Micronta Talking Alarm Clock Full Recap
  • redwire
    • 3912
    Re: Micronta Talking Alarm Clock Full Recap
    Conventional clock IC's relied completely upon 50/60Hz mains AC reference for timekeeping. Of course this does not work if a power failure occurs, as well as the alarm resetting to 12:00 blink blink blink and you will be late for work lol.
    This Micronta is using (the first ever) low cost TI MCU TMS1100 and note there is no quartz crystal. That means for battery backup (7 of AA batteries) it runs off a sloppy RC oscillator but otherwise uses mains for timekeeping. Battery backup was needed because of the hassle setting date/time and other parameters so this was an early clock to have battery backup.
    I could not download the VoxClock 3 (Cat. 63-906) owners manual manual and schematic here
    https://dokumen.tips/documents/micro...06.html?page=1 and it's on ScribeD as well, but you can see the MCU gets AC ref fed into it so it used mains for timekeeping.
    • ClockChip
      • Jul 2023
      • 14
      Originally posted by jayjr1105
      I have this clock back in my possession. My grandfather claims it still acts weird after some time. I'll take it apart and give it a closer inspection for cracked solder joints.
      Could you offer any advice on the best way to get the case open without damaging it?
      I have only ever heard of one other person attempting to open up this particular model of clock. According to his description of the task, the case tolerances were so tight, he felt as though he was breaking it in his attempt to get inside.
      Did you have a similar experience when you first opened the case?
      • ClockChip
        • Jul 2023
        • 14
        Could the OP please post an update? I would be interested to hear what he found during his second visit inside the case and whether he was able to restore the clock to full working order.
        • shelby5041
          clock radio / radio lifespan?
          by shelby5041
          hi
          ive got a modern digital clock radio approx 15yrs old
          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
          it uses very little power just a few watts i would imagine that may have something...
          09-14-2024, 03:30 AM
        • Tom41
          Honeywell Accenta G3 tamper alarm
          by Tom41
          This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
          I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
          08-31-2023, 04:00 AM
        • jm1234
          Projection display radio - some segments not lighting up
          by jm1234
          alarm clock radio Oregon Scientific RRM320P, it projects the time on the seiling.
          However only part of the segments is lighting up. Any idea what could be behind this issue?
          Note I'm NOT talking the main display here....
          11-11-2025, 04:21 AM
        • slybunda
          Alarm Siren issue
          by slybunda
          Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
          Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
          took siren out of the car and checked it out and pics attached seem to be the source of the issue.
          shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
          getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
          02-04-2024, 11:01 AM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
