Does anyone know about 16x2 LCD screens used in alarm keypads?
  • Ady2017
    • Dec 2017
    • 55
    I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was and what replacement screen and driver it might need? Working on 16x2 screens is new to me.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8724
    Dunno what he does to it, but for some reason after the repair the GTAG does no longer function. Wonder why?
    The 4 wire keypad LCD display can be repaired but the GTAG Will no longer function
    The 6 wire keypad LCD display can be repaired but the GTAG Will no longer function.
    Repair models include 595 600 490 490x and 800 series​
      • 31833
      the display is a regular parallel interface display,
      you can get them in lots of colours but also different payouts.
      so if you buy one on aliexpress or wherever, make sure it's got the same hole spacings for the screws and the connector is the same.
      yours has the connector as a single row top-left, you can also get the with the connector on the bottom or as 2 rows on the side.
      but electrically theyare all the same.
        • 31833
        maybe show us what it connects with?
        • Ady2017
          • Dec 2017
          • 55
          Here are some more photos of the keypad. It is very hard to find a reasonably priced working keypad for these alarms. It is put me off buying another Risco alarm. I am not very happy that the engineer locked their own code into it as well so would install one myself next time.
          When I tried replacing the screen on this one, I disturbed a very small bit of glue holding the G-Tag wiring and the G-Tag now no longer works so it is something to do with the effect that it has on the coil.
            • 31833
            check the display is getting 5v
              • Jul 2011
              • 6085
              • Soldering Junkie
              What controller ic chip does it have on the main board
              It has been my experience that when you have LCD screens controllers are not the same even if they are the same model number you have the LCD command loaded on the controller for it to work correctly
              Because one time I was doing a microcontroller with a LCD screen controller display that I had not used before and because the routine was not run every time you turn on the device it would not display any thing at all but once I complied the program again now it shows up on the new LCD screen this could be issue here
              • redwire
                • Dec 2010
                • 3952
                The main difference between these LCD displays is the how the LED backlight is done. What pins for it, dropping resistor etc.
                What happens when you rotate the contrast trimpot? You should see the pixels darken... or lighten.
                Wait - is that a display heater or some nutty LED backlight in your pics? To "A1" "A2".
                • Ady2017
                  • Dec 2017
                  • 55
                  The wire coil that connects to A1 and A2 and goes around the LCD is the pick up coil for the G-Tag. I suspect that there is some kind of driver issue with this with the driver being loaded into one of the chips that are located underneath the LCD. I think I have gone as far as I can with this project without knowing more about how that LCD screen talks to the rest of the LCD board.
                    • 31833
                    well - now you know
                    • Ady2017
                      • Dec 2017
                      • 55
                      Thanks. After reading this I can seen that the LCD has to be programmed which is what the problem is as I am only getting a single line of black blocks from it.
                        • 31833
                        programmed?
                        it's a passive device, you just write the text to it together with stuff like position.
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5385
                          • New Zealand
                          • Electronics and computer repair
                          Is the LCD module shown in your photos, the original, or the replacement?
                          The LCD modules already have the required program code in them to operate. You just need to send them the appropriate display data. The only "programming" that's really done is if specifying custom characters to be displayed, but this is also just data sent as part of normal operation (if that feature is being used)
                          (see https://en.wikipedia.org/wiki/Hitach...ontroller#Font)
                          The likely problem here is that your old display and the new display have different controller chips (HD44780 is one, but there are alternatives like SPLC780, KS0066, S6A0069)
                          They all function pretty much the same, but can have slight differences in timing requirements.
                          I expect your issue here is that your alarm CPU is sending the right commands to your LCD, but that the data is not being sent exactly at the right times, so it messes up and doesn't display correctly.
                          It's also possible there is some other fault with the unit as well, like the CPU stuck in reset or a missing voltage rail etc.
                          -David VanHorn
                          • diamon
                            Issues with new Surface Pro 5 screens
                            by diamon
                            I have three Microsoft Surface Pro 5 model 1796, with all cracked screens.
                            Have bought from Aliexpress three new screens, the part numbers from my and the seller are the same:
                            Bad working China screen part number:
                            Good working own screen part number
                            Error I get with the bad working China screen:
                            No error with the good working own screen:
                            All the three China screens (all the same exact part numbers) produce the same error in Device manager. Have also performed a clean installation...
                            06-25-2023, 01:41 PM
                          • slybunda
                            Alarm Siren issue
                            by slybunda
                            Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
                            Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
                            took siren out of the car and checked it out and pics attached seem to be the source of the issue.
                            shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
                            getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
                            02-04-2024, 11:01 AM
                          • M.gonc78
                            Websites where you can buy laptop screens
                            by M.gonc78
                            Do any of you know of websites where you can buy laptop screens at low prices, other than eBay or AliExpress? Because sometimes i have screens that are too expensive to recondition and so buying a laptop for parts is cheaper. I'm located in France.
                            Thank you.
                            10-05-2025, 02:27 AM
                          • Tom41
                            Honeywell Accenta G3 tamper alarm
                            by Tom41
                            This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
                            I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
                            08-31-2023, 04:00 AM
                          • Mcfeetroy
                            Fishing bite alarm drains battery
                            by Mcfeetroy
                            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
                            08-01-2025, 03:52 AM
