A2159 - 820-01598 - Stuck at 5V and am a beginner looking to learn
  • mon2
    • Dec 2019
    • 14271
    Re: A2159 - 820-01598 - Stuck at 5V and am a beginner looking to learn
    it suggests that the short is further downstream?
    Yes. With these 2 resistors OFF the logic board, power up again.
    Measure the voltage to ground at C6912, pin #1.
    What is the voltage? If it is ~3v3, the regulator @ U6903 is working fine and does not need to be replaced.
    Next, remove all power -> dial up your power supply to 1 volt (NOT higher for safety - in case the power rail is shorting to the CPU rail through a leaky mosfet) and 2A-5A current.
    With no power to the logic board but using only this external power supply, attach the RED power supply probe onto R6934 or R6935, pin #1 (either one is ok). BLACK power supply probe to ground (shield is ok).
    The power supply current consumption should spike due to the ultra low resistance on this rail.
    Who is heating up using this process? You can pour IPA onto the board / area you suspect is causing this short. The IPA will mist up and evaporate quickly from the heat. With some luck, it will be a defective capacitor which is quite common. The longer you keep the probes attached, the hotter the shorted component will get. Hope it is not the CPU (do monitor the CPU without a heatsink). Often the caps are tantalum style and they split / crack open under this event. Tantalum caps are just crap and they short circuit when they die over time. Once you home in on the shorted part, remove that part off the board with flux and low air pressure, so the parts do not go flying (without a license).
    Then allow the board to cool down and measure the resistance to ground again for the same short condition.
    Post your updates and measurements.
    • Stiffmesiter
      • Dec 2022
      • 23
      Power supply came today, just couldn't justify pulling the trigger on a thermal camera... will update later today, thanks!
      • Stiffmesiter
        • Dec 2022
        • 23
        I don't understand it, but voltage to ground of C6912 @ pin 1 is 12.3 V steady. Same as the input voltage to the chip measured @ C6909...
        So the chip is acting as a wire now? Furthermore, according to the TPS62180 spec sheet,the max allowable output is 7V.
        So I guess we have two problems now, short after circuit and perhaps this chip is still faulty?
        • mon2
          • Dec 2019
          • 14271
          Whoa! See attached.
          You are measuring ~12v3 to ground @ C6912, pin #1 ??
          That is very dangerous but believe that the 2 x downstream 0 ohm resistors are REMOVED off the board ? (R6934 & R6935 are OFF the board).
          DO NOT connect these resistors till this power rail returns to within range.
          Summary - Vout = Vin ???
          Remove all power and do confirm that the feedback resistors are matching the resistance shown in the schematic.
          The FB resistors are R6912, R6913, R6910, R6911.
          That is, this rail must be ~3v3 else there will be other damage to the board.
          Yes. It appears to be so.
          • Stiffmesiter
            • Dec 2022
            • 23
            Correct, resistors R6934/35 are still off and I won't reconnect. Thanks for the heads up on that.
            See attached pictures of my readings/locations.
            Testing resistors now.
            • Stiffmesiter
              • Dec 2022
              • 23
              R6910: Reading 450 kOhm, Schematic 360 kOhm
              R6911: Reading 71 kOhm, Schematic 115 kOhm
              R6912: Reading 10 Ohm, Schematic 10 Ohm
              R6913: Reading 0.04 Ohm, Schematic 0 Ohm
              • Stiffmesiter
                • Dec 2022
                • 23
                What your thoughts on the readings? Does this mean a trace is wrecked or something?
                • mon2
                  • Dec 2019
                  • 14271
                  Remove each of these resistors but do so one at a time and then measure when the part is on your work table. Allow it to cool before measuring.
                  Does the part value measure to the schematic value?
                  If yes, place it back and remove the next resistor to test.
                  It is possible that the resistor values are showing a different value while in circuit vs. off the logic board.
                  Confirm the feedback resistor values and update this thread.
                  • Stiffmesiter
                    • Dec 2022
                    • 23
                    Wow, that was hard! Those resistors are so small - I can't believe I didn't lose any (pic attached).
                    In any-case, here are the updated readings:
                    R6910: 360 kOhm
                    R6911: 115 kOhm
                    R6912: 10.4 Ohm
                    R6913: 0 Ohm/OL
                    The resistors are all to spec, so is it a chip issue still?
                    • mon2
                      • Dec 2019
                      • 14271
                      Replace U6903 and measure again with the downstream resistors still OFF the logic board.
                      This power rail must be within spec to match the schematic values.
                      • reformatt
                        • Feb 2020
                        • 1416
                        I'd be looking at the pads for this IC. Looked torn/damaged to me in the original posts.
                        • Stiffmesiter
                          • Dec 2022
                          • 23
                          Hi all, sorry for the delay, I was away on work last week, but back now
                          @reformatt, can you please point out the pads that look particularly poor. Do you have any recommendations on how I can clean this up further, or test for the broken pads?
                          • reformatt
                            • Feb 2020
                            • 1416
                            In post #8, your first and second pics didn't look good. Maybe its the way the solder balls reflect the light, but would certainly bear closer examination. Doesn't look symetrical.
                            Just use the boardview to check for connectivity to other parts, and of course, check for shorts etc. If you have lifted or broken pads, you'll need to review whether they are needed or redundant. If needed, you need to run jumpers, which requires some patience to fit correctly with UV mask etc.
                            • Stiffmesiter
                              • Dec 2022
                              • 23
                              Ok. Correct me if I am wrong, but the only way I can have 12 V both in and out of this chip is if there is bridging of the balls, no?
                              Also, if a pad is torn off, wouldn't that mean that the connection would stop the current from moving through and thus no reading on the exit?
                              • reformatt
                                • Feb 2020
                                • 1416
                                Top row of pads is for Vin1/Vin2. The 2nd pad from left, 2nd row looks in the 2nd pic like it is lifted. This could result in a bridge between Vin1 and SW2 once the chip is placed on, hence you'd get 12V on the output. When we place a BGA on, we rely on surface tension of the solder to the pads to pull it into place. If the pads have lifted and moved, this could result in shorts for sure.
                                Take off the IC, and flatten the pads with wick, clean up, and look again under a scope. You do this a short piece of wick and hot air/flux. Lightly scrape across the pads while applying hot air to remove excess solder. Using an iron with wick is risky as it's very easy to pull a pad if you aren't using the right tip or a shitty iron.
                                • Stiffmesiter
                                  • Dec 2022
                                  • 23
                                  Thanks for the suggestion on wicking - I don't have a hakko, so the hint was welcome.
                                  I have removed the chip and added pictures of each step (i.e. right after removal with flux on it, after I cleaned that, and then again after wicking). I also attached a picture of the chip bottom.
                                  Let me know your thoughts.
                                  Also, re-orderd a couple more U6903
                                  • reformatt
                                    • Feb 2020
                                    • 1416
                                    Right, looks much better than your original pics and pads look fine. You should just meter the pads out to other parts on the board just to make sure there are no hidden breaks at the pads themselves. Use the boardview for that.
                                    When you get the new IC, pre-heat the board with hot air. Once you are close to melting temp, put a small bit of flux down and place the IC on roughly in the right spot. Apply a bit of heat again so that it bonds slightly. Then let go with your tweezers, and heat till you see the chip move into place. Give it a nudge with tweezers and it should pull back into place. Then you should be good to go.
                                    • Stiffmesiter
                                      • Dec 2022
                                      • 23
                                      Thats good to hear, thanks!
                                      I will follow those instructions and update once the part comes in (usually 2 days). Fingers crossed it works this time.
                                      In the mean time, it appears that I have lost C6910, C6901 and C6909 during the cleaning. They appear to be non-critical based on the schematic, what are your thoughts?
                                      • Stiffmesiter
                                        • Dec 2022
                                        • 23
                                        Well, I put it back on, but don't think I did it very well. Sadly, I am at my peak with this machine/project and must move on. Thanks again for everyones help, I have learned ALOT!
                                        I would however still like to get this laptop fixed, if possible. So if anyone can recommend a good shop - preferably in Canada - that I can ship to, it would be appreciated.
                                        • mferna14
                                          MacBook A2159 820-01598 Stuck on 5V
                                          by mferna14
                                          Hi all, I working on MacBook Pro A2159 LB # 820-01598, it's just stuck on 5V. The two USB-C connectors on the side., when attached power adapter to one of them, comes up to 5.2V & nearly 0.32amp & then reset after about 15 sec. When attached the adapter jack to the second USB-C connector, it stays on 5.2V & NO amps taken. I took some measurements when the adapter jack was on the first USB-C connector. PPBUS_G3H 12.4V & it resets within 15 secs, & then it resets PP3V3_G3H_RTC: 3.29V, PP3V3_G3H: 3.21 & PP3V3_UPC_XB_LDO. I removed F7000 & check on Pin 1, PPBUS_G3H 12.4V...
                                          12-16-2022, 05:03 PM
                                        • stormanimal83
                                          Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                          by stormanimal83
                                          Hey....
                                          Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                          my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                          01-18-2024, 02:15 PM
                                        • ekozeko333
                                          [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                          by ekozeko333
                                          I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                          🔥 The Problem Started After Suspected ESD/PD Fault
                                          I experienced a power issue or ESD event through a USB-C charger
                                          After that, the NX20P5090 power switch was visibly burned and was replaced
                                          Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                          🧠 What I’ve Done So Far
                                          Flashed...
                                          06-21-2025, 02:48 AM
                                        • praveenramavath
                                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                                          by praveenramavath
                                          Hello All,
                                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                                          https://www.hifivision.com/threads/m...-screen.98243/
                                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                                          04-26-2025, 09:08 AM
                                        • Mess
                                          Motherboard diagnostic beginner advice
                                          by Mess
                                          To save you some time: the most important bits are in bold.
                                          Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
                                          Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
                                          09-12-2024, 07:02 PM
