No boot Lenovo l590 FL490/FL590 NM-B931
  • azemar
    • Nov 2022
    • 46
    • France
    hello I am looking for a breakdown on a Lenovo l590 (FL490/FL590 NM-B931). the computer turns on with the power light and the capslock but no interaction on this one. the screen stays black. external screen no display either.
    for the main voltage they are ok. cpu heats up with 0.8v and 1.1v on the coils. I have already tested several bios nothing changes. thank you in advance for your help
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: No boot Lenovo l590 FL490/FL590 NM-B931
    DRAMRST# present?? PLT_RST# present?? Powergood signals checked?? Having voltage on all coils is not enough for mb to post.
    • azemar
      • Nov 2022
      • 46
      • France
      Thanks dramrst=1.2 plt_rst=3.3v pwrok=3.2v pgood=0v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Ram is onboard?? Where you measured Pgood=0v??
        • azemar
          • Nov 2022
          • 46
          • France
          Ram ok yes pgood=0v
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1226
            • France
            Originally posted by azemar
            Ram ok yes pgood=0v
            schematic and boardvoew here :
            https://www.badcaps.net/forum/showthread.php?t=100946
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              @azemar, when you answer a query vaguely,i think no one can help. Ask if you dont understand the question but always answer precisely.
              • azemar
                • Nov 2022
                • 46
                • France
                Hi, sorry, I didn't understand the question. for pgood after variation it is normal that it is at 0v because there is no chip on this model of motherboard. on the other hand pwrok is well at 3.3v and I measured it on the R1515 as described on the BRD
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Still, your answer is not to the point and you have not clarified whether ram is inboard or not.
                  Anyway, have you measured the followings:
                  01.H_CPUPWRGD
                  02.PCH_PWROK
                  03.PCH_SYSPWROK
                  04.PCH_PLT_RST#
                  05.DSW_PWROK
                  As per schematic, it seems memory is onboard here. What is the consumption on your dc supply after power on??Ignore if you are powering with adapter.
                  Going by the observation so far it seems like onboard memory failure. I dont see any option to disable them in schematic.
                  I beleive there is a memory slot as well. Am i right??
                  • azemar
                    • Nov 2022
                    • 46
                    • France
                    01.H_CPUPWRGD
                    02.PCH_PWROK
                    03.PCH_SYSPWROK
                    04.PCH_PLT_RST#
                    05.DSW_PWROK
                    hello sorry for the late answer I was on vacation.
                    here are the voltage measurements:
                    01.H_CPUPWRGD :1.1v
                    02.PCH_PWROK :3.3v
                    03.PCH_SYSPWROK :3.3v
                    04.PCH_PLT_RST# :3.3v
                    05.DSW_PWROK :0v
                    There is no soldered ram on my motherboard model.
                    I can't feed it with my lab power supply. (power supply via USB C). and I don't have a USB C to USB C controller module.
                    Thank you again for your help
                    • rediii
                      h???, spurrrn
                      • Mar 2018
                      • 490
                      • somewhere in europe
                      did you test flashing ec rom?
                      • azemar
                        • Nov 2022
                        • 46
                        • France
                        yes no change
                        • rediii
                          h???, spurrrn
                          • Mar 2018
                          • 490
                          yes no change
                          did you disconnect the keyboard and screen?
                          • azemar
                            • Nov 2022
                            • 46
                            • France
                            Yes
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 490
                              Yes
                              did you check the board under thermal cam. maybe cpu/pch needs reballing then. epoxy shit :/
                              • azemar
                                • Nov 2022
                                • 46
                                • France
                                yes i looked at the camera only the cpu heats up around 40°c
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Cpu at 40 degree is absolutely normal. I still dont think its SOC fault.
                                  Since you have confirmed there is no soldered memory, what is the consumption on your dc supply 01With ram stick 02.Without ram stick.
                                  Are you sure DSW_PWROK is 0V?? Going by the rest od the readings DSW_PWROK should also read 3.3V. Re-check it.
                                  • privato89
                                    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                    by privato89
                                    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                    Let's begin:
                                    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                    03-26-2024, 06:37 AM
                                  • hinisa
                                    Xiaomi router freezes at boot after re-capping
                                    by hinisa
                                    I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                    When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                    After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                    Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                    07-08-2023, 05:58 AM
                                  • Luke Anders
                                    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                    by Luke Anders
                                    A few details about the laptop itself:
                                    Name: Lenovo Legion 5
                                    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                    BIOS Version: GKCN60WW
                                    EC Version: GKEC65WW
                                    Serial Number: PF39AQ7Z
                                    Board Model: NM-D562 Rev 3.0
                                    RAM: 16GB Installed, DDR4 (brand new)
                                    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                    I bought this laptop recently from eBay as a faulty device....
                                    10-12-2024, 05:13 AM
                                  • NolesFan
                                    Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                    by NolesFan
                                    Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                    10-24-2024, 06:36 PM
                                    Lenovo ThinkPad L590 Notebook L Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad L590 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L590 boardview and L590 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                    09-06-2024, 03:30 PM
