playstation 5 digital firmware dump
  • BD4ROQ
    • Apr 2025
    • China
    #181
    have i CFI-1200A, edm030, blown bios chip, can i have the bios file?
    thanks
    • Reliance Gaming
      • Apr 2025
      • St. Lucia
      #182
      Originally posted by Cobbes
      Here is a working dump from a edm-031 cfi-1216a with 69gg southbridge. Change at 0x001C7200 the console unique data (MainboardS/N and SerialNo)
      dude this worked on a edm-040! thanks alot!
      • kUiTs
        • Apr 2025
        • Estonia
        #183
        Originally posted by PedroMa74111271
        i guess im going to try to reflow the wifi chip. i bought this console with a 3 beeps of death, i dont know if the wifi issues was there before or if was caused by nor chip getting corrupted. Its just weird that the same bin file that was corrupted and was causing 3bod its now working.
        Anyway if anyone needs a bin file for a CFI-2016 B01Y (EDM-041) (it may have wifi issues)
        Thank you, your dump kind of worked for me (CFI-2016 B01Y, EDM-040, 69gg, J20H104), but yeah I now also have WiFi issues - MAC is not shown. Do you know if you have J20H100 or J20H104 WiFi/BT module?
        I the beginning I had DEAD console - no peeps, no nothing, Power draw was quick 58mA -> 8mA. BIOS dump showed some errors.
        I replaced values in your dump with my SN and MAC and now console works but no WiFi.
        BT works, update works, PSN games work, disc games work etc, only WiFi does not work.
        Power draw now is 254mA->14mA - kind of strange or not for slim?
        • Gamingrepairsukk
          • Apr 2025
          Looking for a clean dump of CFI-1216B, board EDM-030 if anyone have one thank you in advance
          • Darky777
            • Sep 2024
            • 5
            • Mexico
            #185
            Good afternoon, any good soul to patch my original 1015B dump with 3BOD with one working??? It will be very appreciated
            • igeektech
              • Jul 2017
              • 18
              I have a PS5 Slim CFI-2015 EDM-044 with the 3 beeps, pulled the BIOS file and need help with a good file if anyone can assist.
              • kUiTs
                • Apr 2025
                • Estonia
                #187
                try this
                • SoJustMe
                  • Jul 2024
                  • 5
                  • Saudi Arabia
                  #188
                  hi guys , need EDM-032 dump for 61GG please
                  i uploaded my currupted firmware
                  • igeektech
                    • Jul 2017
                    • 18
                    Originally posted by kUiTs
                    try this
                    tried this and still getting the 3 beeps unfortunately. Any ideas?
                    • umeediqbal80@gmail.com
                      • May 2025
                      Originally posted by Comp_Pro
                      Re: playstation 5 digital firmware dump
                      Here is a firmware dump for CFI-1015A. Note that it must end A. Copied from known working and it helped me fix a PS5 that had 3 beeps as soon as you plugged in the AC cable. I believe the board was originally also going to 30mA and then shutting back down.
                      Upon boot it is now asking me to reset the software, will update to see if software reset/update will work.
                      Hello, will this work for PS5 disk version?
                      • Maxpower3
                        Bad Veteran
                        • Feb 2018
                        • 1253
                        • France
                        #191
                        The name of the dump ends with .BIN but must be .bin for the PS5 NOR Modifier.
                        I've modified the Windows application to allow all extensions: .Bin /.BIN /.iso /.rom etc....
                        If this helps, please test and give me feedback.
                        I don't work on PlayStation.
                        If this bothers TheCod3r​ or the forum administrators
                        Please delete it.
                        • Jacksoft
                          • Feb 2011
                          • 36
                          • Italy
                          #192
                          Check what southbridge is on your cfi-1216a edm-030
                          After start, check if WiFi is working and showing its MAC in system infos.
                          Used this on a three beeps PS5 (CFI-1216A, EDM-033, CXD90069GG):
                          - Dumped original BIOS and extracted the SN and MB SN.
                          - Written on your BIOS SN and MB SN with The Coder cmd tool.
                          - Console starts! But LAN MAC address is different! (WiFi seems the same?).
                          - Replaced both MAC addresses in the new BIOS.
                          - Three beeps again. (Tryed also with another tool and same result)
                          Only works with JUST the SN and MB SN replaced. Why!?
                          Any suggestion? Could this affects online, PSN, etc?
                          • Cobbes
                            • Mar 2024
                            • 26
                            @Maxpower3: Nice. Thanks a lot. My dumps are saved as .BIN and till now I had to rename them in .bin to use TheCod3r's tool. Your modification is very handy.
                            @ Jacksoft: So, if you use the donor dump replace just the SN and MB SN, the PS5 starts. If you replace also the MAC for LAN and WiFi you get three beeps? Interesting.
                            Btw: If you have initial three beeps with the original NOR, please clear error codes and check if it is solve the 3BOD problem.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1253
                              • France
                              #194
                              For the WiFi Mac address, did you notice that it's written three times? With +1 and +2.
                              Click image for larger version  Name:	Nouveau Image bitmap (4).png Views:	0 Size:	375.4 KB ID:	3639083
                              Edit
                              Click image for larger version  Name:	image.png Views:	0 Size:	31.0 KB ID:	3639088
                              • Fenerlee11
                                • Nov 2016
                                • Türkiye
                                #195
                                i need edm 020 cfi-1116A bios for no power 3 beeps
                                • Jacksoft
                                  • Feb 2011
                                  • 36
                                  • Italy
                                  #196
                                  Edit
                                  Ah!
                                  Yes I noticed that but I completely forgot about bluetooth! So it could be because a mismatch!?
                                  I'll try and let you know asap!
                                  • jibril mohammed
                                    way big
                                    • May 2025
                                    • 8
                                    • Nigeria
                                    #197
                                    guys need a good dump for cfi-1216A edm-033
                                    • MIRROR6866
                                      • Jun 2016
                                      • 7
                                      • IRELAND
                                      #198
                                      HI, need help looking for CFI-1216A, EDM-033 CG69 working BIOS. please
                                      • Jacksoft
                                        • Feb 2011
                                        • 36
                                        • Italy
                                        #199
                                        Edit
                                        Fixed all the MACs but still three beeps. I gived up and keeped the old one from the dump. Console boot, goes online, joypad works, disc drive works.
                                        I noticed that WiFi MAC is still the original one and NOT that from the BIOS. Maybe it self-update by reading the chip infos?
                                        • Mason Hamilton
                                          • May 2025
                                          I'm looking for a BIOS dump for a EDM-031, model CFI-1215A, 61GG board — the disc edition
                                          • Ahari
                                            by Ahari
                                            I...
                                            08-13-2025, 06:12 AM
                                          • Tamo Neko
                                            Request for MX25VB8035F (1MB) Firmware Dump – Asus TUF Gaming H670-Pro
                                            by Tamo Neko
                                            I'm working on an Asus TUF Gaming H670-Pro motherboard and need help finding a firmware dump for the MX25VB8035F (1MB) SPI flash chip.
                                            What Happened:
                                            I mistakenly removed and erased this 1MB chip, thinking it was part of the main BIOS.
                                            • I later found that the board has two main BIOS chips (8MB + 16MB), which I have backups for.
                                            • My backup for the MX25VB8035F chip is just an empty 1MB segment filled with FFs, meaning I have no valid data to restore.
                                            What I Need:
                                            • A firmware dump for the MX25VB8035F chip from the same motherboard (or a compatible
                                            02-12-2025, 11:29 PM
                                          • Mephysis
                                            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
                                            by Mephysis
                                            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
                                            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
                                            03-27-2025, 02:34 AM
                                          • gun4as
                                            Need firmware dump for LG 23MP48HQ-P
                                            by gun4as
                                            Hello everyone, I have an LG 23MP48HQ-P with a mainboard EAX65543134. After a power flicker, the monitor only shows the "No Signal" message but goes to a black screen with a brief flash when an HDMI/VGA cable is plugged in. I cannot enter the OSD menu. All main voltages (18V, 5V, 3.3V) are stable under load. I made a backup of the firmware, but it was *after* the fault occurred, so my backup is likely corrupted. I flashed it back with no change in behavior. I can only find the firmware for the 24M38H model online. Could someone please share a working firmware dump for the 23MP48HQ-P?...
                                            08-25-2025, 04:28 AM
                                          • eurocomputerland
                                            Canon iSensys MF264DW II, firmware memory dump
                                            by eurocomputerland
                                            Hi, i have canon mf264 printer which is stuck in download firmware mode and I'm after a firmware memory dump for this model, so I can try to rewrite. Thanks for your kind help!
                                            07-22-2025, 04:48 AM
