Baofeng charger mods
    • 31298
    TP5100 module.
    1A charge, 10-18v input
    • Jul 2011
    • 6070
    Re: Baofeng charger mods
    How well dose it work
    So goes to a radio receiver
    Three different models
    In the last picture what type of ic chip was there
    I like your idea for this mod
      • 31298
      all those bases had the same circuit, sc6038 based linear charger.
      slow as fuck with a 10v maximum input.
      what you cant see is that i sliced 2 of the boards up to retain the input connector and mounts.
      it works well - upto 2Ah charge(i set it to 1Ah) and it smart-charges a 2cell lithium pack.
      older iCOM stuff could really use this mod!!
        • Jul 2011
        • 6070
        What was the charging amps with old controller in it
        Because from the data it not exactly clear what the charging current is suppose to be
        The only reference I could see the trickle charge mode 60 ma really
          • 31298
          old circuit charged an 1800mA pack in about 6hours!!
          it's a compromise,
          they used a linear charger so you could keep the radio on in the base,
          but because it's linear they had to keep the current low and the voltdrop to a minimum(10v) to keep it from getting hot!
          i did not try to run the radio on the base now, but i bet there is lots of rf noise from that inductor!
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8715
            Based on what mine was before it croaked, it was set at a charging current limit of 400mA, so 1.8Ah in 6h is about right taking in account absorption phase and charging inefficiencies.
            At 400mA the chip would have to dissipate 1W+ which is excessive for a SOP8 IMHO.
              • 31298
              you should get one of those modules - they dont even warm the case up!
              btw, i'm waiting now for bi-colour leds.
              only chinese suppliers had common-anode ones, all the local places only stock common cathode.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8715
                Well I ordered one, hopefully it works. And no CA LEDs, I think the old one in the charger is a CC? I suppose I could just use two discrete LEDs hidden behind the hole or build a light pipe for the LED on the board... or add two PNP transistors and two resistors...hmm...
                Probably will also have to mod the board to 1A or less max charge rate to the 1.8Ah battery..
                  • 31298
                  to set the board for a 2cell pack you blob-link a pair of pads,
                  to switch from 2Ah charge to 1Ah you remove one of a pair of 0.1ohm shunt resistors that are in parallel
                  the board has leds on it - you can see it through the case - but i want the original look so i ordered these:
                  https://www.aliexpress.com/item/32415510038.html
                  not sure what i'll do with the other 97 of them!
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8715
                    Eh, the LED is not a big deal. Definitely not worth it to get a hundred of the CA LEDs but I may end up putting in a CC unit with two 2n3906's and resistors... mainly because I have a large pile of 2n3906's I'll never finish using up...
                    BTW, your UV82 original charger board looks better than mine...though not any better than the UV6R.
                      • 31298
                      better how? you mean the surface area of the copper?
                      it's an early one - i grabbed the uv82 when they first got released - love that double-ptt!
                      i was a bit shocked with the uv6r that they reduced the pcb to a thin strip that just stretched from the power jack to the led hole!
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8715
                        exactly. must have been some beancounter and ignored the design engineer...
                        not so sure about the double ptt, though I never suffered a uv5r with dual watch. I wish it was dual vfo... that would be nice.
                          • 31298
                          double ptt comes into play when your talking with 2 groups you want isolated from each other.
                          great on work sites.
                          uv6r functions like a uv5r - just built better.
                          dual watch with single ptt is a pain in the ass, you have to constantly be checking the A/B flag before transmitting, or put both on the same channel.
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8715
                            Work sites? using ham radio? Or using Baofeng instead of a legal part 90/95 radio (for USA...)? :o
                            Yeah this radio is not quite FCC approved for what dual PTT would be nice for. Using the dual watch for two amateur repeaters and you don't necessarily know who's talking on which repeater even if you recognize the voice but don't know which repeater...
                              • 31298
                              i'm not in the u.s. - FCC can go fuck themselves.
                              as long as i use the legal frequency's and power limits for the purpose, nobody gives a shit here.
                              you know which channel your recieving from because there is a little flashing arrow on the display btw.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8715
                                I don't stare at the little screen all day... wish it would indicate the frequency last reception occurred on well past carrier loss.
                                  • 31298
                                  it can,
                                  you can set it so that it locks onto the slot it last recieved on.
                                  these radio's are very advanced, but the instructions are pretty long - and the older manuals like the 5r are shit.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8715
                                    Doesn't seem to be obvious what setting to use to "lock" onto the last slot. What does it mean to "lock" anyway when you have dual ptt?
                                    Closest to what I see is if you're in scan mode you can tell it to stop scanning when it receives something but this isn't what I want...
                                      • 31298
                                      on dual ptt it has no use, but if you only have one ptt then it can latch the ptt to the last slot (A/B) it recieved a signal on.
                                      i hope your using CHIRP and not the factory software!
                                      https://chirp.danplanet.com/projects/chirp/wiki/Home
                                      • motormayhem
                                        Lenovo T460 Only Charges on One Charger
                                        by motormayhem
                                        Laptop Question
                                        I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                        A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                        05-12-2023, 01:46 PM
                                        NVDC charger configuration...
                                        11-05-2024, 03:28 PM
                                      • flat-earther
                                        how to prevent a connected charger from draining battery when not charging?
                                        by flat-earther
                                        I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                        So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                        but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                        So the battery is backfeeding the charger and being drained.
                                        How can I prevent...
                                        08-07-2025, 01:04 PM
                                      • flat-earther
                                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                                        by flat-earther
                                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                        Windows also shows ''Plugged in'' when charger is not connected.
                                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                        If I let battery run out and say it has 3% Windows will...
                                        06-24-2025, 09:32 AM
                                      • Johndill
                                        Dell Inspiron 7567 LA-D993P odd charger issue
                                        by Johndill
                                        Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                        There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                        I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                        Here are the tested scenarios:
                                        1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                        2. With the laptop off, plug in charger (LED says on) & the front charging...
                                        11-16-2022, 10:55 PM
