xbox aerogel cap
  • bluto
    • Oct 2007
    • 560
    xbox aerogel cap
    This has been documented elsewhere, but I thought I would bring it here for good measure.
    I recently decided to figure out why my xbox would lose the system time immediately after being unplugged. I recalled that there is no clock battery, but instead some kind of 'super capacitor' or so they say. Turns out this 'super capacitor' or aerogel capacitor is not so super after all and was leaking its electrolyte inside my xbox (and most every other xbox in the world too).
    I found some posts where folks said that their xbox started acting up because of it and few even shorted out and released the magic smoke because of the electrolyte on the board.
    Fortunately neither of my two xboxes (both 1.0 version) had not suffered this fate yet. I ordered some replacement aerogel caps from digikey and fixed both of my xboxes at the same time. On the first one, I knocked off an SMD capacitor (C7G6) which was compromised and corroded by the electrolyte spill. Luckily, the machine still works without it. Does anyone have any idea on how to figure out what the value might have been? It appeared to be connected in parallel to the small 'lytic cap right next to it, I am thinking that means it didn't do much
    The digikey part numbers that you can use for the aerogel cap are as follows:
    283-2776-ND (1.0F 2.5V aerogel) [stock value]
    283-2780-ND (3.3F 2.5V aerogel) I used these for a ludicrous amount of extra clock backup time.
    My pictures of the damage didn't turn out so the first picture is shamelessly re-posted from another thread. The second pic is my recapped board with the missing SMD cap at C7G6
    If you still enjoy your xbox, you should open it up and check for leakage. If nothing else, just remove the aerogel cap and clean up the mess. The xbox will work without it, there will just be no hope of the clock backup working. Amazingly enough, all the standard electrolytic capacitors on the board look just fine.
    • 31280
    Re: xbox aerogel cap
    dont replace them, just leave the space empty.
    the clock uses so much power that even a lithium battery wont last.
    (design fault)
    a 1.6 wont start without a cap, but older boards dont need one.
    • bluto
      • Oct 2007
      • 560
      Why should I not have replaced it? Is the risk of the new one eventually leaking the main reason?
        • 31280
        yes, it will fail pretty fast.
        and it's not really needed because almost nothing uses the clock.
        • cheese007
          • May 2009
          • 85
          Oh good, right after fixing the broken solder joints on that damn FOXLINK PSU too! Glad to know about it though. I almost lost the XBOX to that one, don't want the repair to be in vain.
          • 370forlife
            Large Marge
            • Aug 2008
            • 3113
            Foxlink, actually foxconn brand, their re-branding of delta. Didn't know they called the one in the xbox a foxlink too, I would have thought Microsoft would have bought straight from delta.
              • 31280
              some are delta, others are fox.
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Foxconn = delta, only OEM's foxconn used is delta/newton and deer.
                Foxconn started to use delta when dell started using them for psu's. They knew their earlier deer units wouldn't cut it with dell.
                  • 31280
                  they arent "Foxconn", they are "Foxlink" btw.
                  i just looked at one.
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    Foxlink Group is Foxconn's parent company.
                    • cheese007
                      • May 2009
                      • 85
                      Who makes the minebea one?
                        • 31280
                        i'v been in over 100 xbox's and never seen minebea, it must be an aftermarket replacement.
                        there were a few replacements made, 1 was universal 100-250v inout, one was even a buck/boost design with 12v input for cars.
                        • 370forlife
                          Large Marge
                          • Aug 2008
                          • 3113
                          Minebea is NMB, they make their own psu's AFAIK. I've never seen a Minebea in a xbox, but I do see a Minebea fan in them.
                          • weirdlookinguy
                            • Sep 2007
                            • 1638
                            I had a refurbished xbox for a bit and it had a NMB/Minebea PSU in it. Maybe M$ used them as replacements?
                            It was really nice with TDK transformers and all japcaps.
                            • cheese007
                              • May 2009
                              • 85
                              http://secure.llamma.com/catalog/pro...roducts_id/489
                              • Xboxoriginalfan94
                                • Usa
                                🌟🌟🌟Could you explain to me how to remove the aerogel cap and where it is located on the motherboard?🌟🌟🌟
                                • mariushm
                                  • May 2011
                                  • 3799
                                  You can see it in the pictures he posted ... it's the big one that says B-Series on it
                                  And you remove it like you remove any capacitor... heat the wires from the bottom and pull it out.
                                  • rogerTrutman
                                    • Apr 2014
                                    • France
                                    thanks for this infos !
                                    I'll do it !
                                      • 31280
                                      aerogel caps are evil - throw them away!
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        so thats how my brothers old XBOX got toasted.....
                                        Follow the white rabbit.
                                        • MORETTIGIAN
                                          Capacitor detached from PCB – RTX 2070 Super Founders Edition
                                          by MORETTIGIAN
                                          Title:
                                          Description:
                                          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                                          I did not notice it detaching, so I am unsure of its original location on the PCB.
                                          Procedure performed:
                                          - Removed backplate
                                          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                                          - Reapplied thermal compound
                                          - Reassembled card
                                          Observed behavior after reassembly:
                                          - GPU powers on and operates normally under...
                                          09-18-2025, 12:14 PM
                                        • Destroyer-Br
                                          [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                          by Destroyer-Br
                                          I'm working on an Acer Nitro 5 unit with the following specs:
                                          • Motherboard: LA-J871P Rev: 1B
                                          • Model: Acer AN515-55-59MT
                                          • S/N: NHQ7JAL00403906A973400
                                          • SNID: 03902728734
                                          Initial Issue
                                          The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                          After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                          04-17-2025, 08:18 PM
                                        • TMTGTR
                                          An Xbox One PSU Odyssey
                                          by TMTGTR
                                          Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                                          =>Background:
                                          I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                                          06-17-2022, 05:40 PM
                                          HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                          09-12-2024, 02:00 PM
                                        • grimacelord
                                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                                          by grimacelord
                                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                                          10-24-2024, 12:31 PM
