dell 3567 / AC fine, but Battery not charging and CPU @ 0.4ghz if battery not removed
  • WhatsTheDellio
    • Jan 2023
    • 16
    Re: dell 3567 / AC fine, but Battery not charging and CPU @ 0.4ghz if battery not rem
    I've got this currently, never used flux before. will it do?
    MG Chemicals 8341 No Clean Flux Paste, 10 ml Pneumatic Dispenser (Complete with Plunger & Dispensing Tip) (8341-10ML) https://a.co/d/98yRVBo
    i looking at this drag solder with an iron https://youtu.be/Fwx_qzfwdgk he calls it soldering paste but it looks like flux paste to me... maybe I'm wrong?
    also this chip looks closer to mine (only pads on the bottom) so I guess this would be the process I need to follow? https://youtu.be/c_Qt5CtUlqY
    • WhatsTheDellio
      • Jan 2023
      • 16
      Does it shows the correct wattage of adapter in bios setup screen?? If no,then your problem is PS_ID circuit.
      Next measure voltage on PU4301/PQ4410 for Pin 1/4/8.
      All the measurements should be without battery,only adapter connected.
      Voltage on PL4401 also.
      Report back and then we decide and may opt for resistance check and some voltage measurements on charging ic PU4401.
      i measured the PL4401 again tonight and it seemed to pulse between 0mv and 30mv.. not sure if i'm getting some interference or if that is expected... where in the schematic should I be able to read the expected voltage of these pins?
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • HTR-Informatique
        by HTR-Informatique
        02-09-2025, 06:51 AM
      • ipatch
        dell inspiron 5567 laptop battery lipo WDX0R
        by ipatch
        recently i was gifted a dell inspiron 5567 for wiping the data on the hard drive. (yay me). however i already have a computer that i use, so i have no need for this computer. this computer wasn't without its problems though.
        1. i had to purchase an adapter to retrofit my older style dell laptop battery cable. (not too expensive) ~= 10 bucks for a 2 pack via amz.
        2. after that i had to find a spare cr2032 (easily found in my parts bin) and assemble a makeshift cmos battery thanks to some copper foil tape and some heat shrink tubing.
        got the computer...
        04-02-2023, 04:45 PM
      • tomodachi
        Dell Precision 5510 " Not a Dell Battery"
        by tomodachi
        Hi
        Dell Precision 5510
        Mobo code : LA-C361P
        This one came in for battery replacement but without original battery, so original battery and charging history is unknown.
        The customer said he bought the computer several years ago second-hand and was told that there was no battery inside but that he could purchase one if he wanted.
        So we ordered a geniune battery for customer, plugged it in
        RTC battery was also dead and it was also replaced. First boot up brought up warning message;
        Funny thing is Service Tag is already set.
        And...
        11-07-2024, 06:08 AM
      • ianbak
        Dell Vostro 3578 Battery Error
        by ianbak
        Please can anyone shed some light on why my Dell Vostro 3578 is giving the following BIOS error: 'The primary battery is not identifiable and this system will not charge this battery pack.'?
        The problem is not the battery - I've tried three different identical ones, all Dell OEM. They all work perfectly in other systems (different models, though) whilst giving the same error in the Vostro.
        The laptop will run happily from the battery if it is charged and Windows accurately reports the charge level, proving that the communication between the laptop and the battery...
        10-17-2025, 02:52 AM
