAME TIME. Put PL4901 back. Should run fine then.
        Done this same mistake so many times for years and years and years myself, especially on VGA and battery charger circuits. Find mosfet short, replace mosfet, burns again on all terminals. Replace controller chip and burned mosfet, controller chip burns again. Replace controller chip a 3rd time. Mosfet burns.
        Rinse and repeat and measure and check untill I FINALLY get fed up and "pull out the shotgun" - replace controller chip, ALL associated mosfets and low value gate resistors (if any) and all the fuses too. Then, the magic happens. The smoke stays in, the power supply delivers healthy voltage, the battery charges and the dedicated graphics card works unless it needs reballing.
        There is an actual physical, electrical and very real and measurable explanation to this, it's not just "old technicians' talk", service bulletin or something you learn from experience. It's called MOSFET gate leakage. Look it up. You will find everything about it in less than 1 minute. Fully understanding what it means, why and how it happens and how you can prevent it from happening if you are the designer doing that power circuit could take many years, though.
        A working TV? How boring!
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Agree with @Th3_uN1Qu3 to replace PWM along with high/low side fets. Thats the standard practice and we all do that. Since the OP is here for long time, i expect him to replace fets along with PWM though perhaps i should have mentioned it.
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
          • ahmarzo
            Acer laptop battery draining issue
            by ahmarzo
            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
            08-02-2025, 06:39 AM
          • elmark
            HP 15-cw1002ua strange keyboard issue
            by elmark
            HP Pavilion 15-CW1002UA
            S/N 5CD0251CBC
            P/N 7KE54EA
            Hello guys!
            I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
            It powers on OK and has no other issues except the following:
            • CAPS LOCK does not work at all
            • Fn button toggles Flight Mode
            • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
            • (with SHIFT pressed: 't%' and 'y^' respectively)
            I initially thought it was a keyboard malfunction (internal short, etc.),
            but when I press and hold...
            06-27-2025, 01:10 AM
