need some help to limit current after repair
  • petehall347
    • Jan 2015
    • 4426
    • United Kingdom
    ok i know its sort of a double post but also has its own merits . its something i can never work out .
    thinking of using light bulbs on the power supply outs 12v and 5v but don't know which lamps to use . i know all about limiting mains supply with light bulbs but obviously no use with switching supply .
    i have been working on a console . i did ask a few times but it seems my thread has gone cold for some reason .
    https://www.badcaps.net/forum/showthread.php?t=104579
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8695
    Re: need some help to limit current after repair
    Ideas are the same: what is the expected current, both expected average and "always safe" current. Whether you choose between one or the other depends on what condition you're trying to debug...
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      i don't have a clue as to what current it needs to run . i just don't want to risk fireworks when i power it up as i have replaced various shorted ic.s and a capacitor after an accidental short circuit .
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8695
        Definitely tough to choose a proper limiter if you don't know what the limit should be
        Always can start low and work your way up if you think it won't roast something however, just takes more time to ensure it's not a short and just normal power consumption...
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          i used dim bulb tester on the mains and fuses on the secondaries . found out 500ma is enough for 5v and 12v liked more than 1 amp so used 2 amps . was a bit interesting because 500ma was fine to start with for 12v . then after i had fixed the controller ic fuck up the fuses were blowing as it was then powering up so tried bigger fuses .
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Is this the thing you are working on? https://cdn.badcaps-static.com/pdfs/...89ae2aaa34.pdf
            • petehall347
              • Jan 2015
              • 4426
              • United Kingdom
              yes but the monitor console is different . i cant find a manual for this exact model .synchro exc 700ip
                • Jul 2011
                • 6032
                You could build a current limiter using a LM317 in current mode and a heat sink on the device
                and use a wall wart power supply
                If fact I have one that I use to use when charging nicad batteries back many years ago and it works very well back when Radio Shack had there 12 volt 3 amp power supply’s
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  You understand that there are three 700 models in the manual with different displays? On page 13 and 14 they have product codes that tell what machine one has. On page 15 is the serial number structure. On page 16 are the product characteristics of each model. In the Appendix 13 on page 193 is a password list.
                  In the model 700sp the sp stands for self-power brake board. I believe the model 700IP stands for Ingress Protection Code which is how much protection the case has for the electrical component. In this case it probably is IP20 listed on page 19. At little bit of a guess.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    pretty sure i looked at them all .not that it would really help too much as it doesn't go into servicing .. i have it booting up now but the touch screen isnt working and it keeps rebooting itself so must have damaged something when i did some damage to it .
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      It may mean it is looking for an input from the keyboard? The first thing is to identify what you have. Does it have a 16 alpha numeric product code on the machine?
                      Does it have a 14 alpha numeric serial number?
                      With the above numbers you will be able to tell what the machine is and you will also be able to tell the badcaps technical people what it is. On page 66 is the display being off without pedaling. This is the SP model and if the machine is not pedal then the display switches off in 30 sec. This is one example why the display may go off. SP means an alternator is generated by the person pedaling and it has a 12 battery back up.
                      Each block diagram shows the different way each model is connected. Further there is a theory of operation of each one. Just have to read them.
                      • petehall347
                        • Jan 2015
                        • 4426
                        • United Kingdom
                        there isnt a battery .
                        its a 700ip model will post a pic of label later
                        • petehall347
                          • Jan 2015
                          • 4426
                          • United Kingdom
                          id label
                          • keeney123
                            Lauren
                            • Sep 2014
                            • 2536
                            1
                            • keeney123
                              Lauren
                              • Sep 2014
                              • 2536
                              id label
                              This is part of a sticker showing. The other part is the D4 numbers. From this sticker we know that there is a 15 AMP fuse on the output side which is most likely DC? The 2X3 in front of the fuse is anyone guess. Mostly likely the physical size. The input of the device is between 100 to 240 AC with a maximum current of 0.85 Amps. Multiplying .85x240=204 Watts of power. One can never get more power out of something then they put into it. I believe the 240volts in AC RMS if it is not the case then the Peak to Peak voltage must be converted to RMS before the multiplication to the 0.85 of current. So we know that no matter where we go in the circuit the DC voltage will never produce more than 204 watts of power. So where there are high voltages there will be low current. Understand though that any voltage can kill a person if the resistance to ground is low enough. Is this the only sticker on this device?
                              I believe this is your model https://cdn.badcaps-static.com/pdfs/...bb22ccb277.pdf
                              This has the pdf for download
                              • petehall347
                                • Jan 2015
                                • 4426
                                • United Kingdom
                                might be it . will compare connector numbers .
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Here is a reference guide.
                                  Page 11 is 2009
                                  Here is a 700i e Manual from England. I know you have a Ip but it may help as I think your unit is made for Europe.
                                    Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                    The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                    The bq24745 features dynamic power management...
                                    10-23-2024, 02:50 AM
                                    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                    Narrow VDC applications where the system power source is
                                    either the battery pack or the regulated output of the charger.
                                    This makes the max voltage to the system equal to the max
                                    battery voltage instead of the max adapter voltage. Operating
                                    at lower system voltage can improve...
                                    11-05-2024, 04:43 PM
                                    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                    by sam_sam_sam
                                    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                    I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                    02-04-2025, 08:08 PM
                                  • Fritter
                                    Bulbs to avoid in current limiter
                                    by Fritter
                                    Just putting my first current limiter together (uk). Apart from led's, are there any bulbs that will not function as needed? Any advice much appreciated.
                                    10-31-2023, 11:24 AM
                                    Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
                                    The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
                                    All AP21X2SG-13 AP21X2MPG-13 devices are available...
                                    10-23-2024, 03:33 AM
