Gardena R38li lawnrobot mainboard power issue
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    Well i have this Gardena R38li lawn robot, that is giving me a headache. it had a blown somthing and a bit of corrosion on it.
    attempt no 1. when i put the battery cable in, it shuts off the 18 volt battery.
    attempt no 2. i tried soldering a new cap in where the blown thing was, battery still shuts off.
    attempt no 3. desoldered the cap from attempt no 2, used and external powersupply and it instantly draws 6 amp at 12 volt (max on my gauge).
    but i never can measure a short from + to - .
    please help me, get this thing alive again
  • Stigsolbjerg
    • Mar 2020
    • 33
    • Danmark
    Re: Gardena R38li lawnrobot mainboard power issue
    Here is some pics off the board
    • CapLeaker
      Leaking Member
      • 8352
      how do you figure that actually a cap was there first place? Trace both pads and see where they go.
      • Stigsolbjerg
        • Mar 2020
        • 33
        • Danmark
        Hi Capleaker, that was also one of my problems. I thougt it was the most obvies, since there is this giant forum named after it. But i asked in a robot forum, for close up pics of the board.
        Do you have better idea than a cap?
        • CapLeaker
          Leaking Member
          • 8352
          could have been a diode, a resistor, a jumper (0 Ohm resistor) or an inductor... we need to know where these traces go.
          • Curious.George
            • Nov 2011
            • 2305
            • Unknown
            An obvious approach is to see if it is a separate subcircuit vs. one of the many (likely identical) FET circuits in that area. In the latter case, you can examine the non-toasted FET circuits to identify the component and value.
            • Stigsolbjerg
              • Mar 2020
              • 33
              • Danmark
              HI now i am measuring on the board.
              no. 1. in the battery connection between + and - i get 6 kohm and rising fast to 1000 kohm, maybe starting from zero ohm.
              no 2. on the big electrolytic cap (next to the blown something) there is only 2,4 ohm
              no 3. on the big electrolytic cap same size as no. 2 there is 3,66 kohm
              no 4. from the battery connection there is 2,5 to 3 ohms on both sides of the blown thing.
              no 5. from the blown thing to the electrolyte there is 2,7 to 4,5 ohm.
              these low values are going to zero when swithing to diode mode.
              no 6. i cant see where the traces are going, it goes under the electrolyte.
              Should i remowe it and look, What value should it be reading when i
              desolder it from the board?
              P.s it is 4 layer pcb with lacuer on.
              • CapLeaker
                Leaking Member
                • 8352
                sounds like something is shorted at your step number 2. Make pictures each step as you go along, so that you know where things went and in which direction they were sitting on the board, when you take parts off the board. That electrolytic cap has a value of 220uF at 50V. My guess is, that when you take the capacitor off, the cap tests good, but you got a short across the 2 pads where the cap was sitting on. Check and compare the 9 FETs below that cap. Maybe one or more are shorted.
                Can you clean that area where the burnt mystery device was up with rubbing alcohol and make another picture of it to see where the pads go?
                • Stigsolbjerg
                  • Mar 2020
                  • 33
                  • Danmark
                  you were right, took the cap of today, and the short is still there. I sadly tore one of the traces of the board and damaged it a bit, that cap was very hevily solded under its socket. but i think it can be repaired.(see attached pic).
                  you said there could be a short in the nine fets. How do i check that.
                  • Stigsolbjerg
                    • Mar 2020
                    • 33
                    • Danmark
                    hopefully a better pic here
                    • R_J
                      • 9628
                      Based on internet pictures of the board, it kooks like the "blown something" is a mlcc (ceramic cap), the cap that was missing is a 220µf/35v. Like suggested there is likely one or more shorted mosfets.
                      There is liklely a diode for polarity protection, or the POWER SWITCH is not connected, that is why there is no short measured across the BAT connection.
                      • Stigsolbjerg
                        • Mar 2020
                        • 33
                        • Danmark
                        hi Capleaker and R_J. you got me thinking could it be the powerswitch, hooked it and and the problems still there.
                        so i started looking for shorts on the mosfets. but i dont have a clue on how to look on mosfets, so here is what i found. all of 9 mosfets are shortet like the one marked whit green, but only nr 8 are shorted 2 more places marked blue and red on the pic. is this right done?
                        • R_J
                          • 9628
                          try cleaning the coating off one of the mosfets to see if you can read the number (don't use sandpaper) try cleaning it with alcohol.
                          • Stigsolbjerg
                            • Mar 2020
                            • 33
                            • Danmark
                            ha its a 1F33AB FDD 8424H. im suspecting i need a new one, does enyone have any ideas where to find one (laptops-printers-tv´s) or do i order in china and wait for 3 weeks.
                            • R_J
                              • 9628
                              The mosfet number to use is FDD8424H, most suppliers like digikey, mouser etc. have it. Now that you have the number, here is the datasheet. You might be able to remove the one bad mosfet and check that the short is no longer there.
                              The short you measured (yellow) is S1 to S2, this might be normal and the source pins are connected together, Check for shorts between D1/D2 and S1/S2
                              • Stigsolbjerg
                                • Mar 2020
                                • 33
                                • Danmark
                                Hi R_J im sitting here and looking to buy new mosfets, you linked a data sheet to a 20 amp one, but at digikey they only have a 9-6,5 amp one. and at r.s.online they have both, but calling the 20 amp fdd8424H-f085a.
                                so now im totally lost, is the 9-6,5 amp ok? i can buy minimum of 5 of that.
                                • CapLeaker
                                  Leaking Member
                                  • 8352
                                  did you actually find a blown FET on the board, before you go out and order something?
                                  • Stigsolbjerg
                                    • Mar 2020
                                    • 33
                                    • Danmark
                                    No sorry, i was only Looking for cheap plaeses to buy now. I am still trying to figure out how to desolder the FET from the PCB, i do NOT have a fancy hot air soldergun/blower thing.
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      Once you find the shorted part, lets say it is one of them fets, you can clip the legs with the side cutter, drill a big hole in the top of the fet until you get metal (dont drill through) then take a large wattage soldering iron / gun and unsolder the rest.
                                      First things first... you NEED to find the broken part first. Do you have or can you borrow a CC / CV lab power supply?
                                      • Stigsolbjerg
                                        • Mar 2020
                                        • 33
                                        • Danmark
                                        hi happy news from Denmark.
                                        its working
                                        i did order the 5 mosfets from the danish supplier, the 6,5-9 amps one.
                                        my soldering iron had no chance at the mosfet, so i used the Dremmel and grinded the most off it away. Then i soldered in a new one and the rest of the componets. hooked it up, flipped the on/off switch and the display lights up.
                                        Damm good feeling.
                                        Thank u so much Capleaker, Curious.George and R_J for helping me
                                        • Nairolf
                                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                                          by Nairolf
                                          I have a Samsung DM32D display.
                                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                                          Here’s what I have tried so far:
                                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                                          08-24-2025, 03:47 AM
                                        • riko 656
                                          Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                          by riko 656
                                          I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                          Laptop Model:
                                          • Model: Lenovo Legion Slim 5 16APH8
                                          • GPU: NVIDIA GeForce RTX 4070
                                          • Main BIOS chip size: 32MB
                                          • VBIOS chip size: 16MB
                                          Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                          What I Have Tried So Far:
                                          1. I
                                          11-04-2025, 05:14 AM
                                        • harshana
                                          DA0ZPVMBAD0 rev d Mainboard - blank screen issue
                                          by harshana
                                          I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
                                          When I power on with fn+ esc the blue light start blinking on mainboard.
                                          I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
                                          https://www.badcaps.net/forum/troubl...and-electronic...
                                          08-16-2025, 02:16 PM
                                        • alltvrepairs
                                          Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                                          by alltvrepairs
                                          I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                                          This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                                          Any help appreciated!...
                                          03-14-2024, 03:39 AM
                                        • dbuergi
                                          PS5 Dualsense controller stick drift a mainboard issue?
                                          by dbuergi
                                          I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
                                          I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
                                          05-02-2025, 05:00 PM
