HP dax1bdmb6f0 suddenly dead, hot apu
  • liquidzorch
    • Oct 2016
    • 135
    • mexico
    Hello. My personal laptop just died on me, and to my luck, it does not seem like it can be fixed, but wanted an opinion. It is a Star Wars edition hp 15 laptop, with a dax1bdmb6f0 motherboard (without dedicated graphics). I was watching a video, moved the laptop, it shut off and thinking it was just a semi unplugged charging cable I pressed it back in, pressed the power button, saw it light up and left to another room. When I got back it was off again, but this time it did not turn back on.
    The 3.3v line has a really low resistance, and if I plug in the charger, I do get 3.3v on the output coil, but things start getting warm real fast.
    The hotest part of the board when connected is the APU. But that is what I don't get, does the 3.3v line go into the CPU or GPU? The APU does get really hot, and other parts of the board get warm, but not as hot. So my logic tells me that the short is in the APU, but then again, I have seen shorts heat up other ic's that are not the issue, but normally that would be voltage regulators or something on in between the voltage source and short.
    Any ideas? I am in a tight spot, since it is my daily use computer, and my wife was just about to start school online this week.
  • Andreasbest
    Dell Latitude 7410 dead and amber light as long power button is pressed.
    by Andreasbest
    Hello.
    I received a bios locked 7410 with 25Q256JVEQ ,i dump the bios, unlocked it and flash it back, since then the laptop has no life signs at all except amber led on for as long the power button is pressed, nothing else.
    Fact #1 i was unaware that 25Q256JVEQ is 3.3v and i used a 5v CH341A to program it, not sure if the chip got damaged but since then i can read it and write it normally, doesn't seem dead.
    Fact #2 i modded the CH341A to 3.3v, same results with programming though, nothing changed.
    Fact #3 i tried hard reset with cmos/main battery disconnected and power...
    12-21-2024, 02:02 PM
  • Francesc V.
    Dell dockstation WD15 is dead
    by Francesc V.
    Hi:
    A friend gave me this DELL WD15 dockstation that does nothing. Not detected by computer, no digital output.........just leds shines when it’s plugged in.
    Here are the findings, followed by good pictures. :-)
    When pluged in, LED3 glows
    Measuring some voltage in the circuit.
    Inductors
    - PL202 has 5V
    - PL201 has 3.3V
    - PL300 has 1V
    V. Regulators
    - UT30 has 19v as input and 6V as output. It seems ok.
    - UT27 (same reference as UT30, has no input/output voltage).
    Thermal find...
    07-09-2025, 12:12 AM
  • jacobtc
    Dead ASUS ROG G14 (GA401)
    by jacobtc
    Hi!
    It seems like all the laptops I get are dead G14's. I already had two, in which one was fixable, and one wasn't. This one is different though, I promise!
    The previous owner used it without a screen, as the panel was dead, and suddenly it just died.
    The board looks fine, no visually burnt components as I can see.
    I do not get a short on the DC-In mosfets, however as I had with one of my other machines, the first mosfet does not seem to let voltage through, so the second mosfet does not receive 20V. (See pic).
    Only the BQ chip...
    02-14-2023, 11:42 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • eastcoastcomputing
    Lenovo Legion7 16ACHg6 no post
    by eastcoastcomputing
    Hi there, I need help with the diagnostic on this board (NM-D563 Rev2.0).
    I could not find schematics nor boardview for it.
    The laptop was working, playing game when it suddenly crashed. Thermal paste is good and fans are clean. Since then, when power gets plugged in the laptop tries to come on (led lights light up, on off button lights up CPU and GPU warm up) for a minute or so before shutting down. No Display, no beeps no flashing led
    There's no liquid damage. I've checked the board under the microscope and can't find any damaged components. I've checked...
    06-24-2025, 04:26 AM
