820-01041 stuck on 5volt 220mah
  • dellxps15
    • Feb 2014
    • 1598
    • italy
    hi all, got this board not powering on. it has 4 usb-c port and at start i got this situation:
    1 usb of each side was on 5 volt and 120mah drain, and 1 usb of each side had 5 volt and 480mah.
    after replacing 2 usb of same side cd3215C00 (should be ok) i had 5 volt and 120mah on all port, but on other side of replaced cd3215 i had one port not worning if cable was inserted one way ( work just opposite side cable)
    after another inspection i see one usb not giving PP3V3_UPC_XB_LDO and usb-c getting hot, so replaced the other 2 usbc and finally now i have all usb stuck 5 volt 220mah.
    PP3V3_UPC_XB_LDO is present on all 4 cd3215.
    PP1V8_UPC_XB_LDOA is present.
    PP1V8_UPC_XB_LDOD present
    pp3v3_g3h_rtc present
    PP1V1_UPC_XB_LDO_BMC Missing
    ppbus _g3h is 12,3 volt
    on usb-c rom u2890 i have 3,3 volt on pin 3,7,8. on pin 1-2 i have volt on pin 1 and 0v pin 2 resistor (r2892 r2893 ) both 3,3k
    on usb-c rom ub090 i have 3,3 volt on pin 1-3, 5-8.
    any tips on where to look at since usb-c mac with 4 port are a pain to diagnose.
    did sone 2 port mac and usb c cd3215 come back to working condition just after replacing them.
  • mon2
    • Dec 2019
    • 14662
    Re: 820-01041 stuck on 5volt 220mah
    PP1V1_UPC_XB_LDO_BMC will be active if using this port to power the laptop. Check it.
    • dellxps15
      • Feb 2014
      • 1598
      • italy
      i checked that volt on all 4 chip but never came , using original apple psu.
      do u think problem is rom , isl or bad cd3215 ?
      • mon2
        • Dec 2019
        • 14662
        Remove all power. Meter in DIODE mode.
        Red meter probe, yes Red, to ground.
        Black meter probe to point to test.
        Measure the DIODE mode reading of each LDO rail of each CD3215. Post each measurement.
        Example readings:
        Good board (diode mode):
        PP1V8_UPC_XA_LDOD=0.483V
        PP3V3_UPC_XA_LDO=0.515V
        PP1V8_UPC_XA_LDOA=0.525V
        PP1V1_UPC_XA_LDO_BMC=0.520V
        PP1V8_UPC_XB_LDOD=0.484V
        PP3V3_UPC_XB_LDO=0.515V
        PP1V8_UPC_XB_LDOA=0.525V
        PP1V1_UPC_XB_LDO_BMC=0.520V
        Update:
        Is the psu the recommended power adapter for this unit?
        Can you test the power adapter with another type C device? Does the adapter cycle to other power delivery contracts or stuck at 5 volts?
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          on steam deck it goes to 15 volt.
          later ill check giode value of each cd3215.
          tnx for reply
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            measured these days value... all reading almost ok.. someone read 0.485, others 0.570.
            same as before.. all voltage present except 1.1 .
            i'll try doing a dfu when i get keyboard.
            • Simplebeans
              • Sep 2021
              • 135
              Your not getting PP1V1_UPC_XB_LDO_BMC on all 4 CD3215's? Did you check the grounding capacitors on all 4 lines?
              • Stunt
                Hp Laptop Stuck on Hp protected by hp sure start screen
                by Stunt
                Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                screen that's it and stuck there. I left it until the following day and i still...
                09-02-2025, 01:51 PM
              • stormanimal83
                Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                by stormanimal83
                Hey....
                Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                01-18-2024, 02:15 PM
              • rilley
                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                by rilley
                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                And the resistor L4004 is literally burned.
                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                07-10-2024, 01:57 AM
              • drscoot
                usbc connector replacement on mobile
                by drscoot
                I replaced the broken usbc connector on this Ciontek CS50 mobile device. It worked fine afterwards, although it looks like the battery went down quickly and the device got warm at the back (battery section). After putting it in standby for a while it didn't came back anymore?
                The battery is still charging (red led), but no power on.
                I had another look at the usbc connector, it looks like one of the components is melted down (blue marking)? I have a picture of an untouched device and then the repaired device with 2 pictures; what are these components with B1 and PB marking? Are these...
                07-13-2025, 02:37 PM
              • ekozeko333
                [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                by ekozeko333
                I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                🔥 The Problem Started After Suspected ESD/PD Fault
                I experienced a power issue or ESD event through a USB-C charger
                After that, the NX20P5090 power switch was visibly burned and was replaced
                Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                🧠 What I’ve Done So Far
                Flashed...
                06-21-2025, 02:48 AM
