HDMI switch handshake issues?
  • spleenharvester
    • Mar 2010
    • 921
    Got a bit of an odd problem with my setup. I have a cheapo 3 in/2 duplicate out HDMI splitter (this one). One output is connected to a HP 24fw display, whereas a computer (800 G1 USDT with Intel HD 4600 graphics) is connected to one of the inputs, and two consoles are connected to the others.
    The consoles work absolutely fine with it all the time, but the computer refuses to output video after it's been in standby for a while. The input light flashes on - the output light flashes on - then the output light goes off, then the input light goes off, and this cycle repeats forever. It will only come on after unplugging/replugging a bunch of times.
    I know this is a hopelessly vague problem but has anyone got any idea how to fix this? I've tried different cables etc and no change.
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    Re: HDMI switch handshake issues?
    When it works, does the PC identify the sink as 'HP 24fw' (PC detects the EDID of HP).
    What is other sink connected to the second HDMI output?
    Can the EDID mode of the device be set?
    • spleenharvester
      • Mar 2010
      • 921
      1. Surprisingly yes it does,
      2. Nothing on the second HDMI output at the moment,
      3. Unfortunately not - only DDC/CI settings and they don't seem to affect the problem,
      Cheers
        • 22216
        What bios version does the pc have . Looking through the bios release notes - v02.59 Rev.A - Fixed the intermittent S3 resume issue .
        If your bios is older that that version update it ,it might fix your problem.
        • spleenharvester
          • Mar 2010
          • 921
          Latest one unfortunately! Only workaround I've been able to find is setting "Monitor Off:" to "Never" in power options. Not ideal but it does the trick.
            • 22216
            Are you using a DisplayPort to HDMI cable ,or an an active adapter .
            • spleenharvester
              • Mar 2010
              • 921
              Interestingly enough I am using a DP to HDMI adapter yeah - no HDMI ports on this PC annoyingly.
                It looks like your box has the same issue as STARTECH product:
                https://www.startech.com/faq/mst-hubs-sleep-issue
                • spleenharvester
                  • Mar 2010
                  • 921
                  That would make a lot of sense, but unfortunately setting to HDMI doesn't fix the issue for me. Killing the power to both devices seems to be the only way to get it working again.
                    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
                    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                    09-06-2024, 05:30 AM
                  • Servicem4
                    Pioneer lx 701 hdmi issues
                    by Servicem4
                    My receiver pioneer LX 701 doesn't work anymore correctly The history:
                    6 month ago hdmi picture output didnt work anymore but music input through hdmi still worked.
                    Since some weeks even this doesn't work. Right Before this occured i heard a plopping noise from the receiver one evening.
                    The rest of the receiver works, I used spdif for sound input.
                    I now opened the receiver and hoped to find a blown fuse but all look good.
                    Any tips how to progress? Between 2 PCB there is something which looks like a blown cap....
                    Image 20250527-204839 hosted in ImgBB
                    05-27-2025, 01:13 PM
                  • Natob82
                    Micro Momentary Push Switch?
                    by Natob82
                    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
                    12-21-2022, 05:22 AM
                  • grimacelord
                    NEC TurboExpress On/Off Power Switch Replacement Help
                    by grimacelord
                    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
                    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
                    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
                    11-09-2023, 09:49 AM
                  • SluggerB
                    Help making a switch work the opposite way with a relay
                    by SluggerB
                    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
                    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
                    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
                    02-07-2025, 07:57 PM
