Playstation 2 PSU zener diode values (ZD1 and ZD3)
  • Technomancer
    • Nov 2021
    • 20
    I am attempting to repair a PS2 PSU that died a horrible death when the Q1 mosfet shorted. There are 2 diodes that I believe got taken out along with the main fuse when that mosfet went, ZD1 and ZD3. From the searching/reading I've done on the topic, ZD1 can look like its failed when a continuity check is done in circuit as there is a .25 Ohm resistor in parallel with it. I'll pull ZD1 out of circuit to check it to be sure. ZD3 I'm pretty sure is gone as its showing a 0 voltage drop on my meter in both directions. (Just pulled and checked them both and they are blown).
    Does anyone happen to know the values of ZD1 and ZD3? I wasn't able to find a good schematic for any of the power supply variants that I know of (shocker, I know) but there was a forum post of someone who mentioned that they used 18V zener diodes. From my limited knowledge of zener diodes though, there are 2 voltages to consider. The zener voltage and the voltage at which the diode fails (breakdown voltage?). I assume they are referring to the zener voltage in this case.
    Any help you can offer would be greatly appreciated.
    Here is a link to that thread where the guy said he used 18V diodes for ZD1 and ZD3: https://www.reddit.com/r/consolerepa...ly_for_my_ps2/
    Here is the PSU that I have which is slightly different that his (1-468-634-11): https://gbatemp.net/attachments/19-jpg.258976/
  • CapLeaker
    Leaking Member
    • 8179
    Re: Playstation 2 PSU zener diode values (ZD1 and ZD3)
    First thing is to upload some high resolution, straight shot pictures of your PSU. Usually the diodes have a marking stamped on it... can you read anything on them?
    • Technomancer
      • Nov 2021
      • 20
      Looking at the diodes under the microscope, the both have the following markings:
      A
      TXZ
      18
      I assume the 18 is the zener voltage. If you still need a closeup of the board, I can probably get that too.
      • CapLeaker
        Leaking Member
        • 8179
        It's always a good idea to include pictures. A high resolution, straight shot picture can say 1000 words. It also tells the reader what version board.
        I guess you answered your own question about the 18V zener diode.
        • redwire
          • 3910
          It would help to know the SMPS IC being used, on the back of the board.
          If ZD1 is across a 0.25R sense resistor, no way it's 18V as that's 72A across it before it turns on. Usually there is no zener across such a resistor.
          • Technomancer
            • Nov 2021
            • 20
            I grabbed a couple of pictures of the board as well as the IC on the back:
            Front - https://imageshack.com/i/pnZUUw7nj
            Back - https://imageshack.com/i/pnSxqhWUj
            IC - https://imageshack.com/i/pnYX7Omyj
            • CapLeaker
              Leaking Member
              • 8179
              None of those links work for me.
              • Technomancer
                • Nov 2021
                • 20
                Strange, they work ok for me. Try these instead:
                Front - https://imagizer.imageshack.com/img923/6246/ZUUw7n.jpg
                Back - https://imagizer.imageshack.com/img923/207/SxqhWU.jpg
                IC - https://imagizer.imageshack.com/img923/457/YX7Omy.jpg
                • R_J
                  • 9550
                  You should attach the photos to your post so they don't disappear like the links do.
                  The zeners are very likely 18v but there is likely other damage, like the ic.
                  It is common to have a zener diode across the source resistor, it is there to provide some protection for the CS input of the ic (which is only about 1 volt) but it doesn't always work.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    As R_J said please attach them here instead.
                    I have attached your pictures to this post.
                    • redwire
                      • 3910
                      I analyzed the circuit enough to figure out those some values. PS2 power supply board 1-468-634-11, Delta ADP-75EP. SMPS IC is DAP002 apparently = ST L5991 pics did work ok for me.
                      It's usually the small caps C3, C20 that fail Badcaps Sony Phat PlayStation PS2 power supply repair
                      If the mosfet shorted and failed, then check current-sense resistor R18, if open then ZD1 is dead, check R10 1k if blown then IC might have bought the farm. The mains fuse is supposed to cover for this though.
                      Mosfet gate-drive: Check R9 20R 1/4W, ZD3, check R11/R15 if cooked then IC might have bought the farm...
                      ZD1 ?V current-sense resistor R18 clamp (would be 2.7V-5.6V zener, IC max is 6V)
                      ZD2 15V some overvoltage shutdown
                      ZD3 18V mosfet-gate drive protection
                      ZD4 ?V (mains) overvoltage shutdown
                      C3 33uF 35V (common failed part) SMPS IC power
                      C20 22uF 50V (replace too) maybe soft-start
                      R18 0.27R 3W current-sense
                      R9 20R 1/4W mosfet gate-drive
                        master hoarder
                        • May 2008
                        • 12175
                        • Bulgaria
                        And while at it, probably also a good idea to replace the output caps too. Generally speaking, the older Ltec from back then don't seem to fail as much as newer ones... but might as well take that out of the equation too.
                        • Technomancer
                          • Nov 2021
                          • 20
                          I appreciate the help with this one! I'll double check those resistors but I'm pretty sure they all measured ok when I looked at it a week or so ago. Certainly couldn't hurt to replace those caps while I'm at it as well as you suggested. I'll let you know how it goes once I get those components in from Digikey/Mouser.
                          Sorry about the photos. I didn't realize that I could upload them so I just linked them earlier. A couple of other forums I was on a while ago didn't let you upload things so I had gotten in the habit of just hosting them on ImageShack and linking them. I'll keep that in mind for next time.
                          • Technomancer
                            • Nov 2021
                            • 20
                            Ok, I finally got the parts in for this power supply. As I mentioned before, it needed the 2 15v zener diodes (ZD1 and ZD3), the Q1 MOSFET (K2545), a new main fuse, and the .27 ohm resistor R18 (between ZD1 and ZD3 in the top down picture). I powered up the supply and of course it still has issues. The drain of the Q1 MOSFET is getting 170v, which is good (I think) but the gate pin reads 0v. I checked the R9 (20ohms in circuit), R11 (30.8k ohms in circuit), and R15 (2k ohms in circuit) and they don't appear to be blown. Pin 7 of the DAP002 is 0v when I had it powered on. Is there any other inputs I should check to that IC to know if it's bad or should I just be looking to replace it at this point?
                            • redwire
                              • 3910
                              Pin 8 is power for the SMPS IC and it won't start until over 9-16VDC.
                              If there is low voltage at pin 8 (same as across C3) I would say the IC has shorted, but there are a few parts like C3 that could be toast but not likely.
                              It might be hiccuping, trying to start up. I would be using a series light bulb limiter when messing with it.
                              • CapLeaker
                                Leaking Member
                                • 8179
                                That C3 starter cap would be my first guess too.
                                • Technomancer
                                  • Nov 2021
                                  • 20
                                  I did some measuring the morning and saw 11.5v across the C3 cap. I also measured all the pins on the DAP002 and came up with the following:
                                  1: .056v
                                  2: .071v
                                  3: .005v
                                  4: .065v
                                  5: 5.46v
                                  6: .036v
                                  7: 0v
                                  8: 11.5v
                                  9: 11.5v
                                  10: .001v
                                  11: 0v
                                  12: 0v
                                  13: .080v
                                  14: .858v
                                  15: 0v
                                  16: .074v
                                  I can't say I have used a series light bulb limiter before. Is it just a test light that will start flashing if there is intermittent voltage on the line? If so, (and until I get one of those), would any of the test settings on the Brymen 869s catch the voltage pulses in the meantime?
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    Pin 4 (VREF) - voltage seems way too low. Should be 5V.
                                    Of course, that could be due to voltage on pins VCC/VC is going up and down due to PSU hiccuping (i.e. trying to start.)
                                    Check SMD resistor R6. Also check diodes D2 and D4. If they are good, replace C3. If that has already been done, you can insert about 15-17V DC on pin 8 (VCC) of IC1 through something like a 100-200 Ohm resistor. Before you do that though, make sure you use the series incandescent bulb on the AC of the PSU (see below) and also your voltage source for inserting 15-17V DC must be ungrounded / not ground-referenced (typically 2-prong "wall-warts".) When you insert the voltage, see if pin 4 (VREF) goes to 5V.
                                    See this:
                                    https://www.badcaps.net/forum/showpo...4&postcount=70
                                    You can use either an incandescent or a halogen light bulb. Must be rated for 120V, obviously (or 220-240V for those who do this in countries with 220-240V AC line.) 40 to 100 Watts rating should do - just make sure you have the PS2 disconnected from the power supply. You cannot use the series incandescent bulb on a PSU that has a load on its output - not unless the bulb has a high enough power rating (several hundred of Watts... or just many bulbs in parallel.)
                                    But anyways, the idea is that if something shorts in the PSU, you won't blow the fuse or any other part, because the bulb will limit the current (and power) going into the device.
                                    Incandescent bulbs are indeed hard to find now... but "decorative" or "appliance" incandescent bulbs should still be easy to find (typically limited to 40 Watts, so grab two and wire them in parallel as if it was one 80 Watt bulb.)
                                    • unimatrix93
                                      TV backlight zener diode
                                      by unimatrix93
                                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                      The led strips has 9 6V leds.
                                      02-10-2025, 12:13 PM
                                    • caspian
                                      What Zener Diodes on a Linear Power Supply
                                      by caspian
                                      Dear members,
                                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                      In addition, I discovered that its zener diodes are defective.
                                      I can replace the burned transistors.
                                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                      Therefore, I cannot replace the zener diodes.
                                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                                      no schematics are available...
                                      05-26-2025, 12:38 PM
                                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                      by sam_sam_sam
                                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                      I bought this from an eBay seller but unfortunately they only had one
                                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                      I bought three of from them to also make battery packs with this output power limit in mind
                                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                      04-23-2025, 05:50 AM
                                    • nev1001
                                      What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                      by nev1001
                                      Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                      The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                      It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                      I think an issue could be a zener diode (or capacitor) which has shorted out.
                                      The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                      04-17-2025, 05:09 PM
                                    • Vincenzo2
                                      Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                      by Vincenzo2
                                      My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                      Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                      I put some pictures here to show that it is labeled "M7"....
                                      09-07-2023, 07:43 PM
