ps3 fat overheating problem
  • elpiko
    • May 2020
    • 25
    • Seychelles
    hi all i have ps3 fat it power on i get to the menu and even start a game then then fan starts to get louder and louder still is automatically shut down. i tried doing a reflow on the gpu and rsx chip with my smd rework at temp 235 degrees Celsius for ab out 90 second on each chip but getting same problem. i dont know if i would increase time im heating the chip or if i should increase temp but i dont want to burn it.
    also i dont have the gray thermal paste im using the white heatsink compound i normally use on transistors i dont know if this is also an issue.
  • ngth82
    • Jul 2015
    • 541
    Re: ps3 fat overheating problem
    Did you use good quality thermal paste, like MX4? Sounds like you used the cheap stuff... which is likely contributing to the issue.
    Reflowing isn't going to do you any good in terms of long term fixes.
    If you have Facebook, come to the Game Console Repair Legion FB page and post your question there. I'm one of the moderators. https://www.facebook.com/groups/console.repair.legion/
    -Thomas
    I'm a hardware engineer focused on networking equipment for my day job. I void warranties and fix consumer electronics for fun.
    • elpiko
      • May 2020
      • 25
      • Seychelles
      i got some gray thermal paste today at a computer store ill try some of these and see if it makes a difference. i will check the facebook page maybe will get some good advice there to sharpen my console repair skills.
      • sigmeyer
        • Feb 2020
        • 149
        • Serbia
        PS3's are known to have problems with CPU's or GPU's overheating quickly , it is most likely cpu going bad... One thing you can try is putting a washer in between screws that push the cooler onto the cpu and gpu so it puts more pressure on it.. Also i would consider taking that metal cover off them and cleaning them nicely.. reapply the new thermal paster under the metal and on top , put the washers on and pray it works... also 235 celsius for a reflow is not enough to do anything... You would have to go about 350 to melt solder but considering the heat dissipation on these boards i dont know if 400 will be enough.. anyways i wouldnt mess with that untill you've exhausted other options.
        • Hombre
          • Jul 2013
          • 231
          • Croatia
          To solve this problem you will most probably have to take off IHS (metal pad between CPU and cooler), because thermal paste between CPU and IHS is not working as it should anymore. I had the same problem and few days ago did this, even with a generic thermal paste PS3 is silent and not overheating.
          BUT, it's not an easy job, and there is big chance that you will damage chip if you don't do it carefully. Then the PS3 would become parts donor, so be aware of that.
          I followed this guide: https://www.youtube.com/watch?v=rDK9aR_xXrs and as a tool used 0.2 mm feeler gauge
          Do it on your own risk!!!!!
          • reset1986
            • Dec 2014
            • 308
            • italia
            ps3 fat have many problems, remove ihs on the bga very carefully and apply thermal paste,
            the one that overheats more cell cpu, be very careful for the removal of ihs, if you scratch the cpu trash the mainboard
            • Veyron7887
              Laptop overheating after replacement thermal paste
              by Veyron7887
              Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
              11-24-2024, 05:08 AM
            • Zeonalbasta
              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
              by Zeonalbasta
              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
              09-13-2024, 01:17 PM
            • Gibon378
              Problem with stopping audio and video for no reason
              by Gibon378
              PC Specs:
              • CPU: Ryzen 5 1600
              • GPU: GTX 1080 Palit JetStream
              • MOBO: ASRock ab350 PRO4
              • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
              • PSU: XFX 650W (don't remember what model)
              • OS SSD: ADATA SP920
              • OS: Windows 10 21H2
              Problem description:
              Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
              11-19-2022, 09:41 AM
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • lazaro.089
              Asus Zephyrus M16 / GU603ZW problem
              by lazaro.089
              Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
              CPU: Core i9-12900H
              Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
              Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
              The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
              08-26-2025, 06:33 PM
