DELL 5537 LA-9982P - not work after lightning strike
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3622
    • slovakia
    Hello.
    Have this DELL 5537 LA-9982P that not work after lightning strike to house.
    i replaced PQ701 but now have only 5.5V after it. ACDRV have voltage only for a moment when attach charger. BQ24717 have ACDET 2.58V, VIN 19V. Dont have this charger ic , can be replaced by other like 737?
    How to check if PSID is ok?
    MOD Edit: Schematic & boardview moved to new thread - https://www.badcaps.net/forum/showthread.php?t=122414
  • mon2
    • Dec 2019
    • 14630
    Re: DELL 5537 LA-9982P - not work after lightning strike
    Remove the 4k resistor on ACDRV pin. Check again to see if the proper ACDRV voltage to ground of ~25v is present at the charger IC.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3622
      • slovakia
      no voltage on ACDRV when removed PR703.
      • mon2
        • Dec 2019
        • 14630
        Confirm voltage on REGN pin # 16 of the charger IC.
        Next, remove all power, meter in resistance mode.
        Measure the resistance to ground of the ACDRV pin on the charger IC.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Was PQ701 new?? I still think PQ701 is faulty. Measure resistance on PQ701 pins between
          01. D1-D2
          02. D1-G
          03. G-S
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • Bardou Kari
            HP EliteBook 840 G6 – no power after lightning strike
            by Bardou Kari
            I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
            – Charger is OK and 19V is present at the motherboard.
            – No charging LED, no fan, no reaction.
            – I don’t see any 3.3V or 5V near the coils.
            – Battery is unplugged.
            – I’m new to board repair but can use a multimeter.
            I added a clear photo of the board.
            Any idea where to start or what to check next?
            Thanks a lot for your help!...
            07-01-2025, 10:45 AM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • SluggerB
            Panasonic TH-50PX80 killed by lightning strike, help me save her!
            by SluggerB
            Yes it's a 17 year old Panasonic plasma!
            I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
            06-04-2025, 07:02 PM
