Gardena R38li lawnrobot mainboard power issue
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Gardena R38li lawnrobot mainboard power issue
    I am glad to hear that the repair was a success!
      • Jul 2011
      • 6070
      Another product that did not end up in a landfill good job getting it to work again
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • riko 656
        Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
        by riko 656
        I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
        Laptop Model:
        • Model: Lenovo Legion Slim 5 16APH8
        • GPU: NVIDIA GeForce RTX 4070
        • Main BIOS chip size: 32MB
        • VBIOS chip size: 16MB
        Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
        What I Have Tried So Far:
        1. I
        11-04-2025, 05:14 AM
      • harshana
        DA0ZPVMBAD0 rev d Mainboard - blank screen issue
        by harshana
        I have the DA0ZPVMBAD0 rev d logic board and it doesn't boot up. I see all the voltages are okay. So I suspect the issue is bios.
        When I power on with fn+ esc the blue light start blinking on mainboard.
        I guess its a good sign. As all the voltages are okay and also charging indicates orange light when battery connected, I think it confirm that the EC bios is okay. So I ignored the ec and flashed main bios with 32mb bin file provided in the link below. But the condition is same.
        https://www.badcaps.net/forum/troubl...and-electronic...
        08-16-2025, 02:16 PM
      • alltvrepairs
        Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
        by alltvrepairs
        I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
        This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
        Any help appreciated!...
        03-14-2024, 03:39 AM
      • dbuergi
        PS5 Dualsense controller stick drift a mainboard issue?
        by dbuergi
        I got a controller where the left stick was moving left all the time (-1.00 at calibration tool). Even after changing to hall effect sticks it stayed the same and reset and all others things didn't help.
        I removed the stick again and even without it calibration tool shows a movement to the left. Anybody knows where the fault can come from? Maybe any bridges or damaged SMD components?
        05-02-2025, 05:00 PM
