Nintendo Switch missing 1.8v
  • WayOfTheRoad
    • Aug 2021
    • 59
    Hello eveyone.
    I have a Switch that shows the blue screen upon startup but it sometimes will boot to the first Nintendo logo (once fully, only to bsod after turning off).
    The time it booted I was able to get 1.8v on the test pads near the backlight connector and above the MAX77621 right below the NAND/emmc chip.
    However, it not showing a bsod is rare and I'm not sure what is causing the rare boot that aren't bsod.
    Is it correct that the MAX77620 produces 1.8v across the board or do the two MAX77621 produce it locally?
    Basically, I don't think schematics or boardviews for Switch exist but any documentation of the system rails anyone has would help a lot. Any tips or info is also greatly appreciated.
    I know people often just say to reflow or reball the Tegra chip but I'd like to resort to that last.
    Thanks!
  • SRO2
    Missing component on Nintendo Switch
    by SRO2
    While changing the charging connector on a Nintendo Switch, a component flew out because of the hot air coming from the hot air station... I would like to know if any of you know the reference of this component?
    I attach a picture with the location of the component. Thanks for your help!...
    10-11-2022, 03:30 AM
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • slimmy182
    Need HELP troubleshooting solid Blue screen Nintendo Switch BSOD
    by slimmy182
    I recently got a switch which did not turn on (blu screen and could not do anything). It draws 15v so battery is charging as normal. I opened it, it's never been touched by anyone, rose old thermal paste still there and foam attached to the heat sync. On microscope I did not see any sign of corrosion or any particular damaged components, only dust. Completely cleaned the board with isopropyl alcohol and give a try with no luck. I cannot exclude that this consol had not being dropped to the ground since it has a sing on external enclosure. Anyway detaching the eMMC screen did not light up and enter...
    03-22-2022, 05:04 AM
  • estabilito
    Nintendo Switch Oled dead
    by estabilito
    Hello, i bought dead nintendo switch oled.
    after plugging charger with amp meter device shows 5v and 0,0 or 0,02 amperage draw.
    I inspected motherboard and someone tried to reflow or replace m92t36 and didn't do it well, i resoldered it proper and find that usb-c fuse was blown too(replaced it).
    After this device started to draw 15v and something around 0,48 but only for few seconds after this returned to 0A draw.
    I tried to plug motherboard without battery - shows 15 0A and when charger was pluged i put battery back in then console started to charging battery but stuck...
    05-07-2024, 03:48 PM
  • tommy97
    Nintendo Switch Oled - Joy con charging
    by tommy97
    I'm having an issue with a Nintendo Switch OLED that suffered liquid damage. After a full cleanup and replacing the Joy-Con rails and joysticks, everything was working fine for about a week. However, now the Joy-Cons won't charge or connect again.
    I tested with a second set of Joy-Cons, and the issue persists. Measuring the voltage on the connector shows 3.7V instead of 5V, which I believe should be the correct value.
    Any insights or suggestions on what could be causing this?
    03-17-2025, 06:30 AM
