Re: Motor control board repair
Let us know if you were able to fix this board issue or not
Well, I found the problem causing no -15V. It's the connector. It's not making good contact, but I'm sure I accidentally bent that pin when I was originally trying to measure transformer output voltages. So I'll have to either fix that or replace the connector. I've seen this type before so I assume I can find one.
So now I guess I power it up on 120V with attention to that connector and see what I get.Leave a comment:
That proves the bridge rectifier and the rest of the -15v circuit is ok. The fault is then with either the transformer not supplying the a/c to the bridge or there is a break (or small fuse) between the transformer and the bridge rectifier.
I hope the transformer was NOT connected when you applied the 20 volts to the bridge? if it was that may have opened the winding on the transformer as the winding would be a very low resistance to the 20vdc.Last edited by R_J; 11-17-2021, 06:48 PM.Leave a comment:
I suspect you have the -15 volts, It was only missing because the main transformer was not being used.Leave a comment:
Yes, it does. I measured half an ohm (0.5 ohms) resistance on the traces. The letters and numbers on the apparent BR are LBA 63.Leave a comment:
It should be ok, but you could also just check the resistance like I said. The transformer winding should connect directly to the ~~ connections on the bridge rectifier.Leave a comment:
If this machine has a step down transformer that supply’s power to this board look and see if it says 110 volt or not because if does do you know if your facility has a hot leg if it does then you might have the transformer on the wrong set of legs because if the step down transformer says 110 to 120 volts output
Because I has this happen to me one time and when I switch the legs to a certain way I got the correct voltage however do not change the machine main power supply legs unless you do NOT have any other motors on this machine because your rotation might be wrongLast edited by sam_sam_sam; 11-12-2021, 10:43 PM.Leave a comment:
Is it going to be safe to power up the board with 120VAC? That's about 10% higher than the 107V at the machine. I assume any voltage regulators should be able to handle that but just wanted to check first since I've not dealt with something that is expecting 107V.Leave a comment:
It looks like the -15V goes back to SR3 and the voltage regulator that doesn't get warm, AVR2. From looking at the trace lines and from the meter, it seems like the AVR2 is in parallel. SR3 has a + and - and two middle pins that go to the AC input, so it seems like a rectifier bridge, but I don't know what the SR3 designation could mean. Any ideas?
If you are not getting any a/c to the bridge, check the resistance of the traces and the power supply winding that supplies that circuit.
What is the part number on SR3?Leave a comment:
Black square thing with four pins on the corners, a hole in the center, and a notch cut from one corner is a bridge rectifier. Can't see the designator, need more pictures from different angles so we can tell what you're talking about.
Have to say it's highly irregular to have AVR1 and AVR2 in parallel, then again they being identical parts? What are the part numbers? Why does AVR1 look like it peeled from the heatsink?
oh...so avr1 and avr2 are not parallel as the G pins are not connected, so one of them is being used strangely for bipolar supplies?
Still a mystery what part numbers they are and how they're connected to the rest of the board...Last edited by eccerr0r; 11-12-2021, 12:36 AM.Leave a comment:
107vac is likely that they have 3 phase power supplying the building and they use one phase to supply the board, this is normal.
Locate the source for the -15v, trace the -15volt point back, the ac for this circuit is likely supplied from the transformer and then through a diode or bridge to give a negative voltage.Leave a comment:
That was with the power supply. I finally got a chance to try the board in the machine and the input voltage was 107VAC.. not sure why it's 107V because that is just outside the typical 110-120VAC. Either way, in that case the -15V was also missing, and I was still getting about +1V on that rail, so my first task will be to get that figured out and repaired.Leave a comment:
When you checked for the missing -15 volts, was that using the main transformer with 120vac applied or was it when you used your 24vdc bench power supply?Leave a comment:
I applied 120vac to the primary and here's I measured with green as ground:
grey one is 10V
blue one is 40V
purple is 2.25V
yellow is 5V
orange is .5VLeave a comment:
Either the -15V rail has wimped out and collapsed, or something is overloading the -15V regulator. It's not good for IC's and semi's power if a -ve rail goes +ve. I would put a reverse diode from each of the two rails to GND, to keep working on this.
The two VREG's look like on the main board two big heatsinks, the IC's are TOP-3 packaged, one says G/IN/OUT.
The second board has a bunch of dual diodes and transistors, I don't see a voltage regulator in the line up.Leave a comment:
I'm going to check the linear input transformer by disconnecting it from the board and applying 120VAC to the primary windings and see what all the outputs are. If everything looks good there, I'll connect up the board to 120VAC through an isolation transformer and see what happens. Got to get the supply voltages worked out first before checking anything else.
I've gotten more information about the problem. The outputs for one motor work, but not for the other motor. The maintenance guy switched the non-working motor to the contacts for the working motor and the motor worked, so it's probably something in the output, although it might be a problem on the input side too.Leave a comment:
photo of the tracks on the back side of the board? does not seem right that two apparently "GND" ports are not grounded/tied together - unless the company was playing tricks with virtual grounds and using the same BOM device for both rails... Or the silkscreen is wrong and the chips on the heatsink are different, still don't know what they are...Leave a comment:
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
Assuming...7 Photos -
by YanlebHi all, I just want to share the repair of my 60PK550-UA TV set.
The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
C57: 3.30V
C61:...07-20-2023, 12:38 AM -
by Joe24Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
I've been over the board looking for... -
by redoxyI am looking at the option of replacing my control/driver board to one with HDMI and/or Display port input on a 2K LED (I think IPS) screen.
The display is Samsung LTM270DL07.
I have tried using the model number to search for a compatible control/driver board but so far my efforts have been futile.
I am looking for inputs on what board could potentially be used for my display.
Attached are pictures of the display label information and connectors (CON30 CON40 only) and pictures of the current control board.
Also attached is a technical...-
03-14-2023, 08:52 PM -
- Loading...
