ps4 power supply resistance out of order, what to choose?
  • fab13
    • Dec 2021
    • 109
    • France
    Hello
    After checking this resistor which gives no value on the ohmmeter on a PS4 SLIM power supply.
    I would like to change it but by which power I can choose it knowing that this resistor is on the primary part that is to say on the 230/400 V side
    Value 16.8 Ohm normally according to color code (See photo)
    1st ring = Brown = 1
    2nd ring Blue = 6
    3rd ring Grey = 8
    4th ring OR Multiplier = x0.1 Ohm
    5th ring Red = +/- 2 %.
    Tolerance of either + or - 0.336 ohms
    Dimension of the resistor Length = 6.4mm, Width 4.8mm
    Can I place one between 15 and 17 Ohm or a little more?
    What power in Watt I can order if it is 2W or 3W
    I don't want to do anything stupid about the value to choose
    Thanks a lot to you
  • lotas
    • Jan 2016
    • 4710
    • Russia
    Re: ps4 power supply resistance out of order, what to choose?
    This is a safety resistor, plays the role of a fuse (0.16 Om. 5%).
    • fab13
      • Dec 2021
      • 109
      • France
      Strange because it doesn't even sound continuous in this case
      • lotas
        • Jan 2016
        • 4710
        • Russia
        What is strange here, 3 stripes (silver) is a multiplier of x0.01.
        • fab13
          • Dec 2021
          • 109
          • France
          I was really surprised to see this silver stripe in the 3rd position, so I considered it as a grey color.
          I can't find any other information about a silver band in the 3rd place for 5 rings.Maybe it should not be taken into account then =S so I will have to calculate it as 4 rings.
          This would give 0.16 Ohm but tested in several modes Diode or megaohm the resistance gives nothing at all.
          Only I need an example of a resistor on the same power supply of a ps4 slim
          • R_J
            • 9582
            Is this the resistor at location F3? if it is, it is a 0.16Ω-2watt. Lotas post #2 is correct
            • fab13
              • Dec 2021
              • 109
              • France
              So the resistor is indeed 0.16 OHM which acts as a fuse we will say.
              I ordered a 2W and it is much smaller, so I took a 3W which is the same size and the power supply works now
              Many thanks to you
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I don't think I've ever seen a multiplier band of gray (and definitely not white), it's always been silver of that set of similar colors.
                Purple multiplier is rare enough as it is... I think I've only seen 1 or 2 ever.
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • cind12
                  GTX 1080 TI Gigabyte Aorus low resistance on vmem
                  by cind12
                  Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                  Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                  The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                  Resistance on 12V 4K ohms (Power present when on)
                  Resistance on 12V PEX 4K ohms...
                  12-08-2023, 09:09 AM
                • fab13
                  What value of resistance PS4 SLIM 17-160p1a power supply?
                  by fab13
                  Hello to all
                  I have this resistor from the PS4 SLIM 17-160p1a power supply that seems to be out of order. Does not give any Ohm or Kohm value ect.., neither diode, nor in continuity it must be cut.
                  I am looking for the value of this resistor ... What is strange the 3rd ring is silver.
                  Should I consider it as this?
                  Value 16.8 Ohm normally according to color code (See photo) or 0.16 Ohm
                  2nd ring Blue = 6
                  3rd ring Gray = 8
                  12-12-2022, 01:18 PM
