Waylens Horizon Dash Cam battery
  • JPToadstool
    • May 2020
    • 19
    • United Kingdom
    Hoping someone can help to identify the battery from my dash cam, a Waylens Horizon camera.
    I have searched for the numbers on the battery and can't locate a replacement. I have attached pictures of the battery and the connector to help.
    Size is: 30mm x 28mm x 12mm
    Thank you in advance.
    • 31247
    Re: Waylens Horizon Dash Cam battery
    it's lithium-polymer,
    the first number is probably the size in cm/mm
    they are sold by size - you need to unrap the tape and keep the protection board hidden under it.
    is that one bad though - it looks o.k.
    • JPToadstool
      • May 2020
      • 19
      • United Kingdom
      It’s more that it seems to be discharging during use, but I suppose this could be to do with the charging circuitry. Although I can’t figure out how to take the rest of it apart.
      Do LiPos degrade with age much or experience expansion? Most of my experience is with Li-Ion.
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • mkdj
        ASUS X571 no power : battery issue?
        by mkdj
        Mark and model: ASUS X571
        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
        Tests already made:
        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
        - I have removed...
        07-14-2025, 09:16 AM
      • techfreak9356
        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
        by techfreak9356
        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
        09-14-2023, 11:10 PM
        NVDC charger configuration...
        11-05-2024, 03:28 PM
      • ferah831208
        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
        by ferah831208
        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
        03-18-2025, 01:18 AM
