LA-E541P no power on
  • koby058
    • Jan 2017
    • 387
    • israel
    Hi
    I have this MOBO, schematic here https://www.badcaps.net/forum/showpo...12&postcount=8
    I see that i have no 3v3_ALw nor 5v_ALW. (5V_3V_EN is missing)
    I can see that I have 20v on PR303 (current sensor)
    the charger IC is isl 88739
    resistance on 5v coil is 22.5ohm and on 3.3v coil 16.5ohm
    Can you please help me debug it ?
  • mon2
    • Dec 2019
    • 14673
    Re: LA-E541P no power on
    Unable to locate PR303 - can you check again the label for this component?
    These ALW rails require the presence of the enables and B+ voltage rails to supply the output rails. B+ is after the 2 x DCin mosfets.
    Start with the voltage to ground reading of:
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    of the 2 x DCin mosfets @ PQ740 and also PQ712.
    ACOK pin # 2 of PU703 ; voltage to ground ?
    To ENABLE each of these 2 x DCin N-channel mosfets, the gate must be higher than the voltage being passed between source / drain pins.
    So the gate voltage must be ~25 volts to enable. Otherwise the drain pins on PQ712 (2nd mosfet) should be @ 0 volts.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Resistance on 3V as well as 5V coil is too low. it should be a few Kohms. PU502,pin15 resistance and PU501,pin17 resistance??
      • koby058
        • Jan 2017
        • 387
        • israel
        Hi
        I meant PR913 have 20v
        Gate is 24.9v and the drain of PQ712 is 20v
        ACOK is 20v
        PU502 pin15 is 2.4 when on the 200M option of mm
        PU501 pin17 is 1.2 when on the 200 option of mm
        • mon2
          • Dec 2019
          • 14673
          The enable for these ALW rails is based on resistor PR506. confirm that this resistor is present. Measure the voltage to ground on both sides of this resistor.
          The voltage on ACOK seems very high. This is an open drain output that has a local pull-up resistor (pr741). Confirm again the voltage to ground of this pull-up resistor on the ACOK PIN.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Clearly +3VLP(LDO) is shorted to Ground. You need to inject 1V at PC509,pin1 with dc supply and observe what is getting hot. Very likely kbc and/or PCH.
            • mon2
              • Dec 2019
              • 14673
              Can you post a pic of your meter face used for the resistance checks? Wish to understand the scale of the measurements.
              • koby058
                • Jan 2017
                • 387
                • israel
                Hi
                since no board-view, i cannot find PR506 but i can say for sure that ENLDO_3V5V is present on pin 11 of PU501 its 4.5v and on pin 11 of PU509 its 0.49v
                It is the 5V_3V_EN on pins 12 of those that is missing.
                Pin 2 of charger IC is 20V
                On PC509 pin1 i have 1.3ohm resistance
                Attached photo of my MM
                • mon2
                  • Dec 2019
                  • 14673
                  See attached. Can you confirm the reading and the meter scale used for this test?
                  If indeed 1.3 ohms on the 200 ohm scale, then you have a shorted component on this power rail.
                  As suggested by @mcplslg123, remove all power -> dial up your power supply to 1 volt (never higher to be safe from killing the CPU) & 2-5A.
                  Then red meter of the power supply on this LDO rail and black power supply lead to ground.
                  Review which part heats up or even cracks under this event. IPA works well to mist up while the part heats up. It may even be the capacitor @ PC509 but we need to confirm.
                  Post your updates.
                  • koby058
                    • Jan 2017
                    • 387
                    • israel
                    confirmed
                    I will push voltages and update
                    • koby058
                      • Jan 2017
                      • 387
                      • israel
                      It took me 3v to get the short to draw 0.4amp. i found out that the EC is getting hot
                      Is it fixable ? can it be change ? can the job be done without a programmer ?
                      • mon2
                        • Dec 2019
                        • 14673
                        You should have kept the voltage down to 1v but increase the current level of your power supply.
                        Is it possible that a component near the EC is causing the heat ? Do you have a thermal camera or using IPA ?
                        • koby058
                          • Jan 2017
                          • 387
                          • israel
                          I have a thermal cam, i cannot control the current in the short killer only the voltage.
                          i felt the EC getting very hot on my fingers
                          I have this one
                          https://www.aliexpress.com/item/4001...901b1802RJPde5
                          • mon2
                            • Dec 2019
                            • 14673
                            Awesome - we have the same one.
                            Sounds like the EC is defective but personally do not have experience in this area. Wait on comments from others. If the EC features an external flash device then you only need to replace the EC itself.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              EC is NPCE388XXX and its programmable.So you need a new EC + sio programmer.
                              • koby058
                                • Jan 2017
                                • 387
                                • israel
                                Can the chip be bought already programmed for this computer ?
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Yes, it can be bought pre-programmed but this facility may not be available iin every country.
                                  • koby058
                                    • Jan 2017
                                    • 387
                                    • israel
                                    can you point me to it so i can ask?
                                    • mon2
                                      • Dec 2019
                                      • 14673
                                      @koby058, this guy is advertising this controller and programming services:
                                      https://www.ebay.com/itm/16363203812...H4a9h#shpCntId
                                      You can try also some of the shops on Aliexpress which may be a lower cost.
                                      • koby058
                                        • Jan 2017
                                        • 387
                                        • israel
                                        thanks, i will ask the owner if he want to invest
                                        thanks all
