PS4 - Weird BLOD Problem - Still Turns On Sometimes
+ More Options
Posts
  • Patty
    • Apr 2021
    • Scotland
    Hi folks!
    I'm new here. And I'm new to the world of electronics and repair. My PS4 suffers from the blue light of death. I have tried the washer method, cleaning it and replacing thermal paste and also replacing the hard drive.
    What's weird about this blue light of death is that it will boot up, but when it restarts or is turned off it won't turn back on again unless it's left for a significant amount of time. Usually a few hours to a day or two.
    Would this still be an APU problem or is there anything else I could look into checking?
    Your help would be greatly appreciated.
    Thanks folks!
  • newbie_unlocker
    • Jul 2021
    • 17
    • england
    Re: PS4 - Weird BLOD Problem - Still Turns On Sometimes
    blod can be many things I would suggest to reflow all the ram chips as a starting point. the chips are a lot smaller so temp setting should be around 200 degrees and flow each chip for around 90 seconds each one, also use flux, best is kingbo rma flux and mask off any other small components that might be near the ram. let us know how that goes.
    • survivalbloke
      • Aug 2021
      • 268
      Exactly which PS4 model is this? As newbie_unlocker mentioned, there are a ton of causes for BLOD and it would help to know which version of the console you're running. Launch consoles were most affected by the APU solder connection issue which is very commonly remedied with the washer trick. The newer models like the pro however, don't generally have the same issues.
      • Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
        by Stephen
        MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
        03-15-2024, 09:37 AM
      • www
        LG L192WS-BN backlight turns off after 1 second
        by www
        I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
        I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
        03-24-2024, 05:26 PM
      • andrhouseolly
        Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
        by andrhouseolly
        Hi.
        I kindly ask you to help me solve the problem.
        Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
        The board turns on, there is no image.
        Read more. When the power supply is connected, the front panel indicators light up briefly.
        When you press the power button, the button indicator lights up. The board works
        there is no image, there is no matrix initialization, there is no image on HDMI.
        When turned on, the fans do not spin, but when they warm up they start spinning.
        When you turn off the button, the fans spin up to full speed for a short...
        05-11-2024, 03:14 PM
      • Egidio85
        Samsung UE55F8000SZ Turns on and off immediately
        by Egidio85
        good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
        This defect happens continuously, hearing the classic click of the relay every time.
        Power supply board BN44-00636B
        disconnecting the mains and lamps from the power board always causes the same problem.
        Is it normal that without anything connected this power supply turns on and off cyclically?
        any suggestions on what to check?
        thanks in advance
        03-11-2025, 12:45 PM
      • mostachio
        Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
        by mostachio
        Hi Badcaps,
        I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
        TV Details:
        Model # - TH-65DX700Z
        Symptoms:
        The television turns on and displays a picture then makes a clicking sound and turns off.
        I haven't opened it up yet but...
        09-04-2024, 02:32 AM
