Macbook A1502 820-4924-A No power
  • orion78fr
    • Apr 2022
    • 37
    • France
    Hi !
    Someone brought me a Macbook A1502 with no power & no green light on charger. Opened it & no liquid damage, good start.
    It had a short on the capacitors just above the battery connector, so I thought it would be simple. Injected voltage, saw a heat spot on the back of the board, and yeah, C6432 was blown (rather catastrophically, fused with the pad, but whatever, it's audio so it's not the most important for now), and removing it cleared the short.
    However, still no green light... Pull up my thermal camera again and OMG Q7010 & R7020 are at > 100°C !
    Here, I don't know where to look, as I'm clearly not an expert on Macbooks, but here's what I know :
    • The only other thing that heats up is U5000 (the SMC if I'm not mistaken), but only 30°C, so I think it's normal operating temperature.
    • Q7010 & R7020 are not getting hot immediately, only like 1s after plugging the charger (probably after the SMC kicks in ?)
    • There is no short after R7020 (it reads 100kOhm to ground, so it seems OK)
    • Caps around U7100 not shorted, R7121 & R7122 not pulled to ground by U7100 (read that it can do that)
    • PPBUS_G3H is around 2V, PPDCIN_G3H is around 15V (probably voltage drop due to the amperage drawn)
    Please tell me where to look, I'll take measurements, but can't let the charger for long to get voltages because of the heat produced.
  • mon2
    • Dec 2019
    • 14589
    Re: Macbook A1502 820-4924-A No power
    Remove fuse F7140. Power up again.
    Meter in dc volts mode (20 volts or higher).
    What is the voltage to ground of the pcb pad for F7140, pin #1 (PPBUS_G3H)?
    Remove all power. Meter in resistance mode.
    Measure the resistance to ground of the pcb pad for F7140, pin #2 (consumer side of the PPBUS_G3H rail).
    Post all measurements and the meter scale used for the tests.
    • orion78fr
      • Apr 2022
      • 37
      • France
      Still getting hot when powered on.
      My voltmeter has an auto scale mode, so shouldn't be a problem.
      1.230 V, slowly decreasing as the board gets hotter.
      ~15 MOhms, slowly decreasing.
      The producer pad is weird though, 400kOmhs slowly decreasing to 2kOms in 15 seconds, then jump back to 400kOmhs.
      • mon2
        • Dec 2019
        • 14589
        Fault is in the producer side of the ppbus_g3h rail.
        What is the resistance to ground of F7140, pin #1 pcb pad?
        • orion78fr
          • Apr 2022
          • 37
          • France
          That's what I guessed
          As I said, the producer pad is weird, 400kOmhs slowly decreasing to 2kOms in 15 seconds, then jump back to 400kOmhs and loops.
          • mon2
            • Dec 2019
            • 14589
            Am confused.
            The ISL side is ~15 Mohms ? That is fine.
            The other side of the fuse is the consumer side of the power rail.
            • mon2
              • Dec 2019
              • 14589
              What is the voltage to ground of PPDCIN_G3H_CHGR ?
              You can measure @ C7130 (+) tab.
              • orion78fr
                • Apr 2022
                • 37
                • France
                Am confused.
                Pin 2 (PPBUS_G3H) is 10 MOhm
                Pin 1 (PPVBAT_G3H_CHGR_REG) is the one fluctuating between 400 kOmh & 2 kOhm
                PPDCIN_G3H_CHGR is 14.6 V
                • mon2
                  • Dec 2019
                  • 14589
                  That sounds too low. Using an official and proper rated power adapter?
                  What is the voltage to ground of PPDCIN_G3H ?
                  This is the INPUT voltage to the ISL6259 @ U7100. You can measure @ F7005.
                  What is the voltage to ground of PP3V42_G3H ?
                  • orion78fr
                    • Apr 2022
                    • 37
                    • France
                    Sorry for the delayed response, had to work on some other boards.
                    It's the official 45W Magsafe 2 power adapter (A1436, 14.85V 3.05A) that was in the box my customer brought me, so I guess it's the correct one. Tested with another A1436 and an USB charger with a magsafe adapter (that works on my wife's macbook air) and got the same result.
                    Remember that Q7010 & R7020 are getting really hot, over 100°C rapidly, so the boards probably draws a lot of amps, and that probably makes the voltage lower a little.
                    F7005 voltage is 15.07V (both sides)
                    PP3V42_G3H (on test point left of D7005) is 0.52V, which seems way too low.
                    • piernov
                      • Jan 2016
                      • 4437
                      • France
                      https://support.apple.com/en-us/HT201700
                      • orion78fr
                        • Apr 2022
                        • 37
                        • France
                        Originally posted by piernov
                        Oh... So if I read correctly A1502 should be an 85W charger and be 20V 4.25A ? It was nicely packaged in the original box and still had plastic wrap on it so I thought it was the original one...
                        So, it won't work with the 45W one ? Not even give a green / orange light or attempt to boot but charging slow / not charge ?
                        • mon2
                          • Dec 2019
                          • 14589
                          I think you have assorted issues on this board - including use of a wimpy power adapter. The power adapter should offer a higher voltage than what you are measuring (assuming that your meter is accurate / with fresh batteries).
                          Measure the voltage to ground on EACH pin of D7005 diode. Does this dual anode diode pass through the voltage present on pins 1 / 2 - diode will select the higher of the 2 voltages to power this regulator.
                          If you DO NOT see the proper voltage on pin # 3 = output of this diode, then power down.
                          Remove all power -> meter in resistance mode.
                          Measure the resistance to ground on pin # 3 of this diode D7005.
                          Post all measurements.
                          • reformatt
                            • Feb 2020
                            • 1450
                            A 45W charger will give you magsafe light green/orange, but the board definitely won't start. Just confirmed it with a 4924 board on the bench and a chipmunk USB. You need at least a 60W charger for them to even try to boot.
                            If you have the magsafe light, then you must have PP3V42_G3H.
                            • orion78fr
                              • Apr 2022
                              • 37
                              • France
                              D7005
                              1 PP18V5_DCIN_CONN_R 3.26V
                              2 PPBUS_G3H_R 0V
                              3 PPVIN_G3H_P3V42G3H 2.8V
                              Is that normal that it's so low in input of D7005 ? Voltage drops from 15V to 3.3V between the pins of R7020, but I think it shouldn't. Is the resistor bad ? My meter reads 46.9 Ohms in resistance mode, but I don't know, maybe it does something weird with voltage.
                              4Mohms dropping to 50 kOhms in 11 seconds then cycling
                              I see, I told to the owner and he will look for a proper 85W charger.
                              • orion78fr
                                • Apr 2022
                                • 37
                                • France
                                I read somewhere that R7020 overheat was probably something around U7090.
                                R7095 R7096 looked good, C7094 not shorted...
                                Checked diode mode to ground on L7095, 0.002, weird. Resistance mode, 2 Ohm.
                                Okay then, let's inject voltage with bench power supply to see what's get hot.
                                1V, only drawing .5A... Maybe not enough ? 2V, drawing even less, .2A.
                                Only things getting warm is U5000, in the 30°C, so I guess normal.
                                And guess what ? Putting charger back, nothing gets warm, and get a freaking green then orange light ! What the actual hell ? Going to solder back the F7140 fuse I unsoldered earlier and see what happens...
                                • mon2
                                  • Dec 2019
                                  • 14589
                                  Pin #1 of D7005 is with the wrong voltage. Check again if that voltage is now restored.
                                  • orion78fr
                                    • Apr 2022
                                    • 37
                                    • France
                                    I get 14.25V now on pin 1 of D7005... plus an orange light...
                                    • mon2
                                      • Dec 2019
                                      • 14589
                                      What is the ppbus_g3h voltage?
                                      Is the laptop booting?
                                      • orion78fr
                                        • Apr 2022
                                        • 37
                                        • France
                                        Yeah it boots, but not with the mac adapter, only with my Nintendo Switch adapter with an USB to Magsafe 2 adapter.
                                        I don't know if battery is super flat or not recognized yet.
                                        I still have to restore the pad and solder C6432, but will do that tomorrow, it's 4:30 AM for me x).
